Question about RCA HD52W59 HDTV Projection Television
Hd52w59 Need help to get the opion of auto covence back on menu screen
  • 4 more comments
  • boyzdadx2 Feb 02, 2009
    Thanks so much!I just replaced the fl231.Will replacing the others help the set from shuting down every now and then it won`t come on?
    Fullthrottle
    Thanks i`ll replace them tomrrow
  • boyzdadx2 Feb 08, 2009
    I did replace them now it keeps shuting off and no more convenve
  • troberts479 Feb 26, 2009
    I have the same problem. How do you "replace" those fuses? Do they just pull out?
  • eblack60 Mar 02, 2009
    what would cause the fuses to blow? and how often?
  • coreweave May 11, 2010
    Can you get these parts at the local Radio Shack? $3.79 is not a whole lot of money, but for a single radial capacitor, the price seems to be pretty inflated http://servicemanuals.vstore.ca).
    I haven't taken a look yet, but is CL230 and DL231 located on the deflection board or convergence board?
  • RCA Master
  • 8,617 Answers
You need to replace FL231, CL230 and DL231. You can get the parts at the following link with free instructions for under 20.00
http://servicemanuals.vstore.ca/
Posted on Jan 31, 2009
  • Sonny Berry
    Sonny Berry Feb 02, 2009
    yes without replacing the other components the FL231 will keep blowing after a few days and can actually end up burning resistors on the convergence power supply board. rep;acing just the fuse id only a very temporary fix as it will keep blowing tioll the cuase is repaired.
  • Sonny Berry
    Sonny Berry Feb 09, 2009
    did you observe the polarity on the diode and capacitor?
Rca tv modle #hd52w59 convergence problem need to know cong.location
if you need to know where the convergence settings are you click menu then setup and then convergence. I have the same tv as you and the picture looks like its 3d with red and green and the words on menu are doubled and I tried auto converge and it didnt work. If you figure it out let me know. it also might be a fuse.
Nov 01, 2010 | RCA HD52W59 HDTV Projection Television
My rca hd52w59 tv looks like its in 3-d. auto covegnence used to solve the problem most of the time but now it does nothing. pic is constantly looks like 3-d now. the colors r all not right. i get it close...
Hi
Thanks for using FixYa. You’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. You can buy the convergence chips from this link; also if you want you can buy repair kit which comes with complete installation and parts. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Television--the picture 3-d images colots red blue and green, been working great till this after noon any help please
When you presss menu and then select settings is the auto convergence and convergence options still there or have they disappeared/ Let me know and I will assist you with the problem.
Dec 17, 2009 | RCA HD52W59 HDTV Projection Television
My picture is not fitted to the screen.
go into the menu find convergence
some models have auto convergence
if you have the option to manual adjust convergence adjust red and blue DO NOT move green
Sep 02, 2009 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
step by step instructions are avalable in the tips and tricks section of this website.
May 29, 2009 | RCA HD52W59 HDTV Projection Television
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 12.00 shipping is free. the parts are all listed under the RCA parts category.
May 28, 2009 | RCA HD52W59 HDTV Projection Television
Screen size changing back and forth on its own
Try going into the menu format setting (4.3 or 16.9 or auto) and change setting from auto to 16,9 and store setting.
SUPER8
Dec 01, 2008 | RCA HD52W59 HDTV Projection Television
No blue auto convergence when performed by menu buttons
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 31, 2008 | RCA HD52W59 HDTV Projection Television
Conversation
The service # is hd52w59 and then something like yx1 or etc..... On the model # tag, this is written in very small writing. There is no way to remove the convergence option. Go to menu the set up and there you should find convergence. Choose convergence and run auto converge. If this does not work then there is a failure on the convergence power supply, convergence amp, or the deflection/power bd.
Mar 19, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
162 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
