Question about Funai F42PDME 42 in. Plasma Television
FUNAI TV Hello, I have a Funai 42" Flat Panel TV model # F42PDME. Tonight when I turned it on the sound is fine however the picture is now just a series of colorfull vertical lines. Is this something I can fix myself? Thank you, Frank
  • cescomuerto Jan 29, 2009
    I unplugged the TV for 15min and I still have nothing but colorful vertical lines and perfect sound.
    I've had it for 3 to 4 years with absolutely no previous trouble.
  • Funai Master
  • 19,396 Answers
Try determining if you have the lines even when tv is stand alone, in that case, it is an internal fault, and you need to have TV tested by a technician.
If you do not get the lines on certain inputs, then check the connection and cables, and also test the receiver.
See also detailed solution on website below:
TV/VCR/Stereo Troubleshooting: Vertical line
Posted on Jan 30, 2009
    Sergeant:
    Champion:
  • 435 Answers
Try playing and DVD or Video disk to check if the problem is only w/ the TV Video.
Posted on Jan 29, 2009
    Sergeant:
    Champion:
  • 239 Answers
You have contact the manufactor it seems like a serious problem if you have warranty take advantage of it
  • 11,896 Answers
If you are getting the vertical lines and you didn't adjust anything for them to get there, than could be some electronical component problems. You could have a bad flyback, bad CRT's, bad EPROM, bad capacitors, or even a fried video board. If you cannot fix it when taking off the back cover of the tv and adjusting v-hold and other picutre adjusting screws, than I'm afraid it's time to dump it or pay a few hundred for getting it fixed
    Sergeant:
  • 285 Answers
First, check ALL the cables and make sure you are on the correct input mode. If this doesn't work, your tv is most likely dead, since plasmas dergade over time.
  • Andrew Perrong Jan 29, 2009
    No, I reccomend you take it in for service. However, plasmas degrade over time and your set might be dead. You
    Scholar:
    New Friend:
  • 70 Answers
Frank,
Sorry but i'm not to familiar with this model,is it using a flat tube type screen or LCD or PLASMA screen? if it's a PLASMA or LCD type screen the only thing you can do is seek a help from a certified technician, most likely the problem deals with the internal.it's either the display driver module or the display screen itself.
cheers,
mark
  • 4,472 Answers
First try each different source but most likely you need servicing. How long have you owned this television. Once I have more information I can suggest the best route for you.
Thanks,
Lee
  • Lee A.
    Lee A. Jan 29, 2009
    http://www.funai-corp.com/support/asc.as...
    being that this is out of warranty i recommend you follow this link and locate the nearest service center and inquire about an estimate as it is definitely a defective part. if you need further assistance let me know, also please take a moment to accept and rate my solution accordingly.
    Thanks,
    lee
    Brigadier General:
  • 8,619 Answers
Hi!
It is almost certain the problem is magnetic distortion to the shadow mask of the picture tube.
This is caused by something nearby to the television that is causing a magnetic field to over power the screen. Most common it is another loudspeaker or subwoofer that is near by.
The correction is as follows:
ONE: Move the object that has the magnets further away from the tv.
TWO: All tv sets have a degaussing coil built in. This coil is activated each time the tv is turned on. It will gradually, over a period of time, degauss the screen and restore it to normal operation.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jan 29, 2009
    If that is not the case then it is either a a bad buffer module or a bad panel. Hope that it is not the panel or else it will cost you a fortune.
    Please revert for any clarifications.
  • 679 Answers
Are you using "component" connection to the video source. If so check the red green and blue wires , It sounds like the green and blue may be crossed. Did someone re connect the cable or sat? The problem uou mention is sometimes caused by mixing up the wires, and being a little color blind myself, I have done this myself. I hope that is all it is, check all of the connections, like surround sound reciever if you are using one.
  • George Bill
    George Bill Jan 29, 2009
    did you check the input connection, are you using HDMI, Component, S video, any little info helps, and if you are using component are they pluged into the right color input and outputs.
    President:
  • 2,110 Answers
I think you have either a faulty line output transistor or a faulty line output transformer. The first thing to check for is dry solder joints and if this is not the case then suspect those two components. If you are not able to check for this find a competant technician. Hope this helps.
  • 10,594 Answers
Yes, this problem can be fixed.
Unplug TV from AC oultlet for couple of minutes and replug back in and power up.
let me know the results to provide further help if problem still exist.
  • Shahid Electronics
    Shahid Electronics Jan 29, 2009
    Since its plasma TV so very hard to find parts / boards.
    Problem seems in digital video processing board and Part Store would be good source of boards for your TV but you need TV tech to examine and decide what board should be replaced.
    Thanks.
My picture size shrunk
you have a bad cap in the vertical section depending on your skills as an electronic tech see repairman
May 19, 2010 | Funai F42PDME 42 in. Plasma Television
No channels installed.lost channels when child knocked over satelight reciever.i have picture but no channels.how do i reset
Rehook everythings,reboot ur box,by turn off/on.Go ur tv menu select for recan channels slect Cable.After rescan everythhngs shoud be back to normal.
Dec 14, 2009 | Funai F42PDME 42 in. Plasma Television
Need the part number for a power supply for a f42pdme plasma this this a part i can change myself
Wouldn't the part number be on the existing part? that is how I find most of them. Also, would that be the same as a "surge absorber", that part is "NVQZVR07N471 "
Sep 10, 2009 | Funai F42PDME 42 in. Plasma Television
No picture vertical colored lines blinking
im afraid to say your display has gone contact funai they should be able to help you replace the display.
Mar 10, 2009 | Funai F42PDME 42 in. Plasma Television
FUNAI TV
Jan 29, 2009 | Funai F42PDME 42 in. Plasma Television
No Sound NLC 3216 SRL No. NLC321661903971
Dear Sir , I am from India having NLC 3216. My young son by chance fidling with remote and all of sudden the sound stoped.Now in my TV Video is very fine , no sound at all. Please assist me Vijay Gupta vijaygupta15@yahoo.co.in. With Kind Regards.
Aug 23, 2008 | Funai F42PDME 42 in. Plasma Television
Funai tv
Open the back cover and check any fuse blow in Y Sustain board or Z Sustain board. If you do find the fuse gone, replace the board. Good luck!
Jan 25, 2008 | Funai F42PDME 42 in. Plasma Television
Funai F42PDME 42 in. Plasma Television Logo
78 people viewed this question
Top Funai Televison & Video Experts
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
