Question about Hotpoint Aquarius WMA42 Front Load Washer
Aquarius wash system plus wm 63
Its not drianing the water out what do i do?
  • Hotpoint Master
  • 3,463 Answers
First thing to do is to remove the lower rear panel of washer and remove the large black hose from bottom of tub, inside you will see a plastic filter, remove and clean same.
Refit hose and test, if water still does not pump out then check that the drain hose is clear, remove hose from pump, and try running water through it from a tap or something, it should be clear, as sometimes the hose itself can get blocked with limescale.
Check pump is clear, and before you refit rear panel try the washer on main spin and you should hear the pump running..If it does not, then you could have a faulty pump.
Plz rate my solurion.
Posted on Jan 29, 2009
  • 135 Answers
First of all lay the drain hose into a bowl or bucket to drain off.
Then take off the plate at the back of your machine and you will see a pipe running from pump to drum.
Where it meets the drum there is a filter inside which you can check for debris. also take off at the pump and check inside pipe & pump.
Happy to help further if required.
Thankyou for using Fixya.
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
My mothers Hotpoint WM 52P will not drain water out or spin???? Does this mean brushes??? poppywitch
no take the sump hose off from the tub off the machine and check for blockages the machine wont spin unless it can drain the water out
Jun 05, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Does the Aquarius 100 wm 25 have a filter?
you'll need to take the bottom rear panel off and remove the retainer from the rubber hose attached to the bottom of the drum.
it's like a plastic basket inside.
Feb 28, 2009 | Washing Machines
Can i clean the filter of my aquarius wash system plus WM 65 ?
Most washing machines have a screen at the water hoses. Remove the hoses on the back of the machine and remove the screens inside. They can be cleaned and reused.
Feb 19, 2009 | Washing Machines
LG WM1832CW water leaking
your valve is not closing or your cycle isn't reading correctly. there should have been a diagnostic read process that should have came with the machine. if not you may have to end up buying a new drian assembly
Jan 15, 2009 | LG WM-1832C Front Load Washer
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Knocking on WM63
Hi there!
Yes , you need new dampers for it.
These are easy to fit from the rear. Look at online parts stores under your model, and you should get them delivered within a week.
Check also that any foam bumpers are still stuck on the sides.
Apr 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wm63
The heating element for this paticular model is located on the front casing of the drum.. you have to remove the front panel complet with the door and you will see it at the bottom behind a black protective cover.
Nov 27, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
239 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
