Question about Toshiba SD-P1900 Portable DVD Player
Toshiba Portable DVD player, SD-P1900SN. No matter what I try, even the suggested fixes on here, I continue to get a "no valid disc" message.
  • 135 Answers
SOURCE: Unlock - DVD player -TOSHIBA model SD-P91SKN
Go to; www.videohelp.com input your make and model, hit search, scroll down, look to right of screen for 'Hacks" that is what you are after.
Posted on Jun 27, 2008
humbletech
  • 31 Answers
SOURCE: portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Posted on Dec 03, 2008
stonephoenix
  • 563 Answers
SOURCE: No valid disc message displayed. Disc is spinning.
When a DVD player starts doing that, it either needs to be cleaned, or something is going wrong with the DVD mechanism inside of it. You can purchase DVD lens cleaner from any large retail store that has an electronics section. However, if you clean it and the problem persists, it will likely be cheaper to replace the unit rather than trying to have it repaired unless you're under warranty in which case any repair or exchange will be covered by said warranty. If you call the manufacturer they will give you your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
BobbyR1234
  • 173 Answers
SOURCE: Toshiba Portable DVD will not spin upon start up
If the disc does not spin it will cause the optical reader to not read the disc, which will give you the "no disc" or "invalid disc" error. If a disc will not spin, the most common cause of this is due to a spindle motor malfunction. The good news is that it can be fixed on average of between $70-90 dollars depending on what service repair technicians charge in your local area. You can fix the problem yourself if you have the patience and a bit of knowledge, but I can tell you from first hand experience it is a pain to do this.
The pictures below provide you an idea of what you are looking at.
I hope this helps give you an idea of what the problem is and helps you solve the issue.
If you would not mind, please rate my help. I would greatly appreciate it. Thank you.
Posted on Feb 07, 2010
  • 3 Answers
SOURCE: Have Toshiba SD-P91S dvd player.
EXACT same problem here. All discs invalid. 1 second of disc motion and then nothing. Have barely used the device.
Posted on May 08, 2010
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
On my toshiba sd-p1900sn player which has hardly any hours the screen will not illuminate but sound works and it plays music only well. this is my second player. i hate to switch to another model because...
you have a broken connection between the player and the screen. its a flat cable and need to be replace.
if your handy, buy one at the shop and replace it yourself.
Aug 26, 2010 | Toshiba SD-P1900 Portable DVD Player
SD-P1900SN After inserting movie DVD, I get message, "No Valid Disc". I ensure disc is inserted properly. Bought player a couple of years ago. Have only used it 3 times. Can't find anything in manual...
Check for cracks or scratches on the dvd disc?It a dvd movie disc,not a computer program dvd disc?Take the dvd disc,washes it with some dish washing soap.To clean all the grims and grease out of the dvd disc laser surface to the dvd player laser eye to read the dvd disc.
Jun 17, 2010 | Toshiba SD-P1900 Portable DVD Player
Feb 06, 2010 | Toshiba SD-P1900 Portable DVD Player
No valid DVD displays on my Toshiba SD-P1850
Most portable dvd players will not read burned dvd/cds. Please be sure to use originals in your dvd player. If you have a user's manual it should tell you if your player reads CDR's or DVD/RWs
Aug 07, 2009 | GPX PDL805 Portable DVD Player
No Valid Disc
I had tried cleaning the lens like most solutions said to do, with no luck. I tried what user gthumm said he/she tried, which was taking off the back of the player. Their problem was the white wheel (motor) and the next wheel (black) were not turning smoothly. He/she pushed the white wheel down until it snapped back in, allowing the wheels to turn. I tried it twice and finally, I have a working portable dvd player again! Yeah! Thank you so much gthumm and fix ya team! My kids especially thank you! You are the BEST!
Dec 06, 2008 | Car Audio & Video
No Valid Disc
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
Jul 25, 2008 | Durabrand Portable DVD
No Valid Disc
Try this out; Go to your DVD player's settings/setup menu, find the "Disc Lock", set it to "off" if it is already set to "on"
Apr 16, 2007 | Durabrand PVS1966 Portable DVD Player
Toshiba SD-P1900 Portable DVD Player Logo
223 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
