Question about Linksys : WET54G Wireless-G Ethernet Bridge (NELIWP19)
Making a wrt54gc wireless router work with a wet54g bridge
I have followed the directions and can't seem to get this right. I have been at this for 2 1/2 hours now.
I have connected it to the WRT54GC wireless router, I set the ssid on the WET54g to linkysys3 as is this in my router. When I hook it to the device i want to have connect through this network bridge it will not connect to my network.
  • Pat Batta
    Pat Batta May 11, 2010
    your issue is not clear title i'm reading says:
    Making a wrt54gc wireless router work with a...
    var g_tryMail = 0;
    function addthschng()
    if($i('at_email') != null)
    Problem Solver:
  • 13 Answers
You shouldn't have to enter your SSID unless you have it hidden. Also, make sure you have the correct encryption set on both sides. WEP/WPA/WPA-2 for the Security type and TKIP/AES for the Encryption type. They need to match your router.
Also, you need ot make sure you are entering the correct IP/gateway/subnet mask address or have DHCP enabled.
Good luck
Posted on Feb 10, 2009
I need to stop others outside using my internet
you need to turn on password based encryption (aka security) that will turn your unsecured wireless network into a secured one.
open a browser window and then type or and enter your router settings. change settings including password. unless you've set it up differently and actually have a username and password, leave the username space blank and use "admin" as the password. that's often the default password on a linksys. linksys has a great support page. they have the drivers, manuals, the works.
your specific page for the drivers and the manual for your router which includes specific info including password, setup procedures, explanation of the various settings, how to do a hard factory reset, etc. is here - click on the download button below the picture
Oct 09, 2010 | Linksys WET54G 2.4 GHz 802.11g Wireless-G...
My WRT54GC router suddenly stop passing internet through it after 4 years of uninteruped service. But all the LED s are on as they should be. I can not get either wired (my desk top) or wireless (lap top)...
Has your modem been hard reset recently? if so, it may require that you bridge the modem out to work with the router- ESP. if you use Verizon DSL. If so, contact your ISP, and ask for assistance in bridging out the modem.
Oct 03, 2010 | Linksys WRT54GC Compact Wireless-G...
Cant acess the set up wizard
First you will need to check the wireless settings of the router. If you don't know the wireless settings of the router then you will need to open the set up page of the router and get the wireless settings. You will need wireless network name ( SSID ) , wireless channel, type of the wireless security and wireless network key or passphrase.
Click Here to know how to check the wireless settings of the router.
If you know the wireless settings of the router then you will need to open the set up page of the WET54G and put the same wireless settings on the wireless briidge.
To access the set up of WET54G Click Here
Feb 18, 2010 | Linksys : WET54G Wireless-G Ethernet...
So I have a little problem. I'm trying to find out how to connect 2 wireless routers together from across the house. The internet side is connected to a Linksys wireless router (WRT54G). This is located in...
you need a wireless ethernet bridge(like wet54g/wet610n) which will grab signals wirelessly from u're primary router wrt54g,& then a ethernet cable from wireless bridge will be connected to one of the lan port of u'rs netgear router(otherwise u will not be able to do file & printer sharing between 2 routers)Remember,the ip address of all 3 devices shold be of same class.
Jan 02, 2010 | NetGear WGT624 Wireless Router
Wet54g will propperly communicate to a cisco 1310
make sure you switch anything that says 'proprietary', or is just not standard 54g with the wireless settings.
Some manufacturers will put in auto-discovery services that only that same manufacturer of wireless access point will understand, this can sometimes cause problems for bridge communication.
Mar 20, 2009 | Linksys Wireless-G WET54G 802.11g/b...
I was asked about the password
Hi rsmagdasoc,
Did you run the setup CD before? It might have been that you had change the password from there.
Sep 15, 2008 | Linksys Wireless-G WET54G 802.11g/b...
WET54G stops working
well first off u prolly got hacked, he prolly made a backdoor by now, if he changed the settings on your bridge i reccomend resetting the device to factory defaults then updating the firmware, then obtain a physical copy or digital copy of the book "wireless hacking for dummies" not saying that u r adumb or any thing but this is really good resource to teach u to tighten up your security.
May 09, 2008 | Linksys Wireless-G WET54G 802.11g/b...
Linksys wireles G enternet wet54g
The settings on that bridge(the far away one) might have been reset somehow. Try to reconfigure it, you can contact the manufacturer to help you set it up
May 08, 2008 | Linksys Wireless-G WRT54GS Router...
Unable to get my WET54G up and running
Make sure that you routers IP range is setup to handle the IP address of your PC.
Feb 02, 2008 | Linksys Wireless-G WET54G 802.11g/b...
Computers & Internet Logo
405 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
