Question about NEC Dterm DTP 16D-1 Corded Phone
How can I forward the calls coming in to another phone?
  • 360 Answers
Call forwarding is a feature offered by your phone company. Contact your provider for instructions and fees
Posted on Jan 29, 2009
I forwarded my cell phone calls to my house phone. I cannot deactivate call forwarding. I have a Samsung S7
  • 1.From the home screen, tap Phone
  • 2.Tap More
  • 3.Tap Settings
  • 4.Tap More Settings
  • 5.Tap Call Forwarding
  • 6.Tap Always Forward
  • 7.Enter the number you would like your calls forwarded to and then tap Enable
  • 8.To disable call forwarding, swipe down from the top of the screen
  • 9.Tap the Call Forwarding notification
  • 10.Tap Always Forward
  • 11.Tap Disable
Samsung Galaxy S5 How to Setup Call Forwarding
Feb 11, 2017 | Samsung Cell Phones
Mobile phone Nokia 311 - Call forwarding is get activated want to deactivate but not able to do.
Hi Shailesh,
I have steps below on how to turn it on and since your concern is to turn it off please do the vice versa. Hope it helps.
Forward calls to your voicemail or another phone number Your phone is ringing, but you can't answer? Let the call go to your
voicemail, or forward it to another number. Call forwarding is a
network service.
1. Select settings > calls > call forwarding.
2. Select when to forward the incoming voice calls:
all voice calls - Forward all calls.
if busy - Forward when busy.
if not answered - Forward when not answered.
if out of reach - Forward when the phone is switched off or out of
network coverage for a certain length of time.
if not available - Forward when busy, when not answered, when the
phone is switched off, or when out of network coverage.
3. Select activate > to voice mailbox or to other number.
4. If if not answered or if not available is selected, set the length of
time after which a call is forwarded
Nokia 311 User Manual Page 30 Forward Calls To Your Voicemail Or...
May 02, 2014 | Nokia Asha 311 Mobile Phone - Unlocked Red
Phone doesnt ring, it goes straight to voicemail
Hii pls chk for all saved contacts, the option "send calls directly to voicemail" is unchecked.
and also verify that the following are unchecked under: Call Settings-->Call forwarding
1-Forward when busy
2-Forward when unanswered
3-Forward when unreachable
If the problem still occurs contact your customer care executive.
Jun 07, 2012 | HTC Status
I have a lucent Partner 18d telephone. I want to be able to have a button programmed so that the secretary can transfer incoming calls to outside phones ( call comes in, secretary presses a button, dials...
That is not possible on the Partner ACS. The oONLY thing that would be close to what you want is Remote Call Forward.
As long as you have a Partner ACS release 6 or higher,
You need to set the permissions on a phone, then set that phone to forward out to teh external number. Then when calls come in, you transfer to that phone, which will forward to a cell or external number....boom, done!
Thats it though.
Oct 14, 2010 | Avaya Corded Phone avaparp18d
Can I divert calls from this phone to another phone? Thanks MArk David
  • Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
  • Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
  • Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
  • Switch on the "Call Forwarding" slider. The default position is off.
  • Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
  • Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
  • Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
  • Oct 08, 2010 | Panasonic Cell Phones
    Voicemail is not picking up for incoming calls...
    Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
    May 26, 2010 | NorStar Startalk Flash 2 Phone
    Does the meridian m7310 phone come with call forwarding capability within it's software?
    Yes you can forward an extension. But there are security settings to change to allow calls to forward out to a cell or something.
    Nov 05, 2009 | NorStar Meridian M7310 Phone
    All your out in coming calls have been forwarded need to deactive
    you will deactivate right from the call setting.
    Jul 15, 2009 | Lands Phones
    How do I forward call on my blackberry?
    Open BlackBerry Call Forwarding Options
    To access your BlackBerry call forwarding options screen, click the green Send key and then open the menu options by clicking the BlackBerry Menu key. Scroll down and select Options.
    You'll then be presented with a list of your BlackBerry's Phone Options, which include Call Forwarding. Click on this option and wait a few seconds for the call forwarding screen to populate.
    Enter a New BlackBerry Call Forwarding Phone Number
    Before you can forward incoming calls via BlackBerry, you first need to enter the number you want calls to be forwarded to.
    On the main Call Forwarding options screen, click your BlackBerry Menu key and choose New Number. A dialogue box will then appear asking for the number to which your calls will be forwarded. Type in the 10 digits and click the trackball to save the number.
    If you mistyped the new call forwarding number and you need to correct it you can click the BlackBerry Menu key on the main call forwarding screen, choose Edit Number, scroll to the number you wish to modify, click the trackball again and choose Edit from the available options. From there, you can make your desired corrections. To save the changes, simply click the trackball one more time. You'll then be returned to the Edit Forwarding Numbers screen. You can reach the main Call Forwarding option screen by clicking the BlackBerry Escape key once.
    Enable BlackBerry Call Forwarding, Tweak Settings
    On the main BlackBerry Call Forwarding screen, you have two options for call forwarding: 1) Forward All CallsForward Unanswered Calls. Below the latter option, you have three more choices: A) If Busy; B) If No Reply; and C) If Not Reachable.
    By default, your device is set to Forward Unanswered Calls to your carrier's voice mail box in all instances.
    BlackBerry Forward Unanswered Call Options
    Forwarding every call that comes in to your device is simple; you just fill in the circle next to Forward All Calls and then specify the number to which you wish to direct calls from the corresponding drop-down menu. To save any changes you make, click the BlackBerry Escape key and confirm the changes when prompted.
    Forwarding calls in specific situations is a bit different, but it's no more difficult. The first thing you want to do is ensure that the circle next to Forward Unanswered Calls is filled in. (Again, this circle will be filled by default unless you modified your settings.)
    To forward only the calls that come in while you're already on the line, click on the If Busy option to open the drop-down menu and then choose the number to which you want to forward your BlackBerry calls. If that's the only call forwarding option you wish to modify, click the BlackBerry Escape key and confirm the change when prompted.
    If you want to forward calls that come in while you're, say, in another room and away from the phone, change the number associated with the If No Reply option and save your changes.
    If you want to receive calls when your BlackBerry is turned off or you're otherwise unreachable, modify the number settings next to the If Not Reachable option and again save your changes.
    When BlackBerry call forwarding is enabled, you'll see a small icon, which looks very much like the missed call icon, appear on your BlackBerry home screen.
    Finally, if you wish to return to your device's default settings, simply fill in the circle next to the Forward Unanswered Calls option and set the number for all three options (If Busy, If No Reply and If Not Reachable) to your wireless carrier's voice mail digits.
    May 11, 2009 | Google Android
    Call Forward not working
    Sounds like an IPK2. try just entering the forward destination in the first 2 fields. Why would the person being forwarded need calls? If you are forwarding his phone he can't receive calls. unless your just forwarding to vmail. cheaper rates at ldtsnj.com
    Mar 19, 2009 | NEC Electra Elite 32D-1 Corded Phone
    NEC Dterm DTP 16D-1 Corded Phone Logo
    136 people viewed this question
    Top NEC Lands Phones Experts
    Brian LaDuca
    george  peters
    george peters
    Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
