Question about Sony KV-36FV26 TV
Sony wega kv-36fv26
Hello: I was wondering if someone can help me or shed some light on my problem. I've got a sony wega kv-36fv26 for about 7 years now, everything is great on it; but, I've noticed that the last 3 years of so, there is a high pitched humming sound comming for the back of the tube (kinda like a high pitched whistle sound), strangely this only occurs in the hot summer months, I'm assuming it has something to do with humidity in the air. Awhile back just before the warranty expired I had call for a repair and the tech had sprayed some sort of silicone around the yoke, it help for about a year or two and now it's back. My question is does anyone know what kind of spray this is and secondly is there as solution to my problem. Thanks
  • Jay Leeb Jul 28, 2007
    Thanks for the advise all, sounds like discharging the tube is the big problem here.
    Two more questions please:
    1) If I was to disconnect the TV and leave it disconnected for several days will this be enough to allow the remove current to leak out by itself?
    2) what kind of silicone/petrolium lubricant should I buy? Is there any special type I'll require? I live in Canada.
    Again Thanks for your assistance.
    Problem Solver:
  • 9 Answers
Hi there, I'll start out by saying that I am a T.V. engineer (now retired). If the problem is exactly as before when the repair guy fixed it for you it is going to be due as you quite rightly say to humidity. A cathode ray tube (CRT) requires a very high voltage (EHT) which can be in the range of 18-30 thousand volts (18-30KV) This voltage is derived from the line output stage of the television and is fed to the tube by means of a single wire terminated with a single connection with shroud. It is usual at this connection to find dust and humidity causing a problem. It is really best to disconnect from the CRT and clean the insulating shroud and the glass area out to the graphite coating of the tube. WD40 will do just fine and a smear of silicone grease after cleaning delays the time span until the next time you need to do it ,although not strictly necessary. WARNING !!! Even with the T.V disconnected from the mains supply the CRT acts as a big capacitor and hold a charge of several thousand volts. It is necessary to discharge this with a couple of insulated screwdivers from the connection point to the graphite coating if you do not want to experience something like a stun gun shock !! If you are not happy about doing this - call someone in. Another reason for high pitched whistles can be loose laminations (coil windings) on the line output transformer which works at a very high frequency. Changing the transformer is usually the only answer in that sort of scenario. Hope the answer is of some help. Be careful with electrics. Regards. Mike.
Posted on Jul 27, 2007
Remove the yoke and DISCHARGE the tube completely then clean with some kind of alcohol based product. get some patrolium gel not vasileen and fill the EHT hole with it and smeer it about an inch or so on the tube and inside the EHT cap this will seal the cap.the reason for the whistle is that carona is leaking and loading the line timebase and will eventually cause the line time base to fail don,t forget you must discharge the tube if you don,t want to get 20'000 plus volts dc up your ass.hope this is successful .
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-36FV26 Picture has washed out and it appears as if there is a film over the color. We have adjusted all color and brightness options and has been like this for over a month. Is...
If the picture is washed out showing poor color it is the picture tube that is the problem, overtime the emission from the guns gradually declines until the picture balance is lost and it progressively gets worse. I recommend you replace it since repairs would involve a new picture tube and cost more than a new set.
Feb 13, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
KV-36FV26 service mode entry
Try Display, Channel 5, Volume +, Power On in quick succession
Jul 02, 2009 | Sony KV-36FV26 TV
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Jan 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
2000 Sony Trinatron #KV-36FV26
IF--- You have 3 video ics located on CRT broad # TDA6111Q ,if only one of them is shorted set will not come on these ics will kill the high voltage, there for keeping set off.
May 18, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
I have a Sony FD Trinitron Wega(Model # KV-36FV26) that has a blinking standby light that blinks intermitenly. Does that mean that trouble is soon to come?
THE TUBE COULD BE GETTING WEAK . IF YOU GIVE
ME THE BLINKING I COULD TELL YOU BETTER, IT ALSO COULD BE A SIGN POWER SUPPLY IS GOING .BOTH PROBLEMS CAN BE FIXED I WOULD WAIT FOR TV TO GO OUT BEFORE FIXING INTERMITTING PROBLEMS ARE HARD TO FIX ESTIMATE ON REPAIR IS AROUND 160,00 DOLLARS
THANKS DOCTOR VIDEO
Apr 25, 2008 | Televison & Video
Sevice Codes for Sony Wega KV-36FV26 TV
Sony Blinking Codes
http://www.iwaynet.net/~nesda/SonyBlink.html
Apr 01, 2008 | Sony KV-36FV26 TV
1999 sony trinitron kv-36fv26
Hello, please check: 1) is the regulated B+ avail at collector of HOT? 2)does the base of HOT go negative when unit is powered? 3)have you examined the external PIN diode for leakage? I sorta recall from memory this circuit and the B+ path from original 165 volt source thru to collector of HOT is not a simple distrubution path i recall a VDR in second stage with a resistor to ground around 5.6 ohms this resistor will discolor or change value if the VDR is defective be careful there are several of these VDR's avail use only the correct one. Best regards, Arpi
May 28, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-36FV26 TV Logo
150 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
