Question about Pentax Optio S5i Digital Camera
Replaced LCD but no image appears
So a while back my lcd screen cracked (accident). i made due for a while until my gf talked me into replacing the lcd screen. i ordered the part from pentax and took a gillion screws out of the camera to get down to the screen mounts. turns out there are two connections between the screen and the camera, (1) a wire that has to be soldered (i guess this is a power supply) and (2) a ribbon cable that has to be clamped into place (i guess this is the video feed). so i took the old screen out, soldered the wire to the new screen and tried to get the ribbon cable in place. thats where i think the problem lies. i have the ribbon cable in, but i don't think all the way. i put the camera back together, power it on, screen turns on (i have power), but no image at all (before there was a messed up crystalized image). i can still take pictures, i just can't review them. any ideas? i think the ribbon cable is my issue, any tips on how to get it in the clamp? the close quarters really made this hard. thank you in advance.
  • Chris Gwinner Jul 27, 2007
    i do remember unclamping the cable instead of just pulling it out. its been a while so i dont remember if its over or underneath? i guess its time open it up and try again.
Ok, having had the same problem as yourself, I can tell you that when looking at the lcd, the ribbon cable on the bottom left hand side stays flat and plugs into the light blue clamp (that is hinged and lifts up) the ribbon cables copper contacts face down onto the bed of copper contacts exposed when the blue clamp is opened. Hope this helps.
Posted on Sep 02, 2007
    President:
  • 1,114 Answers
There are several different types of flex cable clamp arrangement. In some the clamp goes over the cable and others underneath, it is easy to forget which way the cable went! So check how the cable is seated and look carefully at the connector. Often if the cable goes over the clamp it will be grooved. Also when you removed the cable did you slide the clamp out or just pull the cable? It may be that the clamp is actually preventing the cable from being replaced. I use a pair of fine nosed tweezers to push on both ends of the clamp to release it. CAUTION! the clamps are very fragile and once broke virtually impossible to repair.
Posted on Jul 27, 2007
SOURCE:
My samsung r20 backlight keeps going off, if i press the Fn and F5 button it comes on for a second and then back off
If you can see the images on the screen very faintly when you shine a flashlight on the screen, then your problem more than likely is the LCD Inverter. The LCD Inverter costs less than $10, but you will have to disassemble the lcd screen to get to it.
I'm sure you know that you can attach an external monitor to your laptop and hit the FN key and hold it while you hit the correct F1 thru F8 key that will display the image on the external monitor? This could be a solution until you get the inverter fixed.
Now a dishonest repairman will take advantage of you if you take that laptop to them talking about the backlight is going bad. He'll simply bill you $300 and tell you he had to replace the LCD Screen which houses the back light an most times it's easier to replace the screen then fool with the backlight. And in your case all he would do is replace the lcd inverter that sits under the lcd screen and is covered by the strip at the bottom that goes around the lcd screen.
Mar 20, 2012 | Computers & Internet
SONY DSC T33 SCREEN STOPPING SHOWING. CLICK SONY DSC T33 SCREEN STOPPING SHOWING. CLICK BUTTON,FLASH WORKS AND IT APPEARS TO TAKE A PHOTO BUT NOTHING SHOWS. ALL ISONY DSC T33 SCREEN STOPPING SHOWING. CLICK...
This is due to failure of ccd imager chip in your camera, replace ccd imager chip to get live view in lcd to take fresh pictures.
Let me know if you need ccd imager chip part number.
Sep 28, 2010 | Sony Cyber-Shot DSC-T33 Digital Camera
Part of the screen is cracked, the image is as well, Im in Miami how much will that be to be repaired
UNFORTUNATELY THIS FAULT CANT BE REPAIRED THE WHOLE LCD SCREEN NEEDS TO BE REPLACED CONTACT YOUR HOUSE AND CONTENT INSURANCE COMPANY IF IT BROKEN BY ACCIDENT THEY WILL COVER IT.
Sep 07, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
The Monitor screen doesn't work when I want to take a photo, I can only see picture through eye piece.
If your screen works in playback mode, the screen and flexible circuit boards are intact. To shoot an image using the LCD screen you must first activate the "live view" function in the setup menu, and then press the live view (Lv) button to view your image on the LCD.
Nov 05, 2009 | Nikon D90 Digital Camera with 18-105mm...
Lcd monitor
Is the LCD monitor broken with a cracked screen or is it just not displaying an image?
If the screen is cracked then it needs to be replaced.
If there is no image on the screen and it is not physically broken then the fault could be an inverter problem or a faulty CCFL lamp.
For service, parts and DIY info on LCD screens check out LCD Parts, click on this link to their WEB site : -
www.lcdparts.net
Oct 05, 2009 | Sony Computers & Internet
Replacement LCD Screen does not work
Hi there
The best way to determine if its the inverter thats burned out is to look very closely at the screen, if you can see a very faint image then its the inverter which has blown or the connection has worked loose.
Post back with the results please.
Good luck
Feb 18, 2009 | HP Pavilion dv5220 Notebook
Screen Problems with my Laptop
hi dear
1. That can be connection related problem. I check connection between the video cable and the LCD screen, try reconnecting the video cable. It’s necessary to take apart the display panel, unplug the video cable from the connector on the back side of the LCD screen and then plug it back in. In some cases reseating this connection helps. 2. If reconnecting the video cable doesn’t help, here’s what I do in this case. While the display panel is still disassembled, I turn on the laptop and wait until image appears on the screen. Then I move the video cable a little bit without touching the LCD screen. If moving/touching the video cable affects image on the screen, it’s possible that there is a problem with the cable. Apparently there’s a short somewhere inside the cable. In this case, replacing the video cable may fix the problem.
3. If reconnection the cable doesn’t help and moving/touching the cable doesn’t change image at all and the only way to get better picture is moving/touching the LCD screen itself, apparently there is a problem with the LCD and it has to be replaced.
oke
Posted by Laptop Freak on March 22nd, 2008 Filed in Video Problems, LCD Screen Issues, LCD Displays Lines -->
Mar 24, 2008 | Compaq Presario 700 470024-192 Notebook
CRACK LCD TV SCREEN
Take a look on amazon. here Amazon com lcd tv replacement screens. I hope I have Helped. Cheers
Feb 09, 2008 | Mintek DTV-263 26 in. LCD Television
Vertical line on LCD screen
hi unfortunately you'll have to replace the lcd display
Aug 09, 2007 | HP Compaq nc6000 Notebook
Pentax Optio S5i Digital Camera Logo
44 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
