Question about Bazooka CS8A5 Car Subwoofer
Blew my Nakamichi Car SPeakers
I haven't installed speakers since I was a teenager... that was 20 years ago.. I pulled plastic stock speakers out of my toyotas rear deck... plastic speaker frames coming out of a metal rear deck.... The came out of the trunk.. not out of the top of the rear deck... So I tried to install my new Nakamichi 6.5" Coaxials the same way.. from the bottom instead of dropping them in the top... The new speakers have metal frames.. Well both went tinny and fuzzy within 15 minutes.. Did they need to be insulated from the metal rear deck or did they need to be dropped in from the top? I'm not sure where I went wrong... Mounted from the bottom the rubber gasket on the face of the speaker seemed to match up perfectly with the wholes in the metal rear deck. thanks for helping a old Noob...
  • dwight marshall
    dwight marshall Jul 27, 2007
    i know they are both 4 ohm speakers...
    So you don't think it's the way they were mounted to metal?
    I have installed a cheap pair of Sonys but used some cardboard as a gasket so the speakers don't touch the rear tray.. and they are still fine after 2 weeks...
    I would like to get better speakers.. but I dont want to just have them blow..
  • dwight marshall
    i checked them out on my home stereo and they sound like crap..
    can the speakers be saved?
    The stock speaker wires were hooked up to my Toyota stereo.. no amp...
    My question is ... did I kill the speakers by having the metal frame of the speaker touch the metal frame of the car?
    Because the new speakers I put in.. I made a cardboard gasket and they are still working.
  • 156 Answers
I don't think the problem was the metal basket touching the vehicle sheet metal. It's very, VERY common for speakers to be mounted directly to sheet metal. I think what you needed was a spacer, not so much an insulator. Usually when speakers are bottom-mounted, there's a thick gasket on the front that prevents the speaker cone from coming into contact with the mounting surface. Its only function is to increase the distance between the speaker cone and the metal. Your first speakers probably lacked the spacer, so the cone was pushed up against the metal and couldn't move. This is what ultimately caused the damage. Keep in mind that even with your cardboard insulators, there'd still be an electrical connection between the mounting deck and the speaker basket, because of the metal mounting screws.
Posted on Jul 30, 2007
    President:
  • 3,130 Answers
Take out the speakers and take an ohm meter and measure from both speaker connections on the speaker and see if there is an resistance or connections to the frame of the speakers. Next see how many ohms the original speakers where, and what these speakers are. If they are different, you may have blown the amp or the head unit. Good Luck
Posted on Jul 27, 2007
  • Larry  Dillon
    Larry Dillon Jul 27, 2007
    Have you had them checked out yet, as to the grounding to their metal frames? Are you using a separate pair of wires with no grounding and running directly to your amp?
  • Larry  Dillon
    Larry Dillon Jul 29, 2007
    You probably fried the voice coils on the speakers. As maybe they could not take as much power as you thought, but I highly doubt now that you have an issue with the grounding of the frames, unless like I asked you to check before, the resistance from the speaker terminals to the frame on the bad speakers.
SOURCE:
I was listening to in on full volume a few weeks ago (as I wanted to be able to hear it from the shower!) and it suddenly started making popping noises.
try using other speakers....the suspect is the speakers, maybe the cones are worn out....due to vibrations caused bu full volume
Oct 18, 2014 | Nakamichi Audio Players & Recorders
Want 2 remove stock speakers n install after market. Need 2 know how 2 remove stock speakers corectly
There are several sites that offer step by step procedures to remove stock speakers, for a small fee. Most replacements involve removing the door panel. I strongly recommend coughing up the minimal cost for these directions. You can replace your speakers, and if you sell your car, you can replace the stock speakers back where they go.
Jul 30, 2011 | Car Audio & Video
What system are my speakers? like a 2-way or 3-way?
Unless it came stock with a fancy stereo, I would venture they are one-way. I have never pulled a stock speaker out of any car which was more than just a plain jane speaker. It is 20 years old however and someone may have upgraded it over the years. Even if they did, 20 years of sound being played through them has worn them.
Nov 07, 2010 | 1990 Dodge Dakota
Cant get the front speakers to work. The stock tweeters work but the stock door speakers don't on a 95 honda prelude
if you have a bose system, then you have mini amps connected to each speaker, my suggestion would be to take the speakers out and look at them,
see if there is corrosion. or anything.
my other question is did you just install a new stereo in your car or did these speakers go out a while ago on your own?
Jan 02, 2010 | Kenwood KDC-BT742U
Left rear windshield speaker blew out in 1998 lincoln town car...play music fine, but when i turn on bass, HUGE thumping sound, i think its ripped. How can i go about replacing it myself? i believe that...
Hello nathan_ebay9,
Replacing speakers is definitely one of the easy DIY jobs in car audio. And rear deck speakers are the easiest of all. You can usually access them directly from the trunk and it's simply unhook the wires, remove the speakers, mount the new ones, and reattach the wires. Finished!
It's best to replace both in a paired set. The sound from different types of speakers will be different and they're usually sold as a pair anyway.
I'd recommend the Jensen's shown here. They will outperform most stock speakers and sound better too.
Hope this helps.
Oct 15, 2009 | OEM Systems Car Audio & Video
I installed a 475a to my door speakers and when i turn the power up on the amp my speakers make loud popping noise any idea on wat it could be
You blew the speakers. The speakers were probably not made for that much power and the voice coil blew. If they were stock speakers, then they are defenetly blown. Stock speakers are not made for much power at all, and will more than likely blow with any extra power given to them at all.
Sep 26, 2009 | Infinity 475A Car Audio Amplifier
After the recent purchase and professional installation of a used Nakamichi CD 700, I noticed my front speakers weren't working. Activating the fader adjust I noticed that when I turned the knob...
I would recommend taking it back to the pro that installed it given it hasn't been to long. Also the deck should be warrantied and if the front side is not working I would consider that a faulty head unit. I know Nakamichi head units are not cheap.
Go back to the store you purchases it from or contact Nakamichi directly at the link below:
http://www.nakamichi.com/home.html
Sep 05, 2009 | Nakamichi Audio Players & Recorders
Replace rear speaker 2000 es300
You need to check to see if it is an external amp or an amp that is built in with the speakers. They may be 2ohm factory speakers on that stock system, if so you may need a rewire. take a look at the rears and see if you see a small amp. Its Lexus so hopefully it will be a straight forward swap. get back to me if needed.
Jun 02, 2009 | Nakamichi SP-C622 Car Speaker
Only one speaker is working
i also have the same problem. in the begining both of the speakers were working now it's only one. it's not the balance setting either, i think i either blew something, but both of the speakers work when i switched the wires.
Apr 15, 2008 | Nakamichi SoundSpace 8 System
Installation a new speaker in stock sound system
One thing you should know when you install the new speaker it is going to pull most of the power away frrom the factory speaker. In order to get the true sound of the speaker, remove the factory one..I know that the door panel might give you trouble, but it will be worth the trouble..If you tell me what kind of car you are working with, I can help you remove the panel easy.
Dec 21, 2007 | Dynaudio MW 160 Car Mid-Range
Bazooka CS8A5 Car Subwoofer Logo
73 people viewed this question
Top Bazooka Car Audio & Video Experts
Mark Skinner
Martin van der...
Martin van der...
Level 1 Expert
Dalynn Turner
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
