Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
My MOEN shower faucet will not shut off the shower.
The handle seems to be stuck in the open position. I tried pushing as hard as I dare and it will not push in. Any ideas?
  • Anonymous Mar 22, 2014
    metal handle on shower faucet doesn't stay
    Scholar:
  • 35 Answers
You should take the handle off. To do this, Turn Off the water supply to the Shower. Remove the handle with a screw driver or alan wrench. Now you can see the assembly. There should be a nut or some kind of threaded ring holding in the GUTS of the Faucet. Gently pull out the unit (Remember or write down how it goes together). Now visually inspect it and see if you can find an obstruction or broken piece that is causing it to stay open. If there are broken parts you can get them at a Plumbing Supply Store. If every thing seems fine and it seems to work when you have it out, then put it carefully back together, turn on the water and try it again. This has worked for me a few times in the past, Just taking it out, cleaning it , and putting it back together......Good Luck......I hope this helps you with this situation....Joe
Posted on Jan 29, 2009
I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
May 13, 2010 | Moen & One Handle Tub & Shower Faucet
How do you turn off the moen 82691 shower valve when new.
The stem in faucet may be in faucet upside down . you can try taking handle off remove nut that holds stem take it out make sure
you turn water off before doing this.
May 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
When I push the faucet to off I get med fast
push down the tub-spout lift rod and it will empty the remaining water that is between the shower valve and the tub spout
Mar 10, 2010 | Moen Posi-Temp Single HandleTub And Shower...
The shower control valve for my moen 2995 faucet is stuck in the shower position. how do i remove it?
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Sep 27, 2009 | Moen 2995 Chateau Three Handle Tub and...
Moen Model no. 82683 does not close
It sounds like the handle needs to be replaced. the stop place is in the handle. You can
Aug 30, 2009 | Moen & One Handle Tub & Shower Faucet
Single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Feb 23, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Single handle moen shower not turning far enough
it is your shower cartrige. ace hardware $45. hot always goes first. just check if it is a posi-temp or moan trol
Dec 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
946 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
