Question about Altec Lansing VS4121 Speaker
Subwoofer making load humming noise - Altec Lansing VS4121 Speaker
The reason for the hum in the Altec Lansing VS4121 speaker system is the stray field of the power supply transformer. This stray field is strong enough to affect the amplifier. All other reasons given by numerous reports on the web do not apply. If you are handy and have got the time you may mitigate the problem by physically moving the amp away from the power supply or turning it 90 degrees. I managed to lift up the amp in my subwoofer by about 50 mm, which was difficult to achieve and did not cure the problem perfectly. I don't see any other way to solve this problem except you feed DC in from the outside and do not use the internal power supply. That would be really odd indeed
Gerhard Weber.
Posted on Feb 22, 2009
  • na15 Jan 31, 2011
    I attempted to move this also. Decided it was too much of a pain to be worth it. For what its worth I have an old set of Altecs from about 8 years ago and they do the exact same thing. Hum drives me crazy. I should have learned the first time. From now on I will not buy cheap Altecs. Its too bad they could not address this issue because the sound system itself sounds great for the money.
Altec Lansing says in the manual that the hum on the 4121 is "normal". The gall.
Im not sure but maybe if you could convert your unit to accept DC instead of AC, it might go away. Its a long shot though.
Posted on Jan 31, 2009
Subwoofer making humming noise if you adjust volume control up, but if you turn off and turn on again it is ok temporary but later on it humming noise again.
But also if volume control was not so high subwoofer was ok.
Posted on Feb 19, 2009
    Scholar:
  • 140 Answers
Faulty input wire. Check the connections between the receiver and subwoofer. May need to clean them if dusty.
Posted on Jan 29, 2009
I THINK YOU SHOULD UPDATE YOUR OS TO WINDOWS 7 SOME OF THE SETTING S ARE THERE TO CONTROL THE HUMMING SOUND
Posted on Dec 31, 2010
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
The subwoofer makes a humming noise when powered on
Humming , these depends on what kind? or how loud is the humming.
On most it is from faulty regulator or worst from the amplifier and preamp
These may needs further troubleshooting, have a tech to guide you.
Let us know what you find or needs further assistance.
Oct 31, 2012 | Audio Players & Recorders
My acoustic research hd510 has a loud humming noise
check your audio line in connection, either L or R signal line floating may also cause humming noise. Sub woofer usually very sensitive. If your audio input not connected, do you still hear humming noise? in actual you should not hear such noise, unless volume at max then it is possible to hear little.
Apr 03, 2012 | Acoustic Research HD510 System
Subwoofer makes loud hum noise
4 possibilities:
1) ground loop or open connection on input.
2) close proximity to a CFL, or other flourescent fixture.
3) bad filter caps in the sub.
4) bad coax to the sub.
in any event, check wire routing. You can also track down the noise sources by using a portable AM radio tuned off station. it will pick all manner of RF noise around the house. Light dimmers are notorius noise makers.
Dec 20, 2011 | Audio Players & Recorders
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
Speaker makes a rather loud humming noise.
You can go buy a audioquest SUB-X subwoofer cable with a additional ground wire on it an connect the ground cable to the ground slot of the receiver an the other end to a screw on the sub or into one of the high output terminals on the woofer if it has them an this will take that humming sound right away but the cable is around $90
Mar 28, 2010 | Velodyne HGS-10 Subwoofer
My subwoofer makes a humming noise
In most cases when you have a humming from anything electronic it is being caused by a bad filter capacitor in the power supply. Filter capacitors look like little cans. Look for units which are bulging. If so replace them.Electrolytic capacitors are so cheap even if none are bulging you could replace them all for less than $10. Try that and let me know.
hardrocko
Thanks for using FixYa
Feb 12, 2010 | JBL ES150P Subwoofer Speaker
Yamaha YST-SW150 Subwoofer
hi, is it a humming noise ??? check if the connector is plugged in properly,check the earthing, if its a three pin mains plug, if its a two pin, then the CPU SMPShave a proper eathing. let me know
Jan 10, 2008 | Yamaha YST-SW150 Speaker
Altec Lansing VS4121 Speaker Logo
3,080 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
