Question about Dell 5100cn Laser Printer
Color printing Hello - I have a dell 5100CN printer and just want to print in black ink only, how do I do this? Thanks for your help
  • 73 Answers
When you print something and the window pops up, go to preferences and youll be able to specify "black" as the output color.
Posted on Feb 07, 2009
My dell printer 5100cn , print quality very light, replaced inks drum and still having problem with black
laser printers have a high freq high voltage wire that puts ions on the paper as it passes ,
have you cleaned this wire . it attracts dirt an inks like the paper it treats.
there is a wire cleaning tool in the machine usually.
Jan 04, 2015 | Dell 5100cn Laser Printer
Printer will not print in color
Printer properties in "start menu" printing preff. (make sure you are not using a black and white driver) -Car
Apr 17, 2014 | Dell KDA1 Color Laser Printer 5100cn PC...
No color printing
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 05, 2013 | Dell 5100cn Laser Printer
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
Black color has faded to unreadable Have replaced all components
chean the black cartridege with a cleanex and tap it to see if ink will come outm if it does bor then it has dried out and needs replacement.
Jan 11, 2010 | Dell 5100cn Laser Printer
Dell 5100cn small dots of all colors are on all prints
I had the same problem on an HP, and the only thing that solved it was replacing the drum. Not sure if that will help, not even sure if that printer has a drum, but maybe swap out the ink or toner or drum and see if that helps. If it doesn't, at least the money you spent on those options goes towards something you can use...
Jun 23, 2009 | Dell 5100cn Laser Printer
How can I ignore the low toner error message and print black on a Dell 5100cn?
i believe that if you remove the color toner cartridges, it will stop asking and only print black. you may also be able to specify in the print menu settings to disable the color printing
Jun 10, 2009 | Dell 5100cn Laser Printer
Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Oct 19, 2008 | Dell 5100cn Laser Printer
Dell 5100CN Color laser printer - full page wash
Hello from france !!
Your mistake come from the fuser.
Change it and all be fun
See xerox phaser 6300 fuser is most cheaper and it's compatible !!
Jun 08, 2008 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
134 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
