Question about LG 42LG50 42 in. LCD HDTV
Single verticle line running through screen on lcd flat screen
Hi, we've had our LG LCD flat screen for about a year now and recently we're starting to see a perfectly straight vertical line running through the screen, when we squeeze the casing of the t.v it disappears, however, when pressure is released it returns.
It's there most days but not all the time?.
Is this repairable or is our t.v done for?
It's kind of annoying when you're watching it?
Thanks in advance
Emma x
  • Anonymous Mar 11, 2009
    I have the same problem... If i were to get the tv calibrated, would that fix the problem?
    Champion:
  • 211 Answers
Hi Emma,
It could be a connector problem between mainboard and your display.
Often it is repairable, but if your tv is 1 year old there's still some waranty left.
Kind regards,
Gerard
Posted on Jan 29, 2009
Hi in house expert,had a 14 inch sharp tv with a verticle line I change the transistor AN5522 and the 25v 1000 uf capasitor but verticle line still there,it could be what guys?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 21, 2016 | Sharp Televison & Video
Hello, I bought an LG 47LH50 HDTV exactly 1 1/2 years ago. Black horizontal lines suddenly appeared one night after getting home from work. Over the past two weeks I've seen it go from 3 lines, to 4...
Hi, I purchased the same model in November 2009. About 2 weeks ago a single horizontal line appeared. Each day another appeared until today when the video went out. Now it displays bands of vertical colored lines like a pastel colored rainbow. Did you find a solution to the problem?
Jun 04, 2011 | LG 47LH50 47 in. HDTV LCD
Blue verticle line is displayin
The blue line is most likely the result of your monitor's screen going bad. One thing you can try is disconnecting and re-connecting your video cables to make sure it's tight and has a good connection. This probably won't help, but it's worth a try. You may also want to connect the monitor to another computer to see if the blue line stays, or goes. If the blue line stays with another computer connected, the problem is inside the monitor. If the line goes away, you should replace/repair your computer's video card and/or cable. Otherwise, you need to replace/repair your LG monitor.
Mar 03, 2010 | LG Flatron L1750S 17" LCD Monitor
Dynex LCD Tv with a single colored verticle line on the screen.
That is either going to be something simple like a connector being dirty or not seated correctly or a problem in the monitor itself.
Unplug and reconnect the cables a few times.If you are lucky this will fix it. Usually however this indicates a problem either in the video section on the monitor board or a panel edge connector problem.
Check if you have any warrenty left as this will be covered. Keep in mind that repair costs if you pay for them will be a good chunk of buying a new replacement.
Dec 30, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
LG Model# RT -42PX11,screen is not working.. shows verticle line color pattens and turns shades of black when a button is pressed
My LG RT-42PX11 after a few minutes the screen starts to flicker and colors go psychedelic and after some time no picture at all
Oct 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Verticle line running down the screen.Thin verticle line running down the screen.
You have a defective LCD panel. The only way to fix it is to replace the whole LCD panel. It is the most expensive part in the TV (usually $500-2500) depending the make, model, and size. It is also time consuming as you need to take the whole TV apart in order to replace that part.
Oct 09, 2009 | LG Televison & Video
I have a Hitachi LCD 81cm TV that has developed a
Hello Matt,
The most likely cause is a failure of the TAB on the LCD panel inside the TV.
The only fix is too replace the LCD panel itself.
If it is under warranty then you should return it, if not, then you will have to replace the screen or live with it.
Unless you can find the screen cheaply you will find it is not cost effective to repair, just use it as a 2nd TV or a PC monitor.
Sep 06, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Problems with my Mitsubishi hd1080
Most likely you are looking at conversion chip problem. The replacement price on these can varry widely. It may be cheeper to look into purchasing a flat panel lcd or plasma tv.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Laptop lcd screen
that's not a firmware issue..your lcd is starting a slow decay to final unhappiness..
you can try the old driver downloader trick, but it's just a matter of time now.
Feb 21, 2008 | LG Flatron L1750S 17" LCD Monitor
Green verticle line on Maganavox flat screen tv
Most likely it's due to the LCD panel assy failure. It may cost you as much as to buy a new tv. The LCD panel is very expensive in retail market.
Jan 24, 2008 | Samsung LTN1535 15 in. HD-Ready LCD...
LG 42LG50 42 in. LCD HDTV Logo
287 people viewed this question
Computer Repairing
Computer Repairing
