Question about Mitsubishi WD-52525 52" Rear Projection HDTV
TV shut off after 10 min.
I watched this tv for 10min or so then everything shut down, pulled plug for an hour or two turned on tv watched for maybe another 15 min. then the damn thing shut down again. Yes, the red lite come on but i've changed the bulb 3 months ago, i know its not the bulb. Can anyone please help, Mitsubishi really disappoint me, i should stick to Sony or Samsung. What a lost on my part.
  • 1 more comment
  • kvu66 Jan 29, 2009
    can you tell me where i can purchase this cooling fan and where about does it locate inside the tv. Im no tv tech here so please bear with me. Thanks
    can you tell me how much would this fan cost and what the best way for me to solve this problem? should i call someone to help me out or do this myself or get electrocuted during the process. I know its a simple problem to solve if i was only know what im doing. Thanks
    yes i believe so too, thanks so much for your help. bye
    Genius:
  • 2,920 Answers
It souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Posted on Jan 29, 2009
  • Ronnie Houston Jan 29, 2009
    there should be 2 of them in the baok of the tv.you should hear them when you turn the tv on with the back off. on your tv im not sure of their exact location but they are audible when you turn the tv on. if you have one working and can hear and locate it you will find the other one opposite of it on the other side
    call someone to help you with it so you dont get hurt. the fans shouldnt be very costly and i think it will solve your problem.it may be just one thats bad .
My set was zapped by a nearby lightning strike. The screen still works. But it won't do anything past the "Vizio Internet Apps" screen. It then times it and shuts the screen off. It is a model #E422VA
Pull the plugs on everything - going to everything, starting with the TV and on out. Let everything just set for 20 min. Then, hook everything up to the TV BEFORE you plug in the TV. Turn it on. Good luck. . .
Apr 11, 2017 | Televison & Video
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Samsung tv is shutting off all the time.
Do you have enough air flow to cool it?
It may be overheating....add a fan blowing into it and see if that keeps it on.If it does put a strong small computer fan in somewhere to keep it cool.
Aug 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Pioneer sd-582hd5 shuts off while watching
internal components probably need to be cleaned.... sounds like a problem with t.v. overheating
Jul 11, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Message on screen says tv will shut down ck air vents for blocks
you must have a wd series mitsubishi..the lamp tempurature sensor has a manufacturing problem..mitsubishi has an updated one to take care of the problem..the sensor itself is not bad it is the way the wires are crimped in the plug,,the new one is soldered..the part number is 299P313010A,
Sep 17, 2007 | Mitsubishi WD73727 73" HDTV
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
218 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
