Question about Toshiba VGA Board Graphic Card
External monitor connection problem
I've got a Toshiba laptop; Satelite A105 that is 2 yrs old to be exact. The connection to the external monitor is experiencing intermittent connection problems. When I jiggle the VGA cable where it plugs into the laptop I can get it to connect and stay on but if I move anything it drops signal again. Same problem persists after I put in a new VGA cable.
What is the fasest, cheapest way to determine where the problem and fix it?
KwW
  • kevinwaynewh Jan 30, 2009
    Ok, thank you very much for input. KwW
  • 24 Answers
If you are comfortable with opening your case up you need to follow wiring from plug to system board checking proper connection to the board. If not comfortable or connections are ok then a local computer shop is your best bet.
Posted on Jan 30, 2009
Toshiba Satellite A505 - Most of the time when I turn it on the screen is grey, with no text.
This sounds like a bad display on the laptop. Hook up an external monitor to the vga port on the laptop. You may need to toggle the display to output to the external monitor. This is generally accomplished by pressing the "FN" key + one of the F# keys. Look for an icon that resembles a monitor or it may say LCD. If the graphics display correctly on the external monitor, then you will need to replace the computer screen.
Dec 29, 2012 | Toshiba Computers & Internet
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
Toshiba Satelite 105 4134 Major Resolution Problems
Sounds like your screen is going bad. It's either the screen or the video card inside of the computer, but most likely it's the lcd screen. Try connecting an external monitor to the laptop. You can Borrow a monitor from a neighbor, friend, relative or co-worker to connect to the laptop.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the external monitor displays correctly that proves your video card is ok and your lcd screen is bad. If the external monitor displays the same as your lcd screen then your video card has a problem. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 23, 2012 | Computers & Internet
Screen is blank (no video), even when connected to to an external monitor. I presume at this point that it's a problem with the on-board graphics processor. Notebook appears to power-up normally. Notebook...
will video work when first booting?? try to start in safe mode then if you have restore disk or applications disk remove the display video in hardware manager, sometimes the drivers get corrupted, thei may re-install video drivers. al so you might go into bios and check for setup defaults hope this works. have had similar situations on diffirerent systems. some laptops have a Fn key Function key so when you have external monitor up to system it switched=s from laptop monitor to external little picture on keys usually on or near function keys.
Dec 29, 2009 | Toshiba Satellite M35X-S311 Notebook
Viewsonic monitor lcd to laptop problem
Remove the second monitor entry in Device Manager, and let the machine try to find the driver. I swear, sometimes, computers have minds of their own! ??
Apr 04, 2017 | Computers & Internet
Toshiba laptop satelite a135-s2386. I went to turn on computer and there is power but the screen is black. Thanks!
connect an external monitor on the unit and press the key combination to get the video on an  external monitor this is different on some laptops on HP dv 6000 for example it is FN F4 if external monitor work the problem is with your laptop display if the external monitor doesn't work its probebly your systemboard als check your memory.
May 04, 2009 | Computers & Internet
Karaoke
hi, you can connect a video monitor or beam your laptop with the external VGA output fn + f5 and you can select the preferred output, but everything you do on the laptop, will appear in another screen
Mar 13, 2009 | Toshiba Satellite A215-S4747 Notebook
The problem is with the laptop. The femal VGA port is slodered to the motherboard. Once the laptop's MB has been removed you'll most likely find the solder holding the VGA in place is most likely cracked/loose. The fix would be to remove the old solider & apply new.
I can't guide you through disemble, its complex. I can include a site to help you with this.
http://www.laptopka.com/2006/03/18/removing-laptop-motherboard/
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
If you find this all a little too involved it might be worth taking it to a pro.
At this link you can order A105 parts if needed.
http://www.sparepartswarehouse.com/Toshiba,Satellite,A105,PSAA2U-01T018,Laptop,Parts.aspx
I hope this helps you kevinwaynewh!
Mike
Jan 29, 2009 | Toshiba VGA Board Graphic Card
Computers & Internet Logo
131 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
