Question about Frigidaire FDE336RE Dryer
Dryer wont start
Dryer will not start when switch is turned
model fde336res2 when you push the start button it makes a cliking noise in the control board and dont start
  • dusty_white2 Jan 29, 2009
    where is the fuse
  • Anonymous Apr 14, 2009
    I have looked inside the back vent and see the wiring, the belt assembly and the motor, but no "thermal fuse". Where exactly is that?
  • 130 Answers
Its one of three things, check your thermal fuse on the back inside of the vent, the door switch or the start switch
Posted on Jan 29, 2009
Frigidaire model FDE336RES2 makes a squealing noise and won't turn with a full load in dryer.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Frigidaire Dryers
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
heatman101
Jun 27, 2011 | Dryers
Frigidaire dryer model FDE336RES2 won't run when you push the button. How to troubleshoot? I check power to unit and its OK. could it be the thermal limit part?
There can be many reasons why your dryer will not start orturn...
heatman101
Sep 21, 2010 | Frigidaire FDE336RE Dryer
My frigidaire heavy duty dryer model number FDE336RES2, starts to squeak once it turns on. It will continue to do this until it warms up then it stops. How do I fix this?
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does? SOME PICTURES
Sep 07, 2009 | Frigidaire FDE336RE Dryer
Frigidaire model # FDE336RES2 Wont turn on.
The fuse is located on the rear wall upper right hand corner. To get to it you must bust dat dryer down. HERES HOW
Jun 11, 2009 | Frigidaire FGR341AC Electric Dryer
When i push the start button it makes the noise it usually does but the dryer doesnt start. If you hold the start button it sounds like its putting electricity to the motor wont turn. Could it be as...
Hello, that sounds like a bad motor, you can know very quickly by unpluging the dryer, get to the back panel behind the switch. take one wire off the switch, grab your continuity checker, have someone push the switch, if it is good then its the motor. another way you can check is take the two wires for the switch and just touch them together if the dryer starts then it is the switch. Visit here for more help
Mark
Apr 14, 2009 | Kenmore Dryers
Loud thumping noise in Frigidaire model # FDE336RES2
You have to remove the top lid. Then remove the front panel. Then remove the belt and drum.
Your problem is a bad rear drum support assembly.
Remember to unplug the dryer.
Mar 27, 2009 | Frigidaire FGR341AC Electric Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer startup
motor is going out ,, repl/ check door switch is it in good shape should make cliking noise ,,,when good
Dec 28, 2008 | Dryers
Dryers Logo
328 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
