Question about Clarion SIR-CL1 SIRIUS Radio Receiver
MY CLARION DXZ545MP W/CL1 HAS STOPPED TUNING MOST CHANNELS
ALL OF A SUDDEN MY RADIO HAS STOPPED TUNING 80% OF MY SIRIUS CHANNELS. IT SEEMS TO BE STUCK ON POP/ROCK. IT ONLY TUNES:1-15,18,20,23-33,39,66,76
IF ANYONE HAS ANY SUGGESTIONS PLEASE LET ME KNOW. I HOPE I DON'T HAVE TO BUY A NEW HEAD UNIT..
THANK YOU....
  • audiofool51 Feb 01, 2009
    I have the same problem, but a lot of trial and error efforts increased the categories from just Pop to Pop and Rock. I had a lot of talks with Sirius tech support yesterday, and there were 2 messages that kept coming back: first, Sirius says if you're getting that many channels, there's nothing wrong with Sirius, the problem is Clarion related; second, you have to "hard reset" the Clarion. I don't know about "hard" but if you detach the face plate, there is a reset that you can reach with a ballpoint pen or a stylus from a phone, etc. I've done that a lot, and the problem remains.
  • nebetv May 14, 2009
    I listen mainly to channel 100.
    When the radio is initially turned on the channel pops and crackles.
    INVALID CHANNEL appears and then changes to channel 1.
    If I change channels most of the time I can get a station.
    If I go back to channel 100 after about a minute, it comes in.
I have a similar situation ..... And am looking into categories ... will let you know
Posted on Jun 04, 2009
No instrutions with used car
garage downloaded the info we needed
Aug 27, 2009 | Clarion SIR-CL1 SIRIUS Radio Receiver
Constantly goes to "linking" whenever I select Sirius. Sirius tells me that means an antenna problem. However, I have tried a new antenna with the same results.
The unit needs to be replaced. solder pins on the PC board of the unit are broken. Clarion has about 100,000 of these units with the same problem. You can find a replacement online for $50 that's been fixed & the problem should not re-occur. Sorry for the bad news. Hope this helps
Jun 02, 2009 | Clarion SIR-CL1 SIRIUS Radio Receiver
Installation question ??
With the CNET you do mthis, CD Changer to the sirius input, srius output to the Clarion input. It's just a "daisy chain". I hope I understood you right, if not, you can yell at me :-).
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | Clarion SIR-CL1 SIRIUS Radio Receiver
Sirius Starmate Power
My Sirius ST1 receiver froze. It reads "Sirius Radio" with the logs but goes no further in booting up. Any solutions?
Nov 12, 2008 | Clarion SIR-CL1 SIRIUS Radio Receiver
Sirius Radio Invalid Channel message
1) Do you have a Sirius account?
2) Have you called Sirius and given the serial number of that receiver?
Those are the first two things you have to do to get a Sirius receiver working. (The original owner could have changed his account to use his new receiver, if he has one.) Go to http://www.sirius.com/install - the "activate" part - for details.
Aug 20, 2008 | Clarion (NAVSIR) SIRIUS Radio Receiver
Clarion Marine XMD3 / SIR-CL1 Sirius Troubleshooting
I had the same problem with invalid channel on all channels ! Had to reset the siriuss receiver by removing power for 15 sec and restoring! that means not just shuting it off but removing all power to the sirius unit not the clarion unit itself and reastablishing power to it turning on the clarion head unit and walah! satelite would recieve ESN and 184 and programing! Hope it works for you after 3 long waiting periods on the phone!
Oct 21, 2007 | Clarion SIR-CL1 SIRIUS Radio Receiver
SIR-CL1 WIRING DIAGRAM
Here's the manual http://www.sirius.com/pdf/manuals/SIR-CL1_user%20manual.pdf Hope this helps.
Sep 15, 2007 | Clarion SIR-CL1 SIRIUS Radio Receiver
Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
My DX445 does the same thing. Here's my method for fixing it, it should work for any similar Clarion receiver:
1. If possible, make sure the radio is turned off when disconnecting the battery. If the radio turns itself on when the vehicle is restarted (for example after jump starting or battery disconnect for a few seconds only), turn the radio off.
2. Disconnect the battery by removing the negative battery cable from the battery. Leave it disconnected.
NOTE: Car batteries can be dangerous things. If you're unsure how to do this safely, get an experiences mechanic to help you.
3. Reset the radio. On my radio this is done by removing the faceplated, and pressing a tiny button for 30 seconds. Your radio may be different.
4. After waiting at least 20 minutes, reconnect the battery.
5. My radio displayes 'System Check -- Press Power'. After pressing the power button, the display reverts to the clock.
6. Turn on the radio. It should work fine on the broadcast bands.
7. Select 'Sirius'. The radio should display 'Updating'. Don't touch anything until the radio finishes its update phase. When it's done, it should tune to Sirius channel 1 and play as normal.
8. This should restore normal tuning. reset your presets and preferences.
What seems to happen is that the radio gets stuck in a 'Category Select' condition, but not all the categories will load, and manual tuning will not allow, say, Radio Classics to play when the radio is stuck in Pop mode.
On occasion (maybe 1 time out of 10), the radio hangs while doing the 'updating' in Sirius mode. If this happens, just shut off the radio and start over. I've never had to do the brute force reset more than twice since I stumbled on this method.
Aug 11, 2007 | Clarion (NAVSIR) SIRIUS Radio Receiver
Clarion SIR-CL1 SIRIUS Radio Receiver Logo
228 people viewed this question
Top Clarion Audio Players & Recorders Experts
John
John
xxxxxx xxx
Terry Hair
Are you a Clarion Audio Player and Recorder Expert? Answer questions, earn points and help others
