Question about Dell 966 All-In-One InkJet Printer
Faxes going to memory, won't print
I can copy and scan, but when faxes come in they go to memory, they don't print! At business, and nee them! Help!
  • 1 more comment
  • lorilong404 Jan 30, 2009
    Paper fine. Ink full. Past all of that.
  • jandctrans Feb 24, 2009
    faxes going to memery? Where is the memory? How do I get them? How do I make it stop doing that?
  • Anonymous May 15, 2009
    I have been trying to receive 3 faxes for a few days and the message keeps coming up "Fax Stored to Memory. I have no clue how to receive them. They are very important Faxes.
  • 2,120 Answers
Check paper, replace ink.
Posted on Jan 30, 2009
  • Leroy Elliott
    Leroy Elliott Jan 30, 2009
    have you tried unplugging the power cord for 10 seconds?
<Fax sending or copy operation in
Do one of the following:
- Press [Start] key to send or copy the
scanned pages.
- Press [Stop/Exit] key and wait until
the other operations in progress finish
and then try again.
- Clear the data from the memory.
<Printing operation in process>
- Reduce print resolution.
- Clear the faxes from the memory.
Apr 02, 2014 | Brother MFC 8950DW
I can't erase the faxes I already send
Hi There,
While not as popular as they were before the Internet became a principal means of business communication, fax machines are still an essential item in many offices. They are particularly useful on business documents when a signature is needed. Canon makes a number of fax machines that use both ink-jet and laser technology to receive and print documents. Most fax machines store incoming faxes in memory so you can reprint them, but occasionally the memory becomes full resulting in an error message. Your Canon fax machine's memory can be cleared quickly and easily so you can start using it again.
* Click the "Menu" button.
* Press the arrow buttons to scroll through the options on the screen. Select
"MEMORY REFERENCE" and click "Start/Copy."
* Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine's memory.
* Click "Stop" to finish.
Nov 27, 2011 | Canon Pixma MX410 All-In-One Printer
I have a Canon MX410 that scans, faxes, prints & copies. I need to know what to do to clear the fax memory. Thanks!
It's under printer options, format memory. You'll probably have to play with it a little because they like to hide the format option so you don't do it accidentally. Good luck! Please leave me a good rating, thanks! :)
Jul 27, 2011 | Office Equipment & Supplies
Brother FAX-8070P memory shows full and does not send all pages at one time?
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Jun 06, 2011 | Brother FAX-8070P Plain Paper Laser
Brother 8360p has faxes in memory but will not print them. All the faxes ar going into the memory now. It has paper and toner, check by making a copy. the menu 2 5 4 fax command doesn't do anything,...
I have seen a few Brother faxes do this. I fixed them by turning off the power, holding down the clear/stop button and keep holding it down while you turn the power back on. Keep holding it for a few seconds then release. This will clear what ever is in the memory that is locking up the memory print. Note: you will lose any received faxes in memory by using this procedure.
This may help you restore your fax to a operation condition.
Good Luck and Thank You for using Fixya.
Aug 19, 2010 | Brother FAX-8360P Plain Paper Laser
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Apr 20, 2009 | HP LaserJet 3050 All-In-One Printer
Cannot clear memory--NEED FOR WORK ASAP!!!!!!!!!!!
Out of Memory message
If the memory becomes full while you are making copies, the LCD
message will guide you through the next step.
If the Out of Memory message appears, press Stop/Exit to
cancel or Black Start or Color Start to copy the scanned pages.
You will need to clear some jobs from the memory before you can
To gain extra memory, you can turn off Fax Storage.
Print the faxes that are in the memory.
When you get an Out of Memory message, you may be able
to make copies if you first print incoming faxes in the memory to
restore the memory to 100%.
Apr 07, 2009 | Brother MFC 420CN All-In-One InkJet...
Won't print faxes
What printer are you using?
Mar 05, 2008 | Office Equipment & Supplies
Dell 966 All-In-One InkJet Printer Logo
192 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
