Question about Western Digital Cen Genesis Gst 7.7 Rtr 4wd Nitro Monster Truck
Cen genesis .46 nitro 4x4 truck won't shift to 2nd & 3rd gears
Cen genesis 3-speed tranny problems
  • msanfil1 Mar 09, 2009
    the truck seems to drop into neutral when driving
Agree with juchertf100, but also, your motor needs to run lean enough to transfer power when the transmission requires it. There is an engineering gap. Set your tranny to factory specs and lean your motor to operate just under max engine temp. The genesis is an all or nothing machine and the transmission needs constant power to operate properly. After many times of tearing down a tranny I have found that power delivery is the main culprit when shifting is a problem.
Sincerely,
Genesis owner 5 years
Posted on Feb 08, 2010
Have you tried to back out the screws in the clutch shoes
Posted on Feb 12, 2009
My 1999 ford ranger shifts hard from 2nd to 3rd gear what is the problem I recently changed fluid and filter but shifts hard !
Auto Trans not shifting correctly from 2nd to 3rd - Ford Explorer ...
www.explorerforum.com > ... > Under the Hood
May 8, 2004 - 19 posts - ‎9 authors
Auto Trans not shifting correctly from 2nd to 3rd Under the Hood. ... Become an EliteExplorer. Lithuania. 1999 5.0. Join Date: Jun 2003. Posts: 107 ... When this happens, the transmission will skip to the next gear like you said.
Transmission Harsh shifting - YouTube
? 3:59
https://www.youtube.com/watch?v=aAoiL4vR8Qw
Jan 13, 2013 - Uploaded by James Burns
... Doctor, explores the causes of harsh shifting in automatic transmissions. ... Early diagnosis is important to ...
Hard Tranny Shift between 2nd & 3rd - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Feb 24, 2012 - Hard Tranny Shift between 2nd & 3rd Super Duty & Heavy Duty. ... I just got a new to me 99 f250 5.4 V8 SD XLT 4x4 Auto Trans longbox 118k miles. ... it out and said it was solid except for a hard shift between 2nd and 3rd gears. ..... Hard shift between 2nd and 3rd, Brenda Lamka, Explorer, Sport Trac, ... hard shift 2nd to third gear only 4r100
Dec 26, 2012
hard shift into 3rd
Nov 4, 2009
4r55e 5r55e Ranger / Explorer Transmission Problems - CLICK ...
Mar 15, 2007
00 Expedition trans shifts late and hard
Jan 01, 2016 | Ford Cars & Trucks
I have a 94 f150 4.9l with a 5 speed manual and lost 2nd and 3rd gear, would be greatful for any advice, took the shift lever out and reinstalled , did not help. What am I missing or looking for?
I'd be looking for a replacement 5 speed transmission. Does it not go into 2nd and 3rd, or does it go in but won't move? Either way, something broke or is wrong internally, maybe the synchronizer rings are badly worn if it is difficult to put in gear. Can you put it in 2nd with engine off, then start the engine and see if it will move in 2nd? New tranny. Will it not go into 2 or 3? New tranny. Buy a used one, or check the rebuild cost- probably prohibitive.
Aug 25, 2015 | Cars & Trucks
I have a 1999 Chevy 5.3L Silverado Z71 4x4. My truck is having transmission issues. In drive (D) it shifts 1-2. During that shift it hesitates before shifting to 2nd and rpms rise. It will not shift to 3rd...
that should be a 700R4. probably a broken sunshell inside the tranny. need to have it rebuilt. Mine only cost 250 bucks for the parts, but the tranny guy is family.
Sep 29, 2013 | Cars & Trucks
Hesitation or slight bucking when shifting from 2nd-3rd.
Why are you shifting from 2nd to 3rd gear ? is this a standard or automatic? If its a automatic its normal for the torque converter to catch up with the speeds of the tranny. To save the life of your tranny try to let the tranny do the work by itself and don't shift unless in adverse weather conditions.
Jan 14, 2011 | 1998 Mercury Mystique
We cannot get out of 1st or 2nd gear - (3rd & 4th won 't work and the speedometer is not working) - we already changed the speed sensor - this is a K1500 4x4)
sounds like a modulator problem,make sure you have vaccume going to the modulator on the tranny, start the truck leave it in park pull of the vaccume line at the tranny , if its got fluid in it then its bad, and make sure you have vaccume too it!!!!
Jan 05, 2010 | 1993 GMC Sierra C2500
92 chevy s10 4x4 4.3L manual transmission no 3rd gear
Hi:
Your transmission has 3 shift rails...
1st - 2nd
3rd -4th
5th- Reverse
If your 3rd gear doesn't work , you have an internal transmission problem, such as a syncronizer, or similar fail... There is not much you can fix, without removeing the transmission.
Nov 30, 2009 | 1992 Chevrolet S-10
We own a 2001 Dodge Ram 1500 4x4 with an automatic transmission at low speeds the transmission is shifting from 1st to 2nd gear back and forth and back and forth. Once you get it going fast enough to shift...
sounds like a valve body problem in the tranny first try some trans matic you can get it at auto zone if that doesnt help try a fluid and filter change in the tranny!!!!!!!!
Nov 30, 2009 | Dodge Ram Pickup 1500 Cars & Trucks
1st and 2nd gear went out
Check your shifting forks, they are probably worn out
Jun 28, 2009 | 1995 Ford F150 Styleside Regular Cab
Western Digital Cen Genesis Gst 7.7 Rtr 4wd Nitro Monster Truck Logo
1,026 people viewed this question
Top Western Digital Toys Experts
ray gallant
Are you a Western Digital Toy Expert? Answer questions, earn points and help others
