Question about Acer Aspire 5100 Notebook
MY acer aspire one has an icon that stays on my screen it says new item this item has not yet been configurated my icons on the bottom left of my screen which shows batt, connection,and power does on show when i turn on my note book
No volume icon where can i find it? it is not at the bottom of screen
right-click on the bottom right of screen, left-click Properties, then left-click Notification Area Tab, at bottom of tab you will see System Icons , just Check Volume box and then hit Apply
Sep 27, 2012 | Acer Aspire One Netbook 8.9" Notebook
Where is mute on my acer computer
Hello and welcome to FixYa,
there are a couple of ways you can do this,
If you have windows
On the bottom right at the end of your screen, there is usually what looks like a 'speaker' icon
if you left click on that icon; you will see another speaker in an elongated popup that lets you adjust sound.
If you want to mute, left click on the speaker you see at the bottom of that box.
You can also go to your start menu, left click it;
left click control panel;
left click hardware and sound;
left click adjust system volume;
left click the 'speaker' icon under device (speakers and headphones)
It will mute the computer.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
May 29, 2011 | Acer Aspire 6930-6771 Laptop
Acer aspire one
Try to configure your audio settings. Usually on the bottom right of your PC there is a sound icon. Click on it and configure your mic volume.
Mar 08, 2010 | Acer Aspire One A150-1006 Notebook
How do I download Acer Aspire x 1301 owners manual
Have you tried to download it from Acer Support?
This is Acer Support, and the download page for Guides and Manuals, for the Aspire x1300 series of desktop computers,
http://support.acer.com/acerpanam/desktop/2009/acer/aspire/AspireX1300/AspireX1300ul.shtml
The Acer Aspire X1300 User's Guide is the first file listed.
This file is a PDF file. The computer you are using has Adobe Reader on it, which uses PDF files.
After you left-click on - Acer Aspire X1300 User's Guide, you may not see anything happening for a few seconds.
The PDF file is downloading in the background.
Should you wish to save this PDF file to your computer, left-click on the Floppy Disk icon in the top header of the file.
(This way you can burn a copy off to a CD disk for safekeeping, and can also delete the file off of your computer, so that you will have more harddrive space)
The Floppy Disk icon is the second icon from the left, in the top header.
If you hover your mouse icon over the Floppy Disk icon, it will briefly reveal,
'Click to save this to your computer or another location'
After you have clicked on the Floppy Disk icon, a small window will come up.
Save a copy...
At the bottom of the Save a copy window is a box with - File name:
The name of the file is -
UM_ACER_1_0_EN_X1300_X1301
Go down to the bottom right of the Save a copy window, and left-click on - Save.
If you have your downloads set to save to your My Documents folder (Documents for Vista) this file will go there.
If you do Not have your documents set to save to your My Documents folder, this file will go to your desktop screen.
When you see the file name, Double-click on it to open it.
(Note* There is also a separate folder in My Documents. Downloads. The file may may be downloaded to the Downloads folder.
If you have trouble downloading this file, come back, and let me know, or if you have any additional questions about this.
Simply state so in a Comment.
Feb 17, 2010 | Acer Computer AX1301U1302 Desktop PC...
How do i use wifi on my new acer laptop?
press and hold fn key and tap 1 i think it is if not its the key that has the 3 or 4 ) in various sizes to activate/deactivate u will then have to put the settings in by left clicking the flashing icon in bottom right hand corner of screen
Jan 01, 2010 | Acer Aspire 5610-4648 Notebook
Acer Aspire One, online connection is ok but No
Microsoft changed its log-in protocols since the Aspire One was released and the version of Messenger installed is unable to connect to the Microsoft servers.
You can get to the Live Update function by clicking on the settings icon from the home page (bottom right of your screen) you will bring up the settings window (obviously). Inside here, you will see the Live update icon (mine’s on the bottom left next to Touchpad).
1. Make sure you’re connected to the Internet.
2. Click on the Live Update icon.
3. Click on “Update” and if there are any updates, they will be listed and you have the opportunity to install them all.
4. Click on Install and your Aspire One will automatically download and install the updates for your netbook.
Oct 19, 2009 | Acer Aspire One PC Notebook
I have an Acer Netbook, Aspire one series. the icon for wireless doesn't appear at the bottom of the screen for me to choose my wireless network and in setting the network centre won't open HELP
It sounds like you do not have the connection set up yet.
Try using the start button (bottom left hand corner of your screen)
Then click connect to, then click show all connections which will open the network connections panel.
Then you can configure the wireless setting (If you have one) if not, then try creating a new connection and follow the wizard, Hope this helps you, Chris
Nov 09, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
81 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
