Question about FIC K7MNF-64 nVidia nForce 2 Socket A mATX MB w/Snd, VID LAN Motherboard
Need Network adapter
I have a K7MNF-64 motherboard, i recently changed to Windows XP, the installation went fine the only problem i am having is i cannot create a network connection to connect to the internet, i cannot find where to download the network adapter that i need, can someone tell me where i can acquire it.
Install the nForce 2 motherboard drivers. The onboard network controller drivers are part of the package.
Posted on Apr 11, 2009
NEED USER MANUAL FOR W3052/K7MNF-64 MOTHER BOARD
Here It is a PDF file inside a Win Rar File just download and extract files follow instructions if you need help
1. click this Link to download The file http://www.elhvb.com/mboards/oem/emachines/manuals/K7MNF-64_manual.zip
2. If you dont already have Win rar Download from this page just select which language and version of windows your have "64 bit' or most likely "32 bit" then download and install
3. after installed right click on the first winrar file and selcect extract files here so it will take the PDF file out
4 then open the PDF file with adobes PDF Reader Download Ling Here http://get.adobe.com/reader/ just download and install then click open the PDF file and There is the Manual
Mar 01, 2011 | eMachines Computers & Internet
Hi, I have targus usb to 232 serialcable , model
To use a pao88 on Win7 64bit you will need to have Win7 Ultimate, Professional or Enterprise edition AND your computers processor must support hardware virtualisation.
Dowload and install the latest version of XP Mode.
Install the cable in XP mode.
Turn on USB compatibility in XP mode.
Cable will now be accessable in Win7 64bit
I connected and ran a successfull diagnostic test on an old serial modem without issue.
Oct 27, 2010 | Targus (PA084U) Network Adapter
I need a 64 bit Canon D780 printer driver...where can I download? I went to canon, but their drive is only a 32 bit
Okay so this may not help you now, but I just got a hand me down D780. After much frustration and research here's the solution that I was able to work with. It isn't perfect; but it's something....
So here are the steps for network shared installation; assuming your D780 is installed on an old xp desktop and you're using a Win-7 laptop. If you're using the printer directly on your Win-7 machine, just use the local printer installation after the XP mode has been installed.
1) You'll have to install WinXP mode on Win-7 using the steps listed on this link. If you have a genuine Win-7 copy installed, this download and installation is free, courtesy Microsoft.
http://windows.microsoft.com/en-us/windows7/products/features/windows-xp-mode
2) After installation, you'll have to change network settings for your virtual pc. This step is necessary if you want to be on the same home network and want to see the printer! Never mind if you don't understand this logic. Just follow the steps and you'll do just fine. To change the network settings in vPC: click Tools; click Settings; select Network from left; then for Adapter 1 choose the actual network adapter connected to your router (simply put: select the wireless adapter or wired adapter you're using to connect to your actual router or home network. You can find that from Change Adapter Settings in Network and Sharing.) Click Ok.
3) Now add the printer as local or networked following your usual XP steps. You should be able to see the printer. If not, open a command prompt window, check your ip to make sure you're on same network. If not, or if you don't know how to do that, just type in ipconfig /release enter and then ipconfig /renew enter. Try to connect to the shared printer by pinging the ip of the host computer. If the ping works, you should be able to see the printer then.
Connect printer and use in XP mode. Not the best solution, I know. But it's free and at least lets you print from your laptop, given the circumstances.
Feb 21, 2010 | Canon imageCLASS D780 All-In-One Laser...
Windows 7 Pro 64 Bit and No Internet
It sounds to me like you need a new driver for the LAN adapter that is compatible with Windows 7 64 bit. Right click on Computer under the start menu, chose manage, and open the Device Manager applet. Look for your network card under Network adapters. Right click on your adapter and click on properties. Go to the driver tab and click on update driver. You can also try uninstalling the driver from there and then have the computer scan of new hardware from the device manager screen and let Windows reinstall the driver. Let me know what you find so I can help you further troubleshoot if this does not fix the problem.
Jan 08, 2010 | HP Pavilion a1600n (882780776265) PC...
What is max memory for fic k7mnf-64
Supports up to 2 GB RAM 266/333/400 (aka: PC2100/PC2700/PC3200)
Sep 11, 2009 | FIC K7MNF-64 nVidia nForce 2 Socket A mATX...
Cant find nvidia video drivers on my k7mnf-64 motherboard for vista
i only see support xp for this chipset
xp video driver NVIDIA® GeForce®4™ MX graphics
64MB DDR if not work then use AGP slot with
supported
AGP Slot: Support AGP V3.0 32bit / 66MHz 4X/8X card
k7mnf-64 manual
May 13, 2009 | Computers & Internet
I'm looking for the ethernet driver for emachine model W3052 motherboard FIC K7MNF-64
What Operating system are you installing or using on this computer?
The XP Chipset drivers for this motherboard should fix your problem. The download can be found here.
Mar 17, 2009 | Computers & Internet
EMachine W3052 with FIC K7MNF-64 Mobo
I did just solve all my problems with my own FIC K7MNF-64
Stop error: 0x0000007b / may be caused by attempting to load XP HOME
I've not determined exactly why attempting to load XP Home will cause
error 0x0000007b on the FIC K7MNF-64 , but it does , and it's a situaion not covered in the microsoft artical on it.
From what I can gather XP pro was the offical operating sytem for the board which I've now loaded to mine , windows 98/ME can load to it without problem so that rules out a hardware issue on my end.
eMachine T3395 or W3050 shipped with the FIC K7MNF-64 in them.
Drivers can still be obtained from eMachine for the board as of 8-26-2008
but for XP pro only from what I can see. you may need to hunt around for
98/ME drivers , even if you manage to get 98/ME drivers you will most likely still have a PCI Universal Serial Bus issue so best to load XP pro if possible. biggrin.gif
I hope this information saves some people alot of time.
May the nForce2 be with you , always.
Dec 14, 2007 | FIC (51-81677-00) Motherboard
Computers & Internet Logo
278 people viewed this question
Top FIC Computers & Internet Experts
David
David
Jax Planet
Jax Planet
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
