Question about RCA P60921 60" Rear Projection Television
RCA 60" projection tv Turns on and starts flipping channels by it self
I have an RCA 60" Proj TV # P60924, it turns on and starts flipping channels by it self, it will not respond to the remote control. i can unplug it for a day plug it in it works fine for about 1/2 hour then starts doing the same thing again
  • Anonymous Mar 15, 2014
    RCA P52937SG my tv flips channels and won't stick to any one with use of the remote or the buttons on the tv itself, (it doesn't have guide plus marked on the outside of the TV anywherer) Simply put I can turn it on via remote (most times) or via the panel on the TV it starts Blipping on/off every say second and won't respond to the remote or (most times the control panel on the front of the TV) Next it starts flipping channels like it's looking for a signal meanwhile I'm constantly hitting the menu button and the channel up or down and there's no response. When i finally get the TV to a channel where I have cable box picture and hit menu at the same time (by the grace of god) it will show the menu (sometimes it will just scroll up and I can do nothing) sometimes I can go thru the set up and tell it cable and channel input 1 or whatever and it resets and is fine for a moment then it turns on recognizes the cable box channel and it starts comming in and out every second or so then it goes to flipping again. And Yes I have unplugged it for a bit and powered it back up again and still the longest it runs without interruption is a few hours? any ideas?
    Problem Solver:
  • 6 Answers
Replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
Posted on Jul 28, 2007
My rca tv turns off and on by itself
Is there a prankster nearby thast has a remote tuned to your set? As a young lad I used to play this trick on my neighbors daughter.
You should also investigate whether it is timed.. that is has a regular interval or time that it does happen. It could be another appliancwe doing this A/C ,Security system or some other eklectronic device. The dog has the remote under the cushion?
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | RCA P52960 52" Rear Projection Television
Tv turns on but no picture but has sound and menu
55" rca projection tv turns on has sound but no picture
Feb 11, 2010 | RCA Televison & Video
52 RCA REAR PROJ. TV WONT TURN ON.
The problem will be the deflection board (left hand side board when looking from back of unit.Part number is 258762 is no longer avaible thru rca but you can contact tristate module or pts electronics-you can even google the part number
Sep 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No audio...only static
This is caused by a corrupted signal being sent out by one of the stations you are watching. There is definitely NO PERMANENT SOLUTION to this problem. Just keep unplugging the TV.
May 13, 2009 | RCA P60921 60" Rear Projection Television
My sournd sound turns on then turns off can any one help
so is this sound on the tv or a sound system
May 03, 2009 | RCA F32649 32" TV
The tv turns channel by it self
hello are you sure 1 of the channel button is not jammed in
shaun
Apr 08, 2009 | RCA R52WH73 Projection Television
Tv turns off by it self
Ours 60" (60P8342) turns off after a short period of time also. My husband researched it online. The cheap solution he was told to try is to unplug the TV (or plug into power strip and switch off) when you are done watching it. A computer board inside over heats and it's a protection mechanism for it to turn off. Otherwise, it's over $100 to fix the computer board.
May 29, 2008 | Philips 60P8342 60" Rear Projection...
60" RCA PROJECTION TV
my tv is 12 yrs old it started with the color starting to fade and then it started cracklin real bad and now theres no pic but there is sound
Dec 29, 2007 | RCA P60921 60" Rear Projection Television
RCA P60921 60" Rear Projection Television Logo
219 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
