Question about Video Game Consoles & Games
Geoff Crammond's F1 GP4 (Microprose)
Hi mate.
I have this game since it came out on the market and from awhile ago I started do experiencing some problem when running the game - it simply crash without notice. I don't know if there's a bug or what, but the fact I've run it on olders laptops and never had the problem.
Now I have a Toshiba Tecra A7 with a ATI Mobility Radeon X1400 (512MB)... it run better, obviously, but it crashes!
I must do an upgrade on ATI but strangely I can't do so, the system doens't allow it (???).
Do you know if there's any upgrade to the game that my solve the problem and where I can find it?
Thanks!
Cheers from Portugal
Renato
  • 23 Answers
You can upgrade the your game .
go to the game site and there you download the upgrade
Posted on Feb 12, 2009
I forgot my phone lock code.i cant open my mobile.
gday mate, geoff here, well the best i can advise is try it 3 times till it asks for a PUK ( Pin Unlock Code ) then contact your phone carrier to get this, it should be an 8 digit code, hope this helps,geoff.
Feb 11, 2012 | Cell Phones
2002 gmc truck water pump making noise how to stop noise
Gday mate, geoff here, could be the belt mate, try a bit wd40 / rp7 / crc, on the belt just a quick squirt or rub some soap on the V of the belt ,if noise persists could be the pump itself worn, does it have any lateral or dynamic play when wiggled, while engine off of course, hope this helps , geoff.
Feb 11, 2012 | GMC Sierra 1500 Cars & Trucks
Fuel too lean on bank 2 on 1999 ford f150 6 cyl. 4.2
Gday mate, geoff here, well there should be at the end of each rail a vauum hose on a metal disc,daiphram, best to start with connections there, actually disconnect the vacuum hose while running and check for difference, thats where i would start, being computer controled however there may be a need to check computer / fault diagnosis codes,geoff.
Feb 11, 2012 | Ford Cars & Trucks
THE BACKGROUND WALL PAPER IN MY E-MAIL HAS TO GO!!! HOW???
Gday mate,geoff here, just logged into my Gmail and now i will run you through it, 1st at the top of the payne to the right of where you sign out is a little cog/flower, click on it, this will enter you into the settings menu, it will start on General, dirrectly under General is Themes, clik on that and make your choices, enjoy, ( i use the Ocean themes, as it changes during the day ) geoff.
Feb 10, 2012 | Google Gmail
Can i get a working manual for my 1997 savana van
Gday mate,geoff here, the best i have found in manuals over the years are the "Haynes" they explain and disassemble reassemble the vehicle methodically, hope this helps,geoff
Feb 10, 2012 | Cars & Trucks
I have had this game probably since it first came out. The game won't play now, I have installed it but when I press the icon to start the game it goes thru the introduction then just shuts down
I have several programs that will not longer work because they were developed for old versions of Microsoft. It probably is not compatible with the newer Microsoft version you have.
Dec 04, 2017 | MicroProse Star Trek: Birth Of The...
Virtual karts in dosbox keeps showing sound config screen
Erik,
Thank you for asking me directly to help you with your problem. However, either the question you are asking is not within my area of expertise (I am an automotive repair technician), or the question is incomplete and does not contain enough information for me to help you.
Dec 28, 2011 | MicroProse Virtual Karts for DOS
I am trying to install master of orion II on a windows 7 64 bit operating system and it won't open, because DPLAY.dll cannot be found. I have downloaded the driver, put it in the sys32 folder, the...
First install MOO2 on a computer were it runs and copy the entire micropose directory to the program files (x86) directory.
Then copy the dplayx.dll file from the windows\sysWOW64 directory and renamed it dplay.dll and put it back in the sysWOW64 directory (be sure the dplayx.dll file is still there) or if you have the 32 bit version it should be found in the system32 directory (I am guessing, but you will need a dplay.dll)
Found this great post about getting MOO2 to run in Windows 7, and even with the compatibility enabled it still has a graphics palette problem. The reason is because of Windows explorer, and to fix the problem you need to disable explorer.
I know this can be a little too much for some, there is an easier way.
Simply create a notepad file on your desktop, and paste the following.
(If you have 32-bit version of Windows 7.)
TASKKILL /F /IM "explorer.exe"
cd C:\"Program Files"\Microprose\Orion2
start /w C:\"Program Files"\Microprose\Orion2\Orion95.exe
start C:\Windows\explorer.exe
(Copy and paste below if you have 64-bit)
cd C:\"Program Files (x86)"\Microprose\Orion2
start /w C:\"Program Files (x86)"\Microprose\Orion2\Orion95.exe
Make sure you rename the text file to Moo2.bat, then it will launch Moo2 and disable explorer. Moo2 plays perfectly fine this way, even without any of the compatibility enabled.
The Batch file will also restore your explorer when you exit the game.
Alternatively, you could use DosBox to play the game.
Click Here for instructions
Hope this helps,
G33k
May 11, 2011 | Spectrum Holobyte Masters Of Orion 2 -...
Hi, I have a whirlpool AWO/R4205 that will not fill with water and just tries to drain when starting any cycle and never moves on. The water Tap closed light was on earlier but has now gone out. I does...
all washing machine perform a drain cycle before any wash - that's just the norm geoff.
I'm assuming you'll be getting an F1 fault code
Sounds like the inlet solenoids have gone. get your multi meter on the solenoids - the readings should be around 3.4kOhms - 4.4kOhms
If this proves ok then you'll need to do a 'live test' on the power going to the solenoids at the start of the cycle. (Take all precautions so as not to give yourself a shock) you'll expect a reading of 180-230v
If the resistance across the solenoids are between the given values and you're getting power to them then the fault lies with the water supply.
If there is no power going to the solenoids at the start of a programme then you need to check wiring back to the CCU for continuity. If the continuity proves ok then you'll need to replace the programme timer mate
Feb 08, 2010 | Whirlpool AWM6140 Front Load Washer
Video Game Consoles & Games Logo
1,020 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
