Question about Kenmore 53082 / 53084 Side by Side Refrigerator
Frig is freezing at the bottem
It is freezing in the crisper tray and not cold at the top of refrig abiut 50 degrees on top shelf
  • conanscorner Feb 06, 2009
    frigde at bottom frezzes veg and fruit also frezzer has icicles on it by ice maker
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Check doors
Posted on Apr 05, 2009
Freezer is cold, has ice on bottom. Frig side is constant 50 degrees. It is constantly running also.
the defrost has melted the ice,now the drain tray is plugged and needs a wire run down from the drain in the freezer to the condenser pan so it can evaporate,as this fools the temp thermostat trying to cool the refrige compartment to keep trying to cool the unitif theres water dripping into the fridge rom the freezer this is a good indicator of this problem
Jul 01, 2011 | Refrigerators
Vegetable crispers and deli tray freeze food.
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try: If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper.
Feb 15, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
The ge refrig. is 9 years old. Regardless of the refrig. setting, from 5 down to one it is too cold. set on 3, after 24 hours it is 28 degrees in the crisper and 32 degrees in the main refrig. tried...
ok u ok u turning wrong knob..turn other knob the one with the letters. make the freezer colder than u make ref. warmer. that knob controls a flap that controls how much cold air flows from the freezer to ref. ok
Feb 12, 2011 | GE Refrigerators
Our LG LFX25950SB has been freezing all the food in the refer since we purchased it 3 years ago. Had numerous service calls. They tell us we are leaving the door open, we do not have the correct...
Contact LG @ 1 800-243-0000 and let them know what is going on.
This is a known problem and a fix is availiable.
LG may help you out.
Call M-F for the american call center to answer.
If they wont you can fix it real easy.
Pull out bottom crisper dware.
Look on the back wall.
You will see a dime sized hole.
This hole allows cold air from the freezer to cool the crispers.
Cover the hole with a small piece of duct tape.
This should stop the crispers from freezing.
Also on the right wall of the ref. you will see 1 or 2 egg shapped white covers.
Remove the covers carefully so you dont break it.
You will see a 1" white thermister probe.
Pull the probe out of the insulation and clip it on the egg shaped cover and reinstall the cover.
The thermister tells the computer how cold the ref. is.
Jan 12, 2010 | LG LFX25960 Titanium Bottom Freezer French...
GE Profile Artica side by side - freezer not cold enough
replace control board on back of unit there is a six by 10 inch cover on back your panel is in there cost aprox 169.00 dollers also replace bo0th thermisters bottem left of freezer looks like a white bullet the other is in fridge behind shelf trim located beside and underneath where the cold air blows into the fridge.
Aug 10, 2009 | GE Profile PSI23NCR Side by Side...
Vegetable section too cold, freezing the vegetables
if youd like you can remove the affected crisper, locate the "adjustment slidelever" and remove it, behind there youll find a hole(which is what youve been restricting to lessen the cold air flow.) try wadding up a ball of perma-gum, window sealer, some sorta plug forthe hole, its not nessecary for function of refrig, only to make the crispers colder, but usually too cold. blocking of fthe hole willl make the crispers only as cold as rest of refrig
Mar 23, 2009 | KitchenAid KSCS25FKSS Side by Side...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Refrigerator side too warm
SHOULD HAVE A AIR DIVERT ER CONTROL TO SEND MORE AIR TO FREEZER AND LESS TO FRIG SIDE TRY TO SENT MORE AIR TO FREEZER SIDE AND LEAVE COLD CONTROL COLD ENOUGH TO ACCOMMODATE THE FREEZER SIDE TO BE COLD ENOUGH
Jan 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Kenmore 53082 / 53084 Side by Side Refrigerator Logo
96 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
