Question about HP DeskJet 870cxi InkJet Printer
Hp870cxi i have a hp870 printer but the paper is not loading
    New Friend:
Periodically you need to clean the rubber paper feed wheels with isopropilic alcohol (tape head cleaner). They become hardened with age and the alcohol softens them again for a while and enables the to grip the paper.
Posted on Dec 21, 2012
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Receipt printer paper reduction isn't working
Power the printer on and press the Paper button to see if paper will load.
If the paper doesn't load, make sure the paper isn't curled or creased, isn't loaded above the arrow on the left edge guide, and that the paper isn't jammed in the printer.
Take the paper stack from the tray; fan it before attempting to print.
Make sure the paper stack is leaning against the paper tray and not standing straight up in the tray.
If the Paper Out light is on solid, reload the paper, making sure the paper edge guide is adjusted to fit the paper's width, and then press the Paper button again to see if the paper will now load.
If the Paper Out light is flashing, turn the printer off, reload the paper, turn the printer back on, and try pressing the Paper Feed button again to see if the printer will now successfully load the paper. If the problem persists, power the printer off, remove the printer cable, and make sure all of the packing materials are removed.
If the problem is not resolved, contact Epson's technical support for further assistance.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Dec 10, 2012 | Epson TM-T88V (Part C31CA85081) Power...
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
support?
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
condition
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Troubleshooting
68
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
guides
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
Quits printing and screen says "need service"
A: Power the printer on and press the Load/Eject button to see if
paper will load. If no paper loads, make sure the paper isn't
curled or creased, isn't too old, isn't loaded above the arrow on
press the Load/Eject button again to see if the paper will now load.
the paper, turn the printer back on, and try pressing Load/Eject
If the printer still will not load paper, power the printer off,
are removed. If the problem persists, the printer may need to be
sent in for service and you should contact the EPSON Connection for
assistance.
Jan 13, 2010 | Epson Stylus Photo R300 InkJet Printer
Printer says no paper, but there is. Problem loading?
If not paper jam may has some problem with feed rollers on printer.First make sure that option to feed from cassette is turned on.Check this on maintenance mode.Аs the printer is in warranty better don't touch anything else and call Canon.
Nov 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Will not recognize loaded paper, keeps saying no
There 's a torn piece of paper blocking the paper level sensor. Re check all areas where the paper feeds. the try re insert the paper, if its clear . turn printer off for 5 mins then turn on and try again
Jul 08, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jam
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
    Note:
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 22, 2009 | Canon PIXMA MP600 all-In-One InkJet...
5110 ERROR ON PIXMA PRO 9000
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Solution: Removing paper jams MP800R / MP830 / MP530
  1. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note: Be careful not to touch the components inside the printer.
  2. Turn on the printer and confirm that the Alarm light is off.
  3. Load paper back into the ASF.
  4. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  3. Open the rear cover to check if the paper is jammed.
  4. Pull out the cassette and check if the paper is jammed inside the cassette area.
  5. Stand the printer with the rear side down, holding the document cover.
  6. Press the tabs together and pull the green cover toward you.
  7. Check if the paper is jammed.
  8. Close the green cover and place the printer back to a normal position.
  9. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  10. Load paper back into the ASF or cassette.
  11. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer loads paper incorrectly when trying to print
in the tray where you put the paper, there are two pieces of plastic that site on the side ,,,,, bring them close to the paper as to touch the paper.
this way the paper cannot go left or right when loaded and now will go in straight.
this oughta do it.
Mar 26, 2009 | Dell 922 All-In-One InkJet Printer
HP DeskJet 870cxi InkJet Printer Logo
76 people viewed this question
Ben Johnson
