Question about Amana ALE866SB Electric Dryer
Belt broke on Amana dryer
How do I chang the belt.
  • 547 Answers
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Posted on Feb 12, 2009
How to change an amana dryer belt on a model # led20aw
Here is the diagram for the Amana dryer belt routing.
Here is a video to show you how to open the dryer.
Oct 02, 2011 | Amana Dryers
The drive belt broke
Hello there and thanks for cfhoosing fixya
Here is a listing of the belt diagrams and a part number for you ok?
Belt, Drive
Item # 529597
img-descriptiontab-on.png img-repairgurutiptab-off.png Dryer belt. This is the most common belt used on Whirlpool, AMANA Kenmore, Kitchenaid, Roper, Estate and other dryer brands. The belt is flat, 92-1/4 inches long, 1/4 inch wide and has 4 ribs and 3 grooves. It replaces many other belts, including some with 5 ribs and 4 grooves.
img-descriptiontab-off.png img-repairgurutiptab-on.png See our dryer belt diagram to see how this belt should be installed around the motor and idler pulleys.
Watch Video
Order now and choose FedEx 2Day or FedEx Overnight shipping and this item will ship out today - or it's FREE!
$11.20 Quantity:
In Stock
Feb 05, 2011 | Amana NGD5400TQ Dryer
Dryer belt does not apear to be broken but cannot see what pully is broke or other problem
if the belt isnt broken,and just loose then check your "idler" pulley,its on a spring steel bracket by the motor and it keeps the belt tight thats more than likely the culprit from your description
Aug 24, 2009 | Amana NGD4500VQ Dryer
My amana electric dryer starts (makes noise, heats) but the drum does not turn or tumble. What can I do?
there is a big belt inside that turns the drum , your belt maybe slipped off or broke.
Aug 20, 2009 | Amana Dryers
Won't spin or start
Sounds like the screen/sock combo got the tub in a bind and the drum belt broke.
If you want to pursue replacing the belt, let me know.
Apr 30, 2009 | Amana LGA10 Dryer
belt goes around drum and motor pulley and under tentioner
Feb 18, 2009 | Amana NDE5800AY Electric Dryer
Amana Dryer belt instalation
Remove the power to the unit and the bottom access panel. Remove the front bulkhhead where the drum sits on by undoing four screws one for each corner.Verify felt seal on exhaust fan cover is airtight on flange of duct. If seal is installed improperly air flow will be restricted which can cause poor dryer performance.Belt must be positioned around cylinder between center and rear bafflescrews with the ribbed surface against the cylinder. You gotta push up on the spring loaded idler pulley the easily slip on the belt to the motor shaft. make sure that the ribbed part of the belt wraps around the drum and motor shaft and not kinked.
Jul 31, 2007 | Amana DLE330RAW Electric Dryer
Amana ALE866SB Electric Dryer Logo
197 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
