SOURCE: how to change sparkplugs on honda shadow motorcycle
VT1100 has two spark plugs per cylinder, the sparkplug caps are snap-ons so they're fairly easy to remove. You need a spark plug socket wrench to remove and replace the spark plugs.
SOURCE: I changed oil in my 2005 Honda shadow sabre, and
add some more. Very common to require a top up after first filling to correct level
SOURCE: what is the best oil for my 2005 honda shadow
Honda Oil ... available at your Honda Dealer. find him at http://hrca.honda.com/
SOURCE: how to check water level for my 2002 honda shadow sabre
the easiest way to see the coolant level is to shine a flash light up from underneth the plastic tank, located between the the engine and rear tire. now follow the fillcap located above the right side passenger foot peg. there will be a vertical one inch slot in a chrome cover. behind this slot are two very faint lines . one low, one high about a half inch apart. I found that carefully tilting the bike to the right makes it easy to see just how low the coolant is. a really small diameter piece of tubeing jammed into a tiny funnel will prevent a mess when topping off.
SOURCE: 2002 Honda SHADOW SABRE It wont stay running unless it's
More information is needed - aftermarket pipes? any carb work been done to it? is fuel fresh? air filter condition? how are the plugs burning? oily black, white/tan?
