Honeywell T8400B Thermostat Display Intermittently Blank
Two of the 4 thermostats in our house (for water circulating radiant heat) have on occasion had blank screens for several hours, then spontaneously came back on. Turning them off and on or changing the temperature had no effect. Is this a known problem> Should they be replaced?
I have the same problem. It's because your domestic hot water (dhw) is on the same system as your radiant heat. In these systems, dhw is given priority over floor heating. That is, when your dhw needs heat, power to your Tstats are shut off until your dhw is satisfied. (Makes sense: cold showers no fun) Your T8400B's have no battery, so they are dead unitl power to them is restored by your zone control. It's really stupid that they use these Tstats, because you can't even SEE your room temp or settings let alone change them. I will be replacing my Tstats with battery powered soon; hopefully that will allow me to see and adjust during dhw cycles.
Posted on Nov 07, 2009
  • 52 Answers
Most likely a bad tstat i would replace I recommend honeywell focus pro 6000
Posted on Aug 29, 2009
I have 2 wires coming from the wall, 1 white and 1 blue and want to wire a new honeywell 5-1-1 day programmable thermostat.
likely one wire to TH, the other to W if the thermostat operates on batteries. If the thermostat requires a 24 volt power source it is not compatible with your system.
Oct 09, 2017 | Honeywell Heating & Cooling
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
3 year old Lennox system stops intermittently 2-3times past 24hrs
i would have the thermostat receiving 24 volts all the time by running the c terminal from the air handler to the thermostat and go from there
Jun 21, 2009 | Honeywell Heating & Cooling
Chronotherm III Thermostat Completely Blank Screen, No Heat
One of two things either the disply has gone out which is likely as it is a common failure for that thermostat or your heating unit is not sending control power. the older chronotherms were system (24volt ac) powered the new hardware/box store units are battery powered. Either way display should not be blank with fresh batteries. to get heat on remove the thermostat jumper or twist together the wire from the R terminal with the wire from the W terminal. note the color of each wire for later reference, heat up house disconnect wires from each other and go purchase a new thermostat
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
T8411r1028 honeywell thermostat
Check in the heating unit itself for an automotive style fuse.
Heating & Cooling Logo
553 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
