Question about Dell W1900 19 in. HD-Ready LCD Television
TV forgets channels when unplugged
My Dell W1900 LCD TV is a couple of years old. Whenever we unplug it from the wall (or have a power cut), it forgets all its channel settings. I'm guessing that there's a backup battery in there somewhere that needs replacing - does anyone know whereabouts inside the set I should look for it?
  • Peter Flint Jul 27, 2007
    No, this is a recent development - it used to remember the settings.
    I had a Phillips tube TV some years back which eventually developed exactly the same problem - in that case I was able to locate the backup battery which was soldered into the main circuit board. With the Dell I've looked, but the battery isn't anywhere obvious.
    Thanks for the suggestion, though!
Has it always forgotten the channels when you unplug it or is this just a recent development? I know that on my old standard tube television or VCRs, the channel memory is always reset if they are unplugged - the same being true if the power goes out.
Posted on Jul 27, 2007
SOURCE:
My mitsubishi Model # WD-60737. It is lesss than a year old. The status light flashs green, the Mitsubishi blue start up page comes up the the tv cuts back off. I have unplug from the wall for an hour....
Tv under a year old call Misubishi for a warrenty repair.Flashes staus light mean could be any these parts have problems power supply board,Ballast board or the pojection lamp itself.
Jan 11, 2011 | Mitsubishi WD-60737 60 in. HDTV
For the past couple days, my 32" samsung LCD will cut off by itself. It won't come back on unless I unplug it. A little while later the same thing occurs again. The TV is not even a year old yet. What...
Since it is still under Samsungs' 1 year warranty period, you can call 1-800-samsung and they will set up the repair with the closest authorized service center at no cost to you.
May 20, 2010 | Samsung LN32A550 32 in. LCD TV
When i cut my tv on it cuts off i have an hitachi 42 inch
TVs don't like being cut. It breaks them.
If you meant to say "when I turn on my TV, it turns on for a second then turns off", call Hitachi.
Oct 12, 2009 | Dell W1900 19 in. HD-Ready LCD Television
Help me turn my tv on
Dell are a bunch of rip off artists.
Dell tv/monitors turn off if there is no input coming from the selected input. In this case DVI, try powering on the TV and using the menu buttons along with the channel Up/down buttons on the tv to select a different input.
Hopefully this works for you.
Jun 01, 2009 | Dell W1900 19 in. HD-Ready LCD Television
My main menu button is locked and don't know how?! Any ideas? Its a dell multimedia 19" flat LCD.
if its a w1900 this is a known setting. Press the menu button on the right hand side of the TV (second button UP, just above power/standby. Now, WHILE THE MENU LOCK MESSAGE IS BEING DISPLAYED, press CH ^ and VOL - AT THE SAME TIME. Menu unlocked message should be displayed.
And you're done.
Might take a couple of tries - this tv/monitor is a bit fiddly...
Feb 21, 2009 | Dell W1900 19 in. HD-Ready LCD Television
Black box on screen
I was having the same problem. Try making sure Closed Caption is turned off. It is CC on the remote.
Oct 08, 2008 | Dell W3000 30 in. HD-Ready LCD Television
I have the same problem also. I am assuming that the power supply is bad. I have looked everywhere and can not find a replacement or the pinout on the supply. If anyone can find a service manual or a replacement board, please let us know.
Jun 01, 2008 | Dell W1900 19 in. HD-Ready LCD Television
LG 60 IN FULL HD PLASMA
Try unplugging it from a surge protector if you have one and plug it directly into the wall see if thats a fix.
Dec 11, 2007 | LG 37LP1D 37 in. LCD Television
Problem with changing channel and volume
your TV is having problem in the power supply area or th secondary power supply where the micro processor is situated.take it to a qualified techn to be repaired.
Jan 20, 2007 | Dell W1900 19 in. HD-Ready LCD Television
Dell W1900 19 in. HD-Ready LCD Television Logo
121 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
