Question about Toshiba 34HF84 34" TV
Flashes bright white randomly
My TV display randomly flashes bright white. Toshiba tech support told me to unplug the TV for at least 3 minutes to "reset the device" then try again. I have done so and this helped eliminate the flashing for approx 4 hours. The longer the TV is on the more persistent the flashing. Is there anything I can do, with basic soldering skills, outside of calling in a service tech?
  • gdw66 Jan 17, 2008
    I have the same problem with my Toshiba 62hm95 DLP.I replaced the lamp as my screen was having faint flashes and the colors looked muted and this did not fix the problem.Does anyone know what the problem might be?
    Genius:
  • 1,074 Answers
Resolder the tv circuit in the power supply and the flyback area that will solve your problem as the symtoms are intermittent just some loose components due to consistent heat over the years.good luck.
Posted on Aug 05, 2007
SOURCE:
Sharp LC-32lb261u TV no longer works after a thunderstorm. If I unplug it & then plug it right back in, I get several random flashes of the red power light.
Sorry for the inconvenience. Actually the LED flashes indicates a code. Could you provide how many times it flashes and the pattern?
For example: 8 short 3 long or 7 flashes and repeats.
Jul 28, 2018 | Sharp Televison & Video
Sharp lc-46le830u LCD tv does not turn on white arrow flashes 2 times slow than a pause and than flashes 5 times quick .it flashes this pattern over and over.what does this code mean?
It doesn't correlate to tthe trouble code in the users manual which are written. It sounds like a motherboard error. Try a cold reboot. Unplug the TV for 2 minutes then restart the TV and anything it is attached to. Unplug all first.
Feb 17, 2013 | Sharp Aquos Televison & Video
Toshiba 42HP66 42 in. LCD Television Color Problem
se cablesdry joints or loooossibly the ribbon cables check for
Sep 19, 2012 | Toshiba 42HP66 42 in. LCD Television
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Dell 32" HD TV flashes black every few minutes
You may want to make sure it's a Yamaha by seeing how the TV displays when connected directly to a cable box or DVD. Also try different HDMI or component inputs to see if it's something in the input connection you're using.
Apr 27, 2017 | Sharp Aquos LC-32D40U Television
Random Flashes on Macbook 13" native screen
you could try reseting the pram. this is accomplished by holding down Command, Option, P, and R at startup you will want to hear the start up tones at least three times. if that doesnt work you might have an inverter issue, the inverter is located behind the screen and needs to be looked at by a pro
Jan 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Toshiba 62hm15a- bright flashes
my toshiba 62HM15A has bright and dark flashes.
Sep 30, 2008 | Toshiba 62HM15 62" Television
Error message
F51 error code is beacause the computer board did not receive input from the motor on the bottom. Unplug the washer, pull the machine forward and tilt the machine back. On the bottom you will see a large white wheel with a silver allen screw in the middle I think it is a 6mm allen wrech that takes it off. Once you remove the screw and drop the white wheel, there will be a large coil of wires with 4 5/16 screws holding it on, remove these scres and drop the coils. On the right hand side you will see a connector with three wires , unplug it. Use sand paper or a scraping tool to clean all 3 male sides of the connectors. Reverse process to re-assemble.
May 15, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Toshiba 34HF84 34" TV Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
