Question about HP OfficeJet G55 All-In-One InkJet Printer
G55 PRINTER NO POWER
The printer will not power up after a storm was experienced . There is power supplied from the power supply as indicated on the plug. when the power button on the printer is pressed nothing happens. is there maybe a fuse in the unit that can be replaced & if so how do i go about replacing it. your help will be much appreciated.
thank you
Roger Deakin
I have had that same problem over years with mine. If you unplug the power supply from the wall outlet (or the 120 power cord from the power supply) and then plug it back in it should all work again. Unplugging it from the back of the printer doesn't help
Posted on Feb 24, 2009
I have a HP Photosmart B8350. I haven't used it for about a few months. The green indicator light on the power module is on but the printer will not power up. Don't know what to do.
So the printer has no indicator lights on at the printer? If so have you verified the power supply is working and is supplying power to the printer. You need to check the voltage output with a DC volt meter.
Nov 24, 2016 | HP Office Equipment & Supplies
Why wont printer start up?
this is will take several exchanges to troubleshoot.
when did it last work? any lightening storms, is it on a surge protector or UPS? can you test the voltage if there is a power supply in the power cable? when u unplug and plug back in any clicks or lights on the printer? same question when you press power.
Jul 27, 2014 | Kodak ESP 7250 All-in-One InkJet Printer
All lights flashing, wont print
if you are experiencing quick flashing light on the display. then you will be needing to aquire a new power supply in particular 2xIRF450BPF components have failed on the power supply PWB located in the upper right quadrant. Belmonte Business Equipment have the Power supply in stock and can be sent or fitted.
Oct 11, 2013 | HP DesignJet 1050c InkJet Printer
No power to unit after storm and power failure
HI!
Its most likely damaged the Power supply and the main board!What people do is buy a new power supply and when they get home it still wont turn on!It will be cheaper buying or claiming one from the insurance than having that one fixed!!
Good Luck!!
Dec 23, 2010 | Canon MX700 Office All-In-One InkJet...
My printer will not turn on
you can try plugging the printer to a different known working power outlet in the wall. If still not turning on, try to unplug the power supply (black box) behind the printer where the power cord is plugged in but the other end still plugged in the power outlet in the wall. The power supply should have a green indicator light on. If not, check any physical defects on the cord or the power supply itself. If on, plug it back in and make sure to plug it in correct position in the slot. Note that it can be plugged in incorrectly so just double-check the position of the power supply itself. Hope this helps.
Mar 08, 2010 | Lexmark Z2300 InkJet Printer
My printer will not turn on. We had a storm
Solution one: Press and quickly release the Power button Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Check the electrical connections and outlet
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif c00057913.jpg
    NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power cord for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power module to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn the product on.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
    • If the product still does not turn on , continue with the next solution.
Solution three: Check the USB cable
  1. Disconnect the USB cable from the back of the product. Figure 2: Disconnect the USB cable from the HP productc01896072.gif
  2. Press the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on with the USB cable disconnected , replace the USB cable.
    • If the product still does not turn on , continue to the next solution.
Solution four: Check the batteryIf your HP product has a battery, follow these steps:
  1. Check the battery light. If the light is red, recharge the battery.
  2. If the battery light is still red after recharge, replace the battery. Figure 3: Removing a battery (example only)c01468528.jpg 1 - Slide the battery release slider in the direction of the arrow 2 - Remove the battery
Instructions for recharging and replacing a battery are available on the HP Web site. Solution five: Replace the power supplyIf you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product. Solution six: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Nov 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
All Lights Flashing
Your printer need service. Its firmware problem. All lights flashing error state usually indicates a hardware problem of your printer.
Aug 04, 2009 | HP OfficeJet D125xi InkJet Printer
Electrical storm last night. Now no power on
you need a power supply. That is where the fuses are and you should not replace them.
The Power Supply should be replaced.
Jun 12, 2009 | Xerox WorkCentre M20i All-In-One Laser...
HP Color LaserJet 4500 Printer
Here is your problem. Hope that this helps you.
54.1 PRINTER ERROR
Description:
Indicates that an internal power failure has
occurred.
Action:
1. Turn the printer off, and then turn the printer
back on.
2. Replace the high-voltage power supply.
3. Check the fuser to ensure jams have not
occurred.
Caution When clearing jams, the
thermistor can be damaged
causing this error.
4. Make sure there is not a fluctuation in the
power supply to the printer. Check that the
electrical specifications (see Chapter 1) are
met.
5. Replace the low-voltage power supply.
Apr 02, 2009 | HP Color LaserJet 4500 Printer
HP OfficeJet G55 All-In-One InkJet Printer Logo
100 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
