Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum
Problem for Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum
I have a hoover windtunnel
By karenpaws on Jan 29, 2009
i have a hoover windtunnel bagless that the filter fell out of on accident when I was trying to dump it and I can't figure out how to put it back in
Solution #1
posted on Jun 28, 2009
Not Rated)
snyderb19
Rank: Apprentice
Rating: 0%, 0 votes
which way does the filter go back in on wind tunnel white side towards sweeper or facing out to see white thru grill
Was this helpful?
Yes
No
Solution #2
posted on Jan 29, 2009
Not Rated)
joboo1
Rank: Guru
Rating: 89%, 188 votes
Hi, You don't say which model windtunnel you have but most are the same. The canister is in two sections with a Hoover emblem to the right of the handle. this is the side the filter goes on. The bracket slides out and holds the round filter, the round filter snaps into the bracket so that the end of the filter with the opening goes down to fit the hole in the bottom of the canister. When putting the canister back in the vacuum be sure the top goes back flat on the canister and the locking lever is open all the way. You have to slide the canister back in level and then it will drop down into position you can't tilt it. now you can lock it. Good Luck!
Comments:
Feb 04, 2009
- Hi, I hope I solved your problem, Please rate my response, your favorable ratings help others that may have the same or similar problem. Thank you!
Was this helpful?
Yes
No
Popular Solutions for Hoover Ultra U6430-900
Questions and Unsolved Problems for Hoover Ultra U6430-900
Do you recommend Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum?
Answer
Answer
I was cleaning the 2 washable filters on my windtunnel u6430-900 and forgot how the multi... (More)
Answer
I replaced the belts and brush of my Hoover U6430-900 WindTunnel Bagged Upright Vacuum. Brush turns... (More)
Answer
Hoover Windtunnel u6430 900 - Self propelled functionality no longer working. What can I do about... (More)
Answer
I threw away by mistake my manual on the UPRIGHT Self-Propelled ULTRA Hoover Wind Tunnel Vacuum... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuums Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
