Question about Olympia OL3000 InfoGlobe Phone
Start up instructions for soft tubs
Can't find instructions.
  • 547 Answers
Contact soft tub in sudbury ontario canada
Posted on Feb 11, 2009
There is a spot almost in the middle of the tub that is softer than the area around it. I am very concerned that there is water damage that we are unaware of. Are soft spots common?
With some manufactures yes. If you can get to the area from under the tub drill some small holes through the flooring and use a stop collar on the drill bit so you don't drill into the tub the put some expanding foam in the holes so it fills the area between the tub bottom and the floor to give the tub bottom some support.
The tub should have been set in cement mortar to prevent this from happening but that
Feb 07, 2011 | Home
My wife and I recently upgrade our tub w/ your Roman Tub with the Soft Touch Personal Shower Head. We have complaint to the Commniuty Supply; where we had purchased it regarding it doesn't work as they...
oh yeah take it back and tell them its not user friendly and your atty will be mailing them papers if a prompt refund is handed to you now don't let them push you around remind them you are the customer you are always right got it now go get your refund
Mar 04, 2017 | Danze D302521 Antioch Roman Tub Faucet...
Water keeps filling in tub
there is a tube that goes from the side of the tub to the water height valve inside the control panel. make sure it is still attached, has no holes in it. blow through the tub side of the hose and, listen for a soft click from the valve; no click replace the valve.
Aug 09, 2010 | Kenmore 24032\24036 Top Load Washer
Water coming out of soap tray
there is a blockage in the the rubber tub tube probally old soap build up, turn power of remove lid and youll see a black tube going from soap dispenser area to the tub, squueze that and you should feel a gooey soft blockage keep squeezing and push it towards tub and that should clear it. hope this helps u
May 17, 2010 | Electrolux Washing Machines
Vbsr3100dawn washer water leaking between tub hotpoint
Hi, there is a tub seal (WH02X10032) that can be replaced, however, the tub nut generally requires the GE tool to remove. The nut is hex shaped, but is made of a pretty soft alloy so it can break if you use a regular wrench. Once the tub is out, you may also find that you need a new tub nut and split ring.
Apr 20, 2010 | Hotpoint VBSR3100D Top Load Washer
Soft drop door mechanism came undone The soft drop door tub wheel
It's held in place by a soft drop nut (99002192). If damaged, the tub wheel part number is (99002183), and the soft drop bolt is (99002189).
May 02, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
Dishwasher ''soft drop door'' mechanism came apart - door now drops
I had a similar issue as described by mc1bean. One day my Jenair dishwasher door just fell down. The right side spring was fine. The left side spring was still hooked into the door hinge but the cable was laying on the floor in 2 pieces. Over time it wore down and broke. I ordered just the soft drop cable. Now I could not find any installation instructions how to install the soft drop cable. After a few tries I think I got it right. Here are the instructions for hooking up the right side spring with the cable. The spring has to be hooked into the door hinge at the notch closer to the door. The end of the cable with the hook has to be hooked into the other side of the spring. The cable should lead from the bottom around the pulley up to the door hinge again. Now the other end of the cable has to be hung into the door hinge on the notch further away from the door. There is some slack, but it is not quite enough for the cable to get over the pulley when in rest position and undo itself.
I hope this helps others who have the same issue.
Feb 10, 2009 | Dishwashers
Rinse Cycle
Is this a fairly new Energy star machine? If it is the rinse cycle is a spin only cycle with several spray rinses.
You may have an option switch that gives you a Fabric softener option, use this option and you will have a deep tub cold water rinse.
Make sure you are using He detergent.
If you have soft water use less detergent
Let me know if you have further questions.
Your sales rep should have told you this!
May 04, 2008 | GE WBSR3140DW Top Load Washer
Lands Phones Logo
365 people viewed this question
Top Olympia Lands Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
