Question about Quantum SuperLoader 3 LTO-3 Tape Drive
Tape stuck in drive
I put a tape into the magazine yesterday afternoon. The tape backup from last night failed with error message 'e00084ed - A hardware error occurred.' Using a flashlight I can see the tape in the actual drive but don't know how to tell the drive to eject it.
I have cycled power on the drive and performed a 'drive unlock'.
Can you help?
  • Steve Gilbertson
    Steve Gilbertson May 11, 2010
    what type of tape drive do you have?
  • 25 Answers
I tried many things; ended up taking off the top plate (a bunch of small torque screws and four larger ones--used the torque wrenches that came with the unit; hmmm, why would they supply that?), then manually got the tape out (pushing, pulling, rotating), and then ejected both magazines and inserted the blanks, fired up the autoloader and let it calibrate; but note: first time trying out a tape, got a different error about tape jam (or something like that), so manually rotated the picker to one extreme and the metal pusher/puller thingy in that picker, then rebooted the autoloader and this time after calibrating, back to business!
Posted on Feb 07, 2011
  • 3 Answers
What usually happens is that the device gets out of calibration with the picker. To solve this, remove all tapes from the magazine(s) and put the magaize(s) back in. Next power down the unit and remove the power cord for about 15 secs to disrupt power. Plug back in and power up. When it comes up it will go through a calibration. When it is Idle, if the tape is still in the drive, you can use the move command to move it to a slot. Unfortunately, if this is a reoccurring problem with multiple 2B errors and then a communication error with the device going offline and no longer available in device manager, the chassis will need replaced. I have had to replace everyone that my clients have had, some more than once, due to this. This and their horrid customer support is why we no longer sell Quantum.
Posted on Mar 22, 2010
    Problem Solver:
  • 16 Answers
The best way that I have solved this is by using the move commands from the drive, and move it from drive to any free tape slot. Also if that does not work, put a few tapes in the drive and perform the random moves test in diagnostics, that will fool the drive to move the tape.
Posted on Jul 20, 2009
We are having an issue with our backups. The system event log says there is an error 7 and lists the tape drive as having a bad block. However the quantum diagnostic tool shows the drive to be healthy. ...
Event ID-7 is a "Bad Block" on the Tape being using. By design, when a Bad Block is encounter, the Tape Drive "Seizes the Tape" and goes offline. It can sometimes be difficult to get the Tape Drive to release the Tape. Refer to the Users Manual for instrcutions on how to Reset the Tape Drive. Sometimes applying the Firmware Update willl reset the Tape Drive and Eject the Tape.
Do not assume the Tape is Bad, but do not re-use until tested. The Tape may be Bad, the Tape Drive may simply need Cleaning or the Tape Drive may be Worn or Damaged. If you are using 3rd Party Backup Software, such as Backup Exec or Yosemite, you wan want to check the Removable Storage Servcie to see if it is set to Manual or Automatic. Any Tape Devices would need to be first Deleted in the Library Section of Removable Storage, then Sop and Disable Removable Storage. Since Removable Storage is in effect NTBACKUP, this Service can interfere with the Operation of your Backup Software and generate "Bad Block" Errors.
To Test the Tape with your Quantum Tape Drive, use a tool called XTALK ( xTalk- ) that is found on Quantums Website
You may run a write_read_full Test on the Tape. Be sure to Clean the Tape Drive first. If it fails the Tape, try it with a 2nd Tape, If it fails again, suspect the Tape Drive.
Oct 04, 2010 | Quantum DLT-V4 DLT Tape Drive
I can't remove the left magazine from a Superloader 3. The unit has failed and I need to remove the tapes. The eject magazine does not work, it doesn't pull the drive gear back.
I found this solution on line and it worked for me. Believe it or not I used a butter knife and stuck it between the magazine and mail slot close to the bottom. You will hear a click and the magazine will pop out. It is like using a paperclip for a stuck CD. Make sure you power the device down and unplug it.
Oct 01, 2010 | Quantum SuperLoader 3 LTO-3 Tape Drive
Elem Table Bad (2B) error
The element error usually points to the drive, the best thing is to do is run the full diagnostics for the drive, and see what other hardware codes you receive, if it still points to 2b, then it is either the drive or the solenoid of the magazine failing. If you have a two magazine setup, just reverse the other magazine and test it that way.
Apr 16, 2009 | Quantum SuperLoader 3 LTO-3 Tape Drive
No Compatible media found in HP Tape Drive
Try a brand new tape fresh out the wrapper.
If that doesnt work make sure you are using the right drive in your backup software!
It sounds like a message often seen in windows backup where you have selected the wrong tape drive from the list and it just tells you "No compatible media found" when actually the drive listed isnt even connected to your system still
Nov 27, 2008 | HP StorageWorks Ultrium 448 LTO 2 Tape...
I get an error code A4 and 8A on the value loader LTO library.
I opened the library, removed all slots and put them back in with proper alignment. It's working now..
Nov 13, 2008 | Quantum ValueLoader SDLT 320 Super DLT...
Getting error message "Bad element"
you have to open the bottom and turn the motor or gears , just be sure to turn the cartridge gears too to wind the tape back in
Jan 18, 2008 | Quantum SuperLoader 3 LTO-3 Tape Drive
SONY TSL-S9000L error message
I need a little more information to better assist you with your problem. What Operating System are you running and how old is this unit?
Is this the first time you are using this device?
Also look at the event viewer for info on the actual error, which could help to better explain what the problem might be.
Nov 24, 2007 | Sony TSL S9000L (TSL-S9000L) DAT Tape...
Media is not inserted: tape backup
it's HPE day, why post to fixya for HPE , enterprise level products?
no pc stated
no sever stated.
no exact products stated,just symanted? what is that? ah Symantec tape backup software.version?
hp lto1 with scsi adapter
what model LT01. what model scsi adapter make and model.
hp makes vast versions of that drive
like (wild guess)
HP Q1515A
StorageWorks Ultrium 230 LTO 1 Tape Drive
try a new tape yet, be wise, no?
never own only 1 tape, and always have 1 spare new on shelf
of the tape runs via the scsi port, ok , all but the error works.
then it is not the scsi card .
tape first.
then get the drive rebuilt.
keep a spare drive on hand after all, is not backup a key function in any data center./? or small business, be ready?
Jan 10, 2018 | HP Computers & Internet
SONY LIB-81 Error on LCD screen - Drive Information 51
I think this sounds like the drive is having a issue loading and moving the tape in slot 1.
AIT units are known for having this kind of problem.
Try a cleaning tape and then a new tape fresh out the wrapper for a test backup.
if it fails with a known good tape then its time to send it out for repair
Jul 26, 2007 | Sony (LIB81A3BB) AIT-3 Tape Drive
40 GB Data backup cartridge keeps ejecting
When was the last time you cleaned out the tape drive. You could get errors like that if the drive is dirty! Regards, Armando
Apr 23, 2007 | Certance Travan 40 GB (stt3401a-sst)...
Quantum SuperLoader 3 LTO-3 Tape Drive Logo
3,542 people viewed this question
Top Quantum Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
