Question about Husqvarna Viking 1
Viking is skipping some stitches when it is on zigzag
I noticed the last couple of times I used the zigzag stitch that every few inches it would do straight stitches instead. I was sewing thick fleece last time and the top thread was also breaking often. The machine is about 25 years old and I haven't ever needed repairs or gotten it "tuned up", whatever that means!
  • Anonymous Mar 12, 2014
    I need to change stitch from straight stitch to zigzag stitch
    New Friend:
  • 186 Answers
These are great machines but after 25 years there are probably a lot of problems that need to be fixed. It could be as easy as buffing or replacing your needle plate. If you take it in for service (and can actually find someone who is good with this machine) you will probably pay $200 to $400 to get it back to 'factory' state.
Posted on Jan 30, 2009
The User Manual does not have a complete stitch guide. Does my Huskystar 207 have a stretch stich?
FWIW, a stretch stitch is simply a stitch that stitches forward a few stitches and then reverses for a couple and then stitches forward again. Having had a machine with a stretch stitch, I found that using a zig-zag is just as effective and uses much less thread as well as less time at the machine. If the fabric is very stretchy, you can merely decrease the stitch length and increase the stitch width to give the stitch enough space to expand with the fabric without popping.
Viking Huskystar 207 Manuals
Jun 22, 2017 | Sewing Machines
Singer 6510 3 dial machine - no "S" on stitch length dial selector
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Dec 23, 2014 | Singer 6510 Sewing Machine
Can someone tell me what the letters on the presser feet that come with the machine correspond to? Which one is for what?
A is the standard stitch foot
B is for a wider stitch such as a zigzag stitch
C is for manual buttonhole
P is for Quilt piecing foot (1/4 inch and single hole)
R is for Embroidery
H is a non-stick glide foot (use for vinyl)
J is an edging foot
D is a Blind Hem foot
S is for omnimotion stitches (stitches that move left to right and backward and forward.
Check the Husqvarna Viking website under Accessories tab for further information. http://www.husqvarnaviking.com/us
Hope this helps.
Oct 14, 2014 | Husqvarna Lily 540 and 550
Trying to use zigzag stitch and it keeps skipping stitches
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Apr 08, 2013 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
Basic Maintenance Tension Skipped Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
Sewing Machines Logo
179 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
