Question about HP Photosmart 2610xi All-In-One InkJet Printer
Hp photosmart 2610xi
States carriage jam can not see any jam front or back
    Brigadier General:
  • 8,619 Answers
Hi!
If the light on the power in connector is not flashing, the power supply is most likely good.
Does the carriage move when you open the cartridge access? If it does, turn off the power. Open the cartridge access and check if the carriage is locked to the right in the service station. If it is not locked, suspect a gummed up service station or a failed service station motor
Posted on Jan 29, 2009
  • Rylee Smith
    Rylee Smith Jan 29, 2009
    The carriage does hold the ink cartridges. If the carriage does not lock to the right in the service station when the printer is powered down normally, you have a problem. Does the carriage go to the far right as if trying to dock in the service station?
    Service station has two purposes: To clean the printhead nozzles and to cap the nozzles to keep them from drying out when the printer is idle. The cleaning and capping involves a motor and some mechanical widgets. It is the capping function that locks the carriage in place and i think your capping part is jammed
    As I mentioned, the motor has either failed or the service station is gummed up with ink. The cleaning process causes congealed ink to accumulate over time. If the service station is gummed up and/or the motor has failed, it should be removed and cleaned, not extactly a simple or clean job. It involves removing the case and partially disassembling the print mechanism.
  • Rylee Smith
    Also see the HP WEBSITE TROUBLESHOOTING LINK for all the details on how to remove this error.
    Brigadier General:
  • HP Master
  • 3,614 Answers
initially check for any paper jam or stuck on the unit, check for any dislocate part near the carriage, could be a misaligned glider cause this problem
When printing, paper pulls to one side and get get error message carriage jam. Don't see ant jam.
It will pull to one side if the rubber roller on that side is coated with dust or is used up on some parts.
1. Clean the roller with some alcohol & soft cloth
2. if the above solution does not solve ur problem, pls replace that part - contact hp
Feb 07, 2010 | HP Photosmart 2610xi All-In-One InkJet...
HP Photosmart 2610xi is printing but it does not keep the left margin aligned - it typically floats progressively to the right but sometimes wanders back and forth. Also about mid-way through each line...
You need to clean the encoder strip, that's the clear strip that runs behind the carriage assembly, you can clean it with a Q-tip damp with alcohol, the strip is fragile so don't press too hard. If you look with a flashlight you should see the area that needs cleaning.
Dec 31, 2009 | HP Photosmart 2610xi All-In-One InkJet...
My HP PHotosmart C4150 is reporting a carriage jam. I have removed all paper , opened the door, and reclosed it. It is not working. I cannot see any carriage jam.
Hi
Please see this link from HP, and check how to clear the carriage jam(link includes the pictures aswell)--
HP Photosmart C4150 Carriage jam Troubleshooting
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | HP Office Equipment & Supplies
Carriage jam on HP Photosmart 3210 Printer
most likely the sensor on the paper path out of position, chech it out and put it back to where it have to be, good luck!
Dec 13, 2008 | HP Photosmart 3210 Printer
Printer keeps saying carriage jam
I hate to state the obvious, but maybe your printer has a carriage jam. Fortunately, HP.com publishes a web page that can tell you how to clear the problem:
Carriage Jam Document
Good luck.
Oct 10, 2008 | HP Photosmart C6180 All-In-One InkJet...
Issues with my HP Photosmart PSC 7280
I had the same problem. You can access the carriage from the back of the printer. I actually had a jam , however just as you exposing the carriage from the front I did not see a thing.
Jul 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart 2610xi All-In-One InkJet Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
