Question about Logitech QuickCam Connect Webcam
Communications helper.exe could someone please tell me why the Communications helper.exe that runs with the quickcam connect continues to keep on using up memory even when the camera isnt in use, the only way I seem to rectify this, is if i turn it off in task manager but then obviously the camera wont work at all then, is this a problem with all Logitech cameras, or just this one? as apart from this the camera works well, thanx for any replies, Simon
  • JavaDevil007 Nov 28, 2008
    When starting my computer I get the message "communcations helper.exe is not working". I have a skype webcam by logitech and have contacted them, to no avail. When I try turn on the camera it says that the cam is not plugged in, which it is has been tried in different ports. Does anyone have a solution as I am now desperate. Thanks - Graham, South Africa
  • 102 Answers
Sounds like Communications helper.exe its some type of driver and/or windows service. This would be the same for all cameras and other computer devices that utilize the Communications helper.exe driver/service. It might be possible to stop Communications helper.exe or its alias from running at start-up but its not recommended as you probably will loose functionality of the camera.
Posted on Jul 27, 2007
    President:
  • 2,961 Answers
The problem with this camera driver is that the helper.exe is used to retrieve info from the net about new drivers and updates and it also sets up the sound and everything else to do with the camera, if this is dissabled; as you rightly mention you cannot use the camera so unfortunately you have to keep the file running.
Hi, i tried using skype with logitech quickcam but pup-up told me this message: Another application (communications helper.exe) tries to access Skype but we are not able to respond. Try to restart the...
The easiest thing to try is just disabling "Communication_Helper.exe" in Skype. Go to Skype / Tools / Options / Advanced, and at the bottom you will see text that says "manage other programs' access to Skype". Click that and you'll get a window, which should list "Communication_Helper.exe". Deny access to that (don't remove it, because it will just come back), and try your call again.
Be aware, however, that this is only a quick fix and does not solve the problem. When Logitech and Skype have problems like this, they can be pretty big ones, and can cause performance problems as well as interface problems.
The Logitech QuickCam application software is not required for the Logitech Camera to function properly in Skype. If you are not using the QuickCam application for anything else, then you should seriously consider uninstalling it.
That will solve this problem, and various other potential problems and performance issues, permanently.
To uninstall it just go to Control Panel / Add or Remove Software (or Uninstall a Program in Vista/7), find "Logitech QuickCam" (NOT Logitech Camera drivers), and uninstall.
Then reboot to get rid of the background processes, and test Skype again.
May 05, 2011 | Logitech QuickCam Connect Webcam
Photo easy 255 driver
Hi, Go to below link:- http://www.xpvistasite.com/photo_easy_255_9901.htm and click on the Download file button to download the driver.
Thanks! mannu_rakesh
Aug 24, 2009 | Office Equipment & Supplies
How do i install my quickcam communicate STX
Hello my friend, kindly follow the following steps:
1. Insert the CD driver of your Logitech Quickcam
2. Goto the CD/DVD drive and find the setup.exe and run it.
3. Follow the installation guide wizard to complete the installation process.
4. If the system requires to restart your computer then restart it otherwise try to test the Webcam to see if you have installed the right and correct driver.
Thanks
Jul 28, 2009 | Logitech QuickCam Communicate STX Personal...
Skype sound test
This means you need to tweak the volume levels a little and maybe also change the recording levels.
Echo is a common thin with VOIP communications and it may not go away fully but tweaking your levels shoul minimise it.
Also do not use VOIP type communications on low speed connections
Jul 28, 2009 | Logitech Quickcam Chat Webcam
Swann Communications DVR-4-Net camera card won't run?
What spyware software did you run? Do you have the name of the software?
many spyware software available on the internet are actually viruses and malware.
Download the file combofix from the link below and run it on your system. This should remove all viruses and errors on your machine
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
Mar 11, 2009 | Swann Communications DVR-4-Net (SWRPCDVR4)...
LPVrcSrv.exe
The genuine LVPrcSrv.exe file is a software component of Logitech QuickCam by Logitech.
A background process that starts with Windows, this application is the core file that allows your webcam to function properly in Windows. It communicates between the hardware driver and the operating system, allowing video to be seen and recorded with the QuickCam software. Located in Switzerland, Logitech creates a variety of peripheral devices for personal computers. Their Quickcam software supports the Google produced internet TV service Google TV.
Click to Run a Free Scan for LVPrcSrv.exe related errors
LVPrcSrv.exe file information LVPrcSrv.exe process in Windows Task Manager The process known as Logitech LVPrcSrv Module or LVPrcSrv Module belongs to software Logitech QuickCam or Logitech or Logitech Camera Software or Logitech Webcam Software or Logitech Process Monitor or Acer OrbiCam by Logitech (www.logitech.com).
Description: LVPrcSrv.exe is not essential for Windows and will often cause problems. The LVPrcSrv.exe file is located in a subfolder of "C:\Program Files\Common Files". Known file sizes on Windows 10/8/7/XP are 81,920 bytes (32% of all occurrences), 86,016 bytes and 13 more variants.
The program has no visible window. It is not a Windows core file. It can change the behavior of other programs or manipulate other programs. LVPrcSrv.exe is able to monitor applications and manipulate other programs. Therefore the technical security rating is 47% dangerous, however you should also read the user reviews.
Uninstalling this variant: In the event of any problems with LVPrcSrv.exe, you can also do the following:
1) uninstall Logitech QuickCam or Logitech Webcam Software software via Windows Control Panel/Add or Remove Programs (Windows XP) or Programs and Features (Windows 10/8/7)
2) ask Customer Support to assist you
3) find out if there is a newer version available.
Jun 17, 2017 | Logitech Webcam
Sony ericsson handsfree
not a radio communications issue
Aug 20, 2017 | Sony HBH-65 Professional Headset
Logitech QuickCam Connect Webcam Logo
4,852 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
