Question about Samsung HCL4715W 47" Rear Projection Television
Power light flashing
Hey,
I have a Samsung HCL4715W that has a flashing power light. I've been doing a little digging and I haven't come up with anything yet. I noticed the TV had been previously serviced. So far I've just been looking for shorts in the power supply but have come up empty so far. I noticed that the switcher for the power supply gets awfully warm but has no shorts on it after I pulled it out. Let me know what you think. Thanks
  • 5 more comments
  • Andrew Hawkins
    Andrew Hawkins Jan 29, 2009
    I unplugged the convergence yokes and it still is flashing the power light
  • Andrew Hawkins
    So the problem is the sub deflection board? To clarify, is that the one that has the AC cord coming in on it? It also has the switcher on it......I would rather not replace a whole board so as long as I know that the problem is most likely on that board I will do more in-depth searching to find the bad part. Thanks
  • Andrew Hawkins
    Thanks for your guidence. I am suprised that you actually have that board. If you have any more advice I would greatly appreciate it otherwise.....FIXYA!!
  • Andrew Hawkins
    Andrew Hawkins Jan 30, 2009
    Well, I pulled the board and I have found that Q473 has 44 ohms from base to emitter. But I can't figure out what exactly the part it is. It has C4125 1L3 on it. I would like to find this part or a datasheet so that I could cross reference it with a different equal part. Thanks.
  • Andrew Hawkins
    Thanks!!! I wish that I would have made that another post so I could give you another FIXYA!!! In the future I will try to make them separate. Thanks again
  • Andrew Hawkins
    Andrew Hawkins Mar 09, 2009
    So I finally got my 2SC4125 and just installed it and I just got it back together and it still doesn't work. Is there anything else you can think of?
  • Andrew Hawkins
    Right now I'm actually shooting in the dark. Also, I made a new post so we can start a new dialog in there so you can get more credit for it. Thanks. I will check the standy voltages are there specific places I should check?
  • Samsung Master
  • 8,617 Answers
Unplug the convergence yokes then try powering up the set. If it powers up the ICs are bad.
Posted on Jan 29, 2009
  • 4 more comments
  • Sonny Berry
    Sonny Berry Jan 29, 2009
    replace the sub deflection board that has all the misc. power supplies on it.
  • Sonny Berry
    The sub deflection board is the board with the HV transformer on it. hears a picture of it
  • Sonny Berry
    Sonny Berry Jan 30, 2009
    Thanks. yes I have access to most boards for just about all televisions where I work, as I have done just large screen TV repair for about 30 years now. If you need assistance please let me know.
  • Sonny Berry
    Q473 is a 2SC4125 Horizontal output transistor it will sub to a NTE2365 Minor mechanical differences in the NTE sub, But it will work in most applications. But the 2SC4125 is a toshiba trans so it should be readily available.
  • Sonny Berry
    youre welcome and thanks. I am here if you need more assistance.
    Slinteriors
  • Sonny Berry
    Sonny Berry Mar 09, 2009
    Do you have the schematics to which you can check to see which voltages are not up to specs? For the led to be blinking it has to be the operational supplies, So the stand by voltages must be ok
Samsung refrigerator has a 33e code flashing
That sounds like a power glitch. Try pressing and holding the power freeze and power cool buttons at the same time for about 8 to 13 seconds and see if it clears.
If that doesn't do it, let me know and I'll dig up the Fast Track on it.
Nov 01, 2014 | Samsung RF265AA Bottom Freezer French Door...
I Have a Sumssung HCL4715W Tv timer flashes 40r 5 times and Tv turns off
A constantly blinking light means shutdown.
The most common issue in this model is convergence-----if the convergence circuit has railed (this means shorted parts) it can cause the set to do what you describe.
Before I suggest a course of action----what is your skill level with electronic repairs? Can you solder and or do a visual inspection?
SD TECH
Oct 28, 2011 | Samsung HCL4715W 47" Rear Projection...
My Samsung HCL4715W will not turn on.....can it be reset or does it need to be replaced.
Your problem is do to shorted Convergence Ic's which will not let the set power up until problem is rectified. You have a very reliable set there. The Ic's will cost about $25.00 for the pair and a tech can install them reasonably cheap. I do recommend repairing it.
Nov 26, 2010 | Samsung HCL4715W 47" Rear Projection...
Samsung LN40A330 will not power on. LED on power button just flashes steadily. Power cord is good. Any ideas?
A couple ideas for you and maybe a solution let see!
The power button blinks because the inverter on the TV has given out the inverter is for the back light on your lcd display now the repair is not what I call a simple one if this is under warranty I suggest you bring it in and seek out that warranty otherwide www.partstore.com will help for the part you might need a service manual so you can learn how to put the part in if you not intrested in doing the repair yourself plan on digging into the wallet a little deeper for the labor on this.
I work hard to help find a solution please express your Thanks by leaving positive feedback and ratings for your FREE answer.
Thanks for visiting fixya.com
Nov 17, 2009 | Samsung LN40A330J LCD TV
Power light is on T.V. is not responding
u may have a bad convergence board stk392-040
Apr 30, 2009 | Samsung HCL4715W 47" Rear Projection...
Tv will not turn on
If your convergence ICs are bad set will not come on 1 of the ICs controls Off/on STKs big black ics replace both STK392-020s use 040s For Parts call 1-800-223-3205. www.electronix.com
Jan 03, 2009 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W will not power on
At five years old, I doubt it will be worth replacing the power supply , a picture tube or two and possible the signal board. Cut your loses and get a new set.
Aug 25, 2007 | Samsung HCL4715W 47" Rear Projection...
TV won't power on
Disconnect the convergence board and see if the set comes on. If it does, and it probably will, replace the convergence board or the convergence amp IC's. Good Luck
Jul 26, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
191 people viewed this question
Henry  Thomas
Henry Thomas
