Question about Hotpoint Aquarius WMA56 Front Load Washer
Where do ilocate the filter on a hotpoint wma 13 washing machine
Water coming uot of the dor and soap tray
  • Hotpoint Master
  • 3,463 Answers
You will find the filter inside the large black sump hose fastened to the bottom of the tub..
Remove the lower panel at rear of washer, locate hose and remove same ,remove and clean filter inside hose
Refit filter and hose and test.
Plz rate my solution.
Thanks.
Posted on Jan 29, 2009
Hello there My WMA 31 washes clothes, but will not rinse or spin. It does a wash, then stops after about 15 minutes and the 'Wash', 'Rinse and Spin' and 'Final Spin' lights all...
Be sure that BOTH hot and cold water are turned on and flowing. The smell can be resolved by running washing machine cleaner (not just soap) through the machine once a month or so.
Jun 21, 2011 | Hotpoint WMA31 Front Load Washer
Machin fills with water,washes and then fills again
hotpoint wma turn off the power and you are looking for the presure w
switch and chamber , the switch is at the back of the soap draw by the valves on the left hand side there should be a hose going into it take it off and blow through it if nothing happens pull the machine out and at the bottom of the back there is a white plastic cover take it off look for the sump hose and on the side of it there is a whit plastic tube this is the presure chamber clean it out might be blocked
Jun 27, 2009 | Hotpoint WMA64 Front Load Washer
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint WMA76 Leaking door and soap tray
you may be using too much detergent, or you have a blockage in the outlet.try putting it on to spin to drain out the water, if it does not drain then check the filter or sump hose for a blockage
Jan 23, 2008 | Hotpoint WMA76 Front Load Washer
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Intermitant water leak.
Put a newspaper under the machine, it will help you to find out from where does the water leaks. Good luck!
Sep 06, 2007 | Hotpoint Ultima WF865 Front Load Washer
Water Leak
I have th same problem, apparently a possible cause could be a partially blocked pump filter. Just trying to get infoon where this is and how to get to it though.
Oct 31, 2006 | Hotpoint Ultima WF860 Front Load Washer
Water Leak
Raf, remove the soap dispensor and check to see if you have a bottle cap gasket blocking the fill port. Just use your finger and probe around where the port is. Catriver..post back.
Oct 16, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WMA56 Front Load Washer Logo
413 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
