Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Noisy F&P fridge freezer
Sounds like small icecubes flyind around at the back and bottom of the freezer compartment.From the back the rocktrowing sound is at the bottom left.a.s.a you open the door it stops.there is a fan between fride and freezer Is there another fan at bottom?
  • ungawa Dec 26, 2007
    Hi there -
    I too have this problem (though with an E402blw) .. but after I got rid of the ice build up in the freezer - I noticed that the (convection?) Fan that sits at the back of the freezer had a blade broken off .. Sure enough when I put the thing back together it is still sounding like there is a pneumatic drill going off in there !! As the fan is mounted on rubber struts - is the fan running off centre with the blade missing ? - Is there any way of tricking the fan to start up with the door open ?
    Thanks for any help ....
  • Anonymous Mar 30, 2014
    need some help
  • 69 Answers
Most of f&p make this noise its most annoying, but could also be ice buildup on the fan blades, creaking and cracking is normal as the pipes expand and contract is these thin foamwall fridges, not nice fridges, insulation has been compromised to lower cost, they work twice as hard at keeping cool
Posted on Sep 23, 2007
  • James sMITH Sep 23, 2007
    forgot to mention.... modified fan blades are avialable that are supposed to not produce noise or ice buildup, you need to see your agent
  • Cathy Wright
    Cathy Wright Dec 15, 2016
    I have same problem, Have had mine for 15 years no problem until last summer, had fan and element replaced but just recently been making very load noise like things flying around inside but stops when you open the doors. It seems to be working ok other than very annoying very load noise. Any ideas?
SOURCE:
Temperature sensors
I have an E402 fridge (403 litre model with freezer on bottom) . I just dismantled the freezer back wall due to a bad defroster element and noticed that on the back wall of the freezer is a small raised "cavity" or "slot" that the black thermostat fits into nicely. In my fridge, it is above the Collins coil and a bit to the right of centre(closer to the wire entry hole). Hope this helps
Feb 15, 2014 | Fisher and Paykel Active Smart E522B...
Hotpoint FFA60 - Freezer Fan not working
It sounds as if the fan motor itself has failed, & without the fan, only the coils will get cold. A replacement can be obtained from any appliance parts store, or from Hotpoint...check the website. If you are not experienced in appliance repair, I suggest you call a repair person , as some of the fans can be difficult to replace, & it is easy to cause additional damage.
Jul 06, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Kenmore 78302 refrigerator noisy fan
Good Job Nail i agree with thats a new change toward the word. Hopes you would never mind this. As i appreciate you work. You are always welcome post. The Queen Is wondering about it.
The Queen Full Episodes 2018 Mzansi Magic Online Free Video
Jun 18, 2017 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
RED TEMP WARNING LIGHT ON MOTOR RUNNING
I'm sorry to have to tell you that this sounds like a very expensive fault to fix!
Either your fridge/freezer has degassed (lost the refridgerant gas) through a small leak in the pipe system behind or inside the freezer compartment, OR the compressor (what you called the motor) has started to fail.
Either way, these are very expensive repair jobs. It's possible to replace the compressor within about an hour, but if your model is out of guarantee, there will be around a £50/60 Call-out charge and the compressor will cost between £75 and £150 depending on the model.
Alternatively, if the fridge/freezer has lost gas, the engineer would have to try to find the leak - this could be IMPOSSIBLE if the leak is within the pipework inside the back of the fridge or above/below the freezer compartment.
I'm sorry to say that it's looking like you may have to part with a lot of money - or say goodbye to the fridge/freezer you have!
Nov 17, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Zanussi fridge freezer frostfree ZX 57/3 W not working
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Hope this helps,
Sai.
Jun 12, 2008 | Zanussi ZX99 / 5 Bottom Freezer...
Fridge not working but freezer does
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Mar 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Freezer compartment
You need to defrost the whole fridge and at the back in the freezer compartment you will c a small drainage hole.. look for it.. The get a piece of say hanger wire and clean this pour some hot water from a kettle down it and then start your fridge up again. that should sort your problem out ... if not then its either a sensor or a board fault...
Dec 03, 2007 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge motor is very very noisy
It sounds like it could be ice around the fan motor. Unplug it and let it defrost for about 12 hrs with the doors open. Plug it back in and see if it has quit making the noise. If it did it probably needs the defrost timer replaced. Good luck. kstfas
Sep 29, 2006 | Hotpoint FFM90 Bottom Freezer Refrigerator
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
1,014 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Colin Stickland
Colin Stickland
Mark Davis
Level 1 Expert
Felizardo Erilla
Felizardo Erilla
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
