Question about HP Compaq Presario V2000 Notebook
Compaq V2000 will not power up
I have this laptop, Compaq V2000, when I press the power button, the power button and the screen lights up for about a second and dies out. I tried 2 different power adapters, one for sure works still does the same. I tried with and without the battery (2 Batteries) or just the battery no power chord and still does the same. Does anyone had the same problem and can help me?
  • Anonymous Jan 30, 2009
    My problem is somewhat similar on my V2000. I can actually power it up however the screen goes out (dark) after a few seconds. The pc is still running but it appears to be a problem with the screen. I also have been having a problem shutting it down.
  • dcfern61 Jan 30, 2009
    I tried that combination, plugging it in also. I tried battery only, Both adapter and battery connected, tried different battery and adapter.When I press the power button, the the power symbol on the power button lights up and the screen lights up at the same time for a second then dies out both the screen and the PC. Thanks
  • 3 Answers
Plug it in lol
Posted on Jan 29, 2009
  • Biggster Jan 31, 2009
    Have ya tried using a vga lead and powering to a different screen??? ie tv,lcd monitor
    is it an intermittent fault ???
Presario v2000 wont boot it powers on then screen says press F1 or F10 but can go no farhter
Sounds like it is not seeing a bootable device, maybe bad hard drive, could be a bad setting in bios. Click here for tech support
Mar 26, 2013 | HP Compaq Presario V2000 Notebook
No screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
The small rubber button on my compaq presario V2000 isn't working. When I open the screen of my laptop the light on the screen will switch on for just a moment, and then switch off. How can I fix it so the...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Mar 08, 2011 | HP Compaq Presario V2000 Notebook
Presario v2000 keyboard issue
well you just might need an external keyboard or just pray for the miracle. i hope you are a christian
Sep 16, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
Receiving Charge will not turn on
Take out the battery and only have the ac adaptor hooked up to the laptop and then try to turn it on.
If that doesn't work, then the motherboard is faulty. Probably a short in the motherboard but the whole thing would need to be replaced.
Also make sure your using the correct adaptor as well.
Feb 10, 2009 | HP Compaq Presario V2000 Notebook
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Compact Presario v2000 the screen is blank
Remove the power cord. Remove the battery. Hold in the power button for up to 60 seconds to discharge the laptop. Try booting it.
Apr 27, 2008 | HP Compaq Presario V2000 Notebook
Screen not coming on
It is a display problem.Better to take any nearest service center.
Feb 26, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
201 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
