Question about HP DeskJet 5740 InkJet Photo Printer
Paper jam the paper keeps jamming and a screeching noise accompanies it
Mine was doing that too. Here's what worked for me... try getting a Q-tip wet with alcohol. Rub all of your rollers then let them dry before trying to print again. A friend told me that this is a sign that the rollers are wearing out and that it will be cheaper to get a new printer than to fix this issue. Eventually, that's what we'll have to do. In the meantime, try the alcohol.
Posted on Feb 15, 2009
Kodak esp 2170 carriage jam problems
The carriage operation is not synchronized. It will have to be adjusted to normal
Aug 14, 2016 | Kodak ESP Office 2170 All-in-One Printer
Printer paper jam
Go To Below official Brother Printer Page For Your problem, How do clear paper jams Brother Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
Mar 24, 2014 | Brother DCP 130C All-In-One InkJet Printer
My brother printer mfc-j415w keeps giving me an error message which says paper jammed, I removed all paper and bits of debris found in between the rollers but it still keeps giving me the same error m
there will be paper to the side of the printer which is stopping the carriage from travelling fully which will also be why it makes a noise.
If its to the right of the carriage, start printer and when carriage starts to move pull the power lead, you'll be able to move the carriage out of the way and look in with a torch to find the paper or foreign object. Just remove it and restart the printer and everything will be normal.
Please indicate if it fixed your problem here.
If you need ink for this printer go to our site:
http://www.the-inkstore.co.uk
Jan 29, 2013 | Office Equipment & Supplies
I had a paper Jam and know printer error 5100 mesage is coming up, I turned off the printer for 5 min but when I turn it back on it make a turn nois and then a screeching noise then stop.
Sometimes when you get a paper-jam and remove the sheet, there can be little pieces of paper still stuck in the machine. This will cause your printer to do exactly what you are describing. Also remember that when removing a paper jam, use caution and care when removing the paper. To much force can damage the rollers and small gears inside your machine.
I hope this assists you,
Regards,
Nico
Jul 06, 2011 | Canon MX882 All-In-One InkJet Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
13.20.00 Jam in top cover area, no jam
pull your fuser out and you will find the jam and reason for the noise. it is pulled from the rear 2 covers and 2 screws
Jun 23, 2009 | HP LaserJet 4200 Printer
OFFICE JET 7410 PRINTER
Check the cartiridge if it is sitting nicely on its place. it seems you dint place the cartirdge properly
Apr 02, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Paper Jam error won't clear
The only way you can clear a paper jam as bad as yours seems to be is to take the cover completely off (screws that hold it on). You have to be able to see the complete printer mechanical assembly and where the paper feeds through it to be sure that you get every piece of paper out. The reason for the screeching noise is that there is still something in the way of the printhead moving back and forth or finding the home position all the way to the left. The printhead to operate normally has to have a clear path to go back and forth. By looking at the cover for the screws (sometimes you have to lift the part where you change ink cartridges to see the ones you have to remove. Once it is off you can see clearly where the hangup is. Since yours is a multifunction printer you may need to disconnect some cables to take the cover completely off. When you disconnect any cable always be sure to note how it came off. Most plugs are keyed so that they cannot be plugged in backwards but that does not mean they cannot be forced on backwards. So be careful with that. Let me know if there is any other information that you need to make this easier for you. At this point you are getting to the realm of where most people would have a technician do that for you.
Feb 10, 2009 | Brother Multi-Function Center MFC-240C...
Paper jam made horrible noise, now no power
that's the mechanism in side rebelling..I'd recommend you have a qualified service person handle this one.
Aug 04, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP DeskJet 5740 InkJet Photo Printer Logo
183 people viewed this question
Ben Johnson
