Question about Kenko Optics
Facing problem in focusing,cosmo wing 20-120x zoom
Focusing problem
Where is the water drain valve on 04 ford focus
It should be lower part of radiator either facing the motor or on the side,look for something like a plastic wing nut.
Apr 30, 2012 | 2004 Ford Focus
The rocker zoom in and out on the top has frozen and doesn't work suddenly :(
I think focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 03, 2011 | Cameras
Lack of focus at 20" on zoom
Zoomed fully in, the minimum focus is about 20 inches. If you want to focus closer, you must zoom out. See page 72 of this manual.
Nov 23, 2010 | Samsung S850 Digital Camera
I want to disable to auto zoom feature but it will not allow me...every time i set it up it starts to auto focus and zoom...i wish to disable these..any help?thankyou
Zoom :
  • 3 x digital zoom (automatic or manual)
  • Travelling-ZoomTM function : Always be in the frame with this unique feature which tracks your face and even enlarges the field of view if there is more than one person in the frame. All completely automatic, just look at the web cam!
The above tells me that you can have automatic or manual 3x digital zoom. Go to the manual mode for the digital zoom and problem might be solved.
Jul 05, 2010 | Guillemot Hercules Dualpix HD 4780428...
Compact digital camera; zoom blur images. what am I doingwrong?
You may be doing nothing wrong, however the camera is either having trouble with the focusing circuitry/lens assembly, or you're not holding the camera still enough, with a solid focusing object (not likely, but happens). I suspect that some aspect of the focusing circuitry (while zoomed) isn't functioning. While that can be a microprocessor problem, it's rare and not likely. Most likely there is debris (dust, sand) in the lens assembly, and needs to be blown out with compressed air. If that doesn't work, you can try to zoom, then hold the camera with the lens facing up, and bump it gently with the palm of the hand, on an area without switches. The focusing ring inside the lens assembly is sometimes stuck, or jammed by debris, and can be freed by compressed air. Bumping the camera tries to reseat the focusing ring, so that it works correctly, from the cpu signals, and focusing detector. If these suggestions don't work, it will have to be serviced. Make sure you get an estimate first- the cost of repair often exceeds replacement cost of a new camera, on sale. Good luck!
May 20, 2010 | Kodak Easyshare M580 Digital Camera
It zooms really close to my face
1) Launch QuickCam software, just goto Start>Programs>Logitech>Logitech QiuckCam.
2) Press the "Change Settings" button, and in the Settings page, just choose the manual focus option, and adjust your focus until the image is clear.
YBC (/\)
Oct 08, 2008 | Logitech QuickCam Communicate STX Personal...
Ford Focus removing a offside wing
hammer and chisel its spot welded on
Aug 12, 2008 | 2001 Ford Focus
P72 face focus blurry background
Hl, I'm not sure what shooting options the P72 has. But, even in Auto you should be able to do this (Auto usually picks a wide aperture). The key is to fill the frame (at least 50%) with your subject. So zoom in and focus on the face and then while 1/2 pressing, zoom back out a little. Then fire away. You should get an in-focus subject and slight blurring of the BG. You have to experiment with this. If you fill the frame too much, you might get such a small depth of field that the subject's nose is in-focus but the eyes aren't.
Sep 13, 2005 | Sony Cyber-Shot DSC-P72 Digital Camera
Focusing the 770
Tom, It's best to do the zoom first, then focus (if you are using the autofocus).
Sep 11, 2005 | Sony Cyber-Shot DSC-D770 Digital Camera
Optics Logo
132 people viewed this question
Top Kenko Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a Kenko Optic Expert? Answer questions, earn points and help others
