Question about Garmin StreetPilot C330 GPS Receiver
Touch screen selection shifts to item in row below
This is a recurring problem that usually occurs when the unit is first turned on. Until the problem goes away, it is necessary to select the item above the one I want to select in order to get the correct one. When the selected item is at the top of the screen, it is not possible to access the one I want until the problem goes away. Using a pointed instrument instead of a finger for touching has no affect. Needless to say, this is a very frustrating problem.
  • Austin Whitten Jul 28, 2007
    Many thanks! I will try your suggestion. Thank goodness we have air conditioning!
    Many thanks to you too for your suggestion which I will try. I will also contact Garmin support to see what they have to say. If it is useful, I will post their reply.
I have this problem when the unit sits in a hot car. I hold the screen to the the a/c vent and when the screen cools off, the touch screen is back to normal.
Posted on Jul 28, 2007
  • 64 Answers
This is a very common problem with touch screens. Hit the menus to find the GPS Nav's "recalibration tool," or just complain to the manufacturer. It is a hardware problem, so aside from recalibrating it there isnt much you can do yourself... probelm solved! good luck!
Posted on Jul 27, 2007
SOURCE:
How do I do a hard reset for my motorola blurr? I'm having problems with the touch screen sensitivity. It selects things that I don't touch, and doesn't select what I do touch, please help!!
  • If the device is responsive, back up all necessary data.
  • Power off the phone
  • While the phone is off, press and hold the Camera key, then turn the phone back on using the Lock/Power key
    • Note: Continue to hold down the Camera key while the phone boots up
  • When prompted, release the Camera key
  • On the USB FastBoot/BOOTLOADR MENU screen, press and release the Volume down key to enter the Recovery Mode
    • If done correctly, you will see VOLUME DOWN KEY PRESSED appear on the screen
    • IMPORTANT: You only have 10 seconds to complete this step before the device powers back on. If that occurs, you will need to start back at Step 1
  • When the "Triangle!" screen appears, tap the bottom right corner of the display to access the Motorola system recovery screen .
    • Note: If this doesnt work, Touch the bottom right corner and make a small circle gesture to access the recovery screen.
  • Highlight the row labeled wipe data/factory reset [Alt+W]
    • Note: You can use the touch display, volume up/down keys, or the Tinytouch pad to highlight the row
  • Tap Ok to begin the wipe/factory reset
  • When the wipe is complete and the device returns to the Motorola system recover page, highlight the row labeled reboot system now [Menu+Back]
  • Tap Ok to begin the reboot
  • When the device powers back up, you will see the MOTOBLUR setup screen and have the option to create or sign into an existing BLUR account
  • May 28, 2012 | Motorola Cell Phones
    Top row of number and letters not responding when I punch them in. for example #1 comes up #4, #2 comes up #5,and #3 comes up #6! How do I resolve?
    To calibrate your Streetpilot c-Series touch screen, follow these steps:
      1. Begin with the unit turned OFF and unplugged from a power source.
      2. Power the unit ON, continue to hold the Power button for 1 minute.
      3. A screen will display instructing you to Press dot in the lower left corner.
      4. Release the Power button and touch the sequence of dots until your unit displays, Calibration complete.
      5. Your unit should now function normally.
    I hope this helps. Please rate my reply. Thank you.
    Jun 27, 2011 | Garmin StreetPilot c340 GPS Receiver
    The touch screen has stop responding. All the other buttons on the control panel work and change the display on the panel accordingly, but you cannot select any options from the touch screen. Any...
    PROBABLE CAUSES:
    1. The control panel adjustment is incorrect. This adjustment will shift the position of the touch sensor of the LCD unit. Perform the following steps:
    a. Hold the Help key and turn power ON.
    b. Touch selection #10 (control panel adjustment) on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching #10, the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
    Two + (plus signs) should be visible on the screen.
    c. Touch the + at the upper right lightly with a touch pen (something with a round tip which is made of resin is recommended as a touchpen). Check the coordinates displayed in the top line at the top of the screen.
    d. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
    e. If the values are not within the acceptable parameters, repeat Step 3 until the values are acceptable.
    f. Touch the + at the lower left lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
    g. As verification of a correct adjustment, touch the CHECK keys at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
    h. Turn the machine OFF to store the adjustment. Turn the machine ON normally and check operation of the touch screen.
    Dec 09, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
    My Garmin nuvi 200w behaves erratically until it has been turned on and warmed up for around 10 minutes. Before this time the touch screen may not work or when pressed respond as if pressed at another...
    First make sure the batteries are good and at normal room temperature.
    Second, based on your question your touch screen is bad or needs calibrating....
    Then
    Try to recalibrate your screen:
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
    1. Have the unit turned OFF and unplugged from power.
    2. Slide the power switch to the ON position and hold for about 45 seconds.
    3. A message will display on the screen: Press Dot.
    4. Once this message displays, release the Power button.
    5. Press in the center of the Dot.
    6. Keep pressing in the center of the Dot as it moves around the screen.
    7. Once this is complete, there will be a message: Calibration Complete.
    8. Touch Ok and the unit will restart.
    The touchscreen will now be recalibrated.
    *Note if unit is running software version 6.00 or newer you will want to follow steps from below.
    To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
    2. Place your finger in the top left hand corner of the touch screen and apply pressure.
    3. Slide the power switch to the ON position.
    4. Hold pressure in left corner until the Press dot message appears.
    5. Once this message displays, remove your finger from the screen.
    6. Press in the center of the Dot.
    7. Keep pressing in the center of the Dot as it moves around the screen.
    8. Once this is complete, there will be a message: Calibration Complete.
    9. Touch Ok and the unit will restart.
    Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
    HP 1720 I making a noise when printing.
      NOTE: Refer to the Testing section in this document for instructions on performing the tests.
    1. Turn the printer off, and then turn the printer on. The grinding or squeaking noise should not occur while the printer is initializing.
    2. Perform a paper path test. The grinding or squeaking noise should not occur because the carriage should not be moving.
    3. Perform a self-test to localize the noise.
    4. Check the printer for obstructions by lifting the top cover and making sure nothing is blocking the carriage movement.
    5. Check the paper path by following the instructions below:
      1. Remove all media from Trays 1, 2, and 3.
      2. Pull out any visible stuck paper.
      3. Lift the top cover, and pull out any jammed paper.
      4. If you are unable to free the jammed paper, pull out the handle of the paper knob, pull the knob away from the printer, and rotate it to remove the paper.
      5. Lower the rear access door by lifting up on the two rear door latches.
      6. Remove the back panel by pushing the two catches inward.
      7. Pull out any paper that may be stuck inside.
    6. Wipe down the milky white strip (see Figure 1) that the front of the carriage glides on with a clean, soft, dry, lint-free cloth.
    Figure 1: Location of the white strip
    bpp90119-1.gif Replace the whole unitgtabtop.gifIf the printer is still making a grinding or squeaking noise after following the steps above, replace the whole unit. See Whole Unit Replacement instructions, which are included with the whole unit replacement.
    Testinggtabtop.gifUpon replacement of the whole unit, perform a Paper Path test and a self-test as described below to verify that the new unit is functional.
      Performing a paper path test
      1. Press the MENU button on the printer control panel until Diagnostics Menu is selected.
      2. Press ITEM until Perform Tray x Paper Path Test is selected.
      3. Press SELECT to perform the test.
      NOTE: The paper path test will terminate only when the paper in the tray being tested runs out or the printer is turned off.
      Performing the stand-alone self-test
      1. Press the MENU button on the printer control panel until Self Test Menu is selected.
      2. Press ITEM until Print Menu Map is selected.
      3. Press SELECT to perform the stand-alone self-test.
    Hope this help. Please Rate My Response! Thanks!
    PREM
    Mar 31, 2009 | Dell 1720dn Laser Printer
    Guide
    General keyboard shortcuts loadTOCNode(2, 'moreinformation');
    • CTRL+C (Copy)
    • CTRL+X (Cut)
    • CTRL+V (Paste)
    • CTRL+Z (Undo)
    • DELETE (Delete)
    • SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
    • CTRL while dragging an item (Copy the selected item)
    • CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
    • F2 key (Rename the selected item)
    • CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
    • CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
    • CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
    • CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
    • CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
    • SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
    • CTRL+A (Select all)
    • F3 key (Search for a file or a folder)
    • ALT+ENTER (View the properties for the selected item)
    • ALT+F4 (Close the active item, or quit the active program)
    • ALT+ENTER (Display the properties of the selected object)
    • ALT+SPACEBAR (Open the shortcut menu for the active window)
    • CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
    • ALT+TAB (Switch between the open items)
    • ALT+ESC (Cycle through items in the order that they had been opened)
    • F6 key (Cycle through the screen elements in a window or on the desktop)
    • F4 key (Display the Address bar list in My Computer or Windows Explorer)
    • SHIFT+F10 (Display the shortcut menu for the selected item)
    • ALT+SPACEBAR (Display the System menu for the active window)
    • CTRL+ESC (Display the Start menu)
    • ALT+Underlined letter in a menu name (Display the corresponding menu)
    • Underlined letter in a command name on an open menu (Perform the corresponding command)
    • F10 key (Activate the menu bar in the active program)
    • RIGHT ARROW (Open the next menu to the right, or open a submenu)
    • LEFT ARROW (Open the next menu to the left, or close a submenu)
    • F5 key (Update the active window)
    • BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
    • ESC (Cancel the current task)
    • SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
    • CTRL+SHIFT+ESC (Open Task Manager)
    Dialog box keyboard shortcuts loadTOCNode(2, 'moreinformation'); If you press SHIFT+F8 in extended selection list boxes, you enable extended selection mode. In this mode, you can use an arrow key to move a cursor without changing the selection. You can press CTRL+SPACEBAR or SHIFT+SPACEBAR to adjust the selection. To cancel extended selection mode, press SHIFT+F8 again. Extended selection mode cancels itself when you move the focus to another control.
    • CTRL+TAB (Move forward through the tabs)
    • CTRL+SHIFT+TAB (Move backward through the tabs)
    • TAB (Move forward through the options)
    • SHIFT+TAB (Move backward through the options)
    • ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
    • ENTER (Perform the command for the active option or button)
    • SPACEBAR (Select or clear the check box if the active option is a check box)
    • Arrow keys (Select a button if the active option is a group of option buttons)
    • F1 key (Display Help)
    • F4 key (Display the items in the active list)
    • BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
    Microsoft natural keyboard shortcuts loadTOCNode(2, 'moreinformation');
    • Windows Logo (Display or hide the Start menu)
    • Windows Logo+BREAK (Display the System Properties dialog box)
    • Windows Logo+D (Display the desktop)
    • Windows Logo+M (Minimize all of the windows)
    • Windows Logo+SHIFT+M (Restore the minimized windows)
    • Windows Logo+E (Open My Computer)
    • Windows Logo+F (Search for a file or a folder)
    • CTRL+Windows Logo+F (Search for computers)
    • Windows Logo+F1 (Display Windows Help)
    • Windows Logo+ L (Lock the keyboard)
    • Windows Logo+R (Open the Run dialog box)
    • Windows Logo+U (Open Utility Manager)
    Accessibility keyboard shortcuts loadTOCNode(2, 'moreinformation');
    • Right SHIFT for eight seconds (Switch FilterKeys either on or off)
    • Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
    • Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
    • SHIFT five times (Switch the StickyKeys either on or off)
    • NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
    • Windows Logo +U (Open Utility Manager)
    Windows Explorer keyboard shortcuts loadTOCNode(2, 'moreinformation');
    • END (Display the bottom of the active window)
    • HOME (Display the top of the active window)
    • NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
    • NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
    • NUM LOCK+Minus sign (-) (Collapse the selected folder)
    • LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
    • RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
    Shortcut keys for Character Map loadTOCNode(2, 'moreinformation'); After you double-click a character on the grid of characters, you can move through the grid by using the keyboard shortcuts:
    • RIGHT ARROW (Move to the right or to the beginning of the next line)
    • LEFT ARROW (Move to the left or to the end of the previous line)
    • UP ARROW (Move up one row)
    • DOWN ARROW (Move down one row)
    • PAGE UP (Move up one screen at a time)
    • PAGE DOWN (Move down one screen at a time)
    • HOME (Move to the beginning of the line)
    • END (Move to the end of the line)
    • CTRL+HOME (Move to the first character)
    • CTRL+END (Move to the last character)
    • SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
    Microsoft Management Console (MMC) main window keyboard shortcuts loadTOCNode(2, 'moreinformation');
    • CTRL+O (Open a saved console)
    • CTRL+N (Open a new console)
    • CTRL+S (Save the open console)
    • CTRL+M (Add or remove a console item)
    • CTRL+W (Open a new window)
    • F5 key (Update the content of all console windows)
    • ALT+SPACEBAR (Display the MMC window menu)
    • ALT+F4 (Close the console)
    • ALT+A (Display the Action menu)
    • ALT+V (Display the View menu)
    • ALT+F (Display the File menu)
    • ALT+O (Display the Favorites menu)
    MMC console window keyboard shortcuts loadTOCNode(2, 'moreinformation');
    • CTRL+P (Print the current page or active pane)
    • ALT+Minus sign (-) (Display the window menu for the active console window)
    • SHIFT+F10 (Display the Action shortcut menu for the selected item)
    • F1 key (Open the Help topic, if any, for the selected item)
    • CTRL+F10 (Maximize the active console window)
    • CTRL+F5 (Restore the active console window)
    • ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
    • CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
    Mar 29, 2009 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
    I'm getting inaccurate letter entry on the letters I type. For example, when I type a B an M appears - I'm noticing it on the bottom row of letters at this time. Solution?
    Are you sure you pressed the correct location on your screen???
    If so, you may need to calibrate the screen.
    Do this:
    Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
    Touch screen sound
    Its very simple actualy, you just need to go to the profiles and select your favorite profile and set Touch reaction to "No Feedback"
    That should solve any sounds playing while your selecting items.
    Jul 07, 2008 | LG KU990 Viewty
    Touchscreen offset
    Here's what you do: Turn off the gps. Then, hold the power button for approximately 30 seconds. The calibration screen will appear. Follow the instructions to re-calibrate the touch screen.
    Feb 26, 2008 | Garmin StreetPilot C320 GPS Receiver
    Garmin StreetPilot C330 GPS Receiver Logo
    71 people viewed this question
    Top Garmin GPS Experts
    Marvin
    Marvin
    Jean-Luc Steffann
    Sheldon Dedek
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
