Question about Kitchen Ranges
All burners have half blue and orange flame?
Orange on top half
  • ljw416 Jan 29, 2009
    It is a gas stove -no propane is used - I never noticed orange before and now it's very obvious. What is the cause and fix?
  • 370 Answers
On a gas range the tip should just be orange. Are you using gas or propaine? If propaine you need to buy a conversion kit.
Posted on Jan 29, 2009
  • Justin Duby
    Justin Duby Jan 30, 2009
    Can you take the top off the burner? If so take a nut driver and tighten the orface below the burner cap.
3 Suggested Answers
  • 3 Answers
SOURCE: burner flame orange instead of blue, problem just started today
The only thing that i can think of is that it is not hot enough. try turning up the heat. Orange fire just means that it is not as hot as the blue fire.
Posted on May 22, 2009
SOURCE: kenmore twin burner.. orange flames
A <i>temporary</i> orange flame from your gas stove can also occur at peak usage times. An increase in local demand can cause a decrease in pressure in the natural gas line. If all of your gas appliances are in combustion simultaneously, this may also cause a drop in pressure, especially in older houses. If the problem persists, it is likely a dirty/clogged burner or the stove needs servicing. In general, an orange flame (on a gas combustion appliance) means incomplete combustion and carbon monoxide production.
Research Design Studio
Posted on Jan 31, 2010
Flame is just orange
there might be a cloq in line or burners like spider webs
.the air and gas is not the right ratio that is why flame is not blue
May 27, 2014 | Fiesta Blue Ember Gas Grill
Orange flames on two Blue-Flame heaters, dual fuel, currently running propane.
Could be that the burner needs cleaning dirt in the burner tubes
Nov 02, 2012 | Blue Flame Heating & Cooling
The flames from the front left burner is 1/3 orange and 2/3 blue; whereas the flames from the other burners are all blue. There is a strong odour from the front left burner when we turn it on and also the...
The flames should be all blue - except when you first turn it on, where the flame begins, & only when you turn it on. Orange flames mean incomplete combustion is happening. Carbon monoxide is being released. Orange flames can also mean your getting low on gas. Clean it & try moving the disk around. An uneven disc means some flames will be higher & burn your pots. The flames are wrapping around your pots if they're burning on the sides. Keep flames under the pot. Regardless of the being clean, the odor means you need to check your gas level. Once filled back, the odor should be gone if that's the only problem. That is placed in the gas as a safety feature. Don't try to fix this problem yourself if the "easy" solutions don't work. It could be very dangerous. Invest in a carbon monoxide detector especially when you have anything gas.
Sep 15, 2011 | GE Profile JGS968 Gas Kitchen Range
Our Uniflame Grill has a round outer burner and a round inner burner. The outer burner has a large orange/yellow fllame. The inner burner has a small blue flame. Is it normal for the inner burner to...
Bob, your wife is partially correct. However, both burners should have blue flames with orange tips. Cleaning the burners and the their venturi valves, should solve the problem. When I say cleaning them, I mean removing and cleaning them.
Hope this helped you and Happy Grilling!!
Jun 27, 2011 | Uniflame FG2204C Grill
We have a Tappan gas range. Don't have the model number; it was in the apartment when we moved in. It is over ten years old. It has electronic ignition. The top burners all have orange-yellow flames...
Sorry to read about your problem, I hope this helps you out.
i would take all units out and clean them..clean all holes in the burners.
since you have the problem on all burners..air/fuel is not the problem at the adjustments..you may have a gas regulator problem
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Tappan MGF500PBW Gas Kitchen Range
Just bought a house with a big old gas wall heater in what i think was originally a fireplace. Only half of the heater turns orange when it warms up. The flames along the bottom are all on and blue, it...
You'll need to remove the faceplate of the heater. Make sure it's off when you do this. Look inside the unit before you power it back up. You should be able to see your gas valve and the pipe that feeds the burner. Your going to find a simple air/gas controller. Depending on your heater, it could be a simple sleve that your able to turn to adjust your air/gas misture. Orange means you have to much air. You'll need to adjust it slightly to make sure you have a good mixture. You'll want a nice clean blue flame on all of the burners. Because it's a simple heater, you might or might not get all blue flames. If you can't, make sure they are blue as much as you can with the least ammount of orange possible.
May 11, 2010 | Heating & Cooling
Dynasty gas range - orange flames
It is normal, it will disappear after a little while, when you bang on the burners, particle fell off form inside of the burners and it caused the orange flame. Yellow flame means not enough air or burner is internal clogged.
Feb 15, 2010 | Dynasty DGRSC 36-6 Gas Kitchen Range
Top Burners have a poor flame. How do I access the burners to adjust the flame ?ps No Owners Manual available. Tappan Millennia.(w/digital clock.)
you dont adjust the burners,either you have dirty burners and need service or your gas pressure is wrong,is the flame blue?or has it some orange flickers in with the blue,then you need to clean orfices and tubes
Jul 16, 2009 | Tappan TGF320 Gas Kitchen Range
Burner flame orange instead of blue, problem just started today
May 21, 2009 | Maytag MGR6775BD Gas Kitchen Range
Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
Feb 20, 2009 | GE 36 in. JGP628 Gas Cooktop
Kitchen Ranges Logo
226 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
