Question about Intel D845GVSR Motherboard
MOTHERBOARD PLEASE HELP ME ,I HAVE A MOTHERBOARD GIGABYTE GA-8 V M 800 M(478 PINS )I WANT TO KNOW THE MEMORY AND THE PROCESSOR TO USE ................... THANKS
  • 565 Answers
That mobo uses DDR400 PC3200 memory and a 800MHz. Front Side Bus (FSB) P4 processor. You can download System Information for Windows (free) here: http://www.gtopala.com/siw-download.html, or use a similar program to get the details of your machine. The Gigabyte website also has the manual for your mobo.
Make sure Hyper-Threading is enabled in the BIOS to take full advantage of the P4 proceessor
Posted on Jan 29, 2009
Motherboard + processor compatibility
Yes you can use the processor on your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Dec 23, 2013 | Gigabyte GA-8S661FXM-775 (4719331838096)...
My gigabyte GA-G31m-s2L motherboard has while i am switchon the board CPU fan working but no other response happen in my monitor please give me troubleshooting method so as to avoid to buy new...
First thing when diagnosing a desktop computer problem, is check the Power Supply.
Really.
A Power Supply with a weak voltage power rail, can also emulate software problems.
(Emulate software problems; The bad hardware (Power Supply), can also make it seem like it is a software problem. It isn't. It's a hardware problem -> Power Supply )
1) Is your computer dirty inside? This will make the computer not work, and also 'kills' Power Supply's.
They overheat, and components inside the Power Supply fail.
(Go bad)
Know this;
1) If ALL of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
Gigabyte GA-G31M-S2L?
http://www.gigabyte.com/products/product-page.aspx?pid=2693#ov
LGA 775 processor socket, and an Intel G31 motherboard chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
Scroll down to G31 in the left column.
Also go back to the Gigabyte Support page.
Click on the Support & Downloads tab.
(Overview / Specification / Support & Downloads / FAQ / etc)
Click on the blue - CPU Support List tab.
(CPU Support List / Memory Support List / Accessory )
Your motherboard can support Processors that use 35 Watts all the way up to 135 Watts.
Point?
If you have a Power Supply with a weak voltage power rail; you may see LED lights light, and fans spin; but there will NOT be enough power to turn the Processor ON.
Do you have a multimeter to test the 3 main voltages?
OR;
Do you have a KNOWN to be good, Compatible power supply; to use for a temporary test unit?
Also;
When working on your computer FOLLOW Anti-Static Precautions.
If you are not aware of what Anti-Static Precautions are, please post back in a Comment.
DO NOT work on your computer until you do.
Remove all Ram Memory modules. ('Stick')
Clean the gold plated contact pins with a pencil eraser.
If using an eraser on the end of a pencil; and not a solid eraser; refrain from letting the metal band of the pencil; touch the gold plated contact pins.
Rub across all gold plated contact pins, and up, and down. BOTH sides.
When finished use air to remove the eraser dust.
You can use a can of compressed air for computers, or air pressure from your mouth will be sufficient.
Handle the Ram Memory module by the BODY.
The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins.
The Body is coated with a see-through protective plastic,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
Reinstall the Ram Memory module/s. Plug the computer back into power. WAIT 1 minute, turn the computer on.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 02, 2013 | Gigabyte GA-G31M-ES2L Motherboard
What kind of RAM memory uses this motherboard
Gigabyte GA-5SMM - motherboard - micro ATX - Socket 7 - SiS530 specifications
  • General
  • Product Type Motherboard - Micro ATX
  • Cache Memory L2 cache - 512.0 KB
  • Chipset Type SiS530/5595
  • Max Bus Speed 100.0 MHz
  • Processor Socket Socket 7
  • Compatible Processors 6X86 , Cyrix MII , WinChip 2 , WinChip C6 , K6-III
  • Memory
  • Max Supported Memory 256.0 MB
  • Supported RAM Technology SDRAM
  • Supported RAM Integrity Check ECC
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 x PCI - Socket 7 , 3.0 x Processor - DIMM 168-pin , 3.0 x ISA , 2.0 x Memory
  • Storage Interfaces ATA-66 - connector(s): 2 x 40pin IDC
  • hope this helps
Aug 13, 2011 | Gigabyte GA-5SMM Motherboard
My gigabyte motherboard will support single chip 2gb ram and i have to upgrade my ram into ddr2 533mhz to ddr2 667mhz or 800mhz it is possible for my motherboard
Gigabyte GA-945GZM-S2 - motherboard - micro ATX - LGA775 Socket - i945GZ specifications
  • it looke like the supported RAM
  • Supported RAM Technology DDR2 SDRAM
  • Supported RAM Speed 533 MHz , 400 MHz
  • hope this helps
  • General
  • Cache Memory None
  • Chipset Type Intel 945GZ Express / Intel ICH7
  • Max Bus Speed 800.0 MHz
  • Processor Socket LGA775 Socket
  • Max Processors Qty 1.0
  • Compatible Processors Core 2 Extreme , Celeron D , Core 2 Duo , Pentium D , Pentium 4
  • Memory
  • Max Supported Memory 2.0 GB
  • RAM Features Dual channel memory architecture
  • Graphics
  • Graphics Controller Intel GMA 950
  • Memory Allocation Technology Dynamic Video Memory Technology 3.0
  • Audio
  • Type High Definition Audio (8-channel)
  • Audio Codec Realtek ALC888
  • Compliant Standards High Definition Audio
  • LAN
  • Network Controller Marvell Yukon 88E8001
  • Network Interfaces Gigabit Ethernet
  • Modem None
  • Expansion Slot(s) 1.0 x Processor ( 1.8 V ) - LGA775 Socket ( x4 mode ) , 4.0 x PCI Express x16 - DIMM 240-pin , 3.0 x Memory , 1.0 x PCI
  • Storage Interfaces Intel ICH7 : ATA-100 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s) , Intel ICH7 : Serial ATA-300 - connector(s): 1 x 40pin IDC - 2.0 device(s)
  • Interfaces 1.0 x Audio - Floppy interface - Mini-phone stereo 3.5 mm , 1.0 x Storage - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Audio - RS-232 - 25 pin D-Sub (DB-25) , 4.0 x Serial - VGA - Mini-phone 3.5 mm , 1.0 x Microphone - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style) , 1.0 x Display / video - IEEE 1284 (EPP/ECP) - 4 pin USB Type A , 1.0 x Audio - Line-out (center/subwoofer) - Mini-phone 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - Line-out (side surround) - RJ-45 , 1.0 x Audio - Line-in - Mini-phone stereo 3.5 mm , 1.0 x Hi-Speed USB - Line-out (rear) - 9 pin D-Sub (DB-9) , 1.0 x Audio - Input - Mini-phone stereo 3.5 mm , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 1.0 x Audio - 4 pin MPC
Apr 09, 2011 | Gigabyte GA-945GZM-S2 Motherboard
I have a gigabyte GA-M55plus-S3G Motherboard with a AMD Athlon 64X2 that wont start. Gives a burst of power to the fans and then shuts down. How can I tell if it is the MB or the Processor that is bad. The...
hi ripvanblinkl
processors do not give out easily which only means there is a 70% percent chance that this might be caused by a motherboard problem. This happened to myself. It turns on for around half a second and then nothing. I changed motherboards and now I am using the same processor on a new board. You may also want to check if the processor has any burn or overheat marks. Also check if all the pins on the processor are in tact and aligned. If all is good then there is a chance the board is already busted. Hope this helps
please let me know
janc30
Feb 16, 2011 | Gigabyte GA-M55plus-S3G Motherboard
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Gigabyte GA-8LD533 start up problem
My guess is that you damaged the cpu and not the mobo, done that myself once....unfortunate...it cost me an new cpu..
Good luck to you
Nic
Feb 10, 2009 | Gigabyte GA-8LD533 Motherboard
Motherboard does not startup
Please remove the CMOS battery & reinstall it after 15 minutes.
Jun 28, 2008 | Gigabyte GA-6BX7 Motherboard
Gigabyte GA-81EXW memory chips
Any 184-pin ddr ram should work on this. You can actually use pc3200 (ddr 400) ram as well. Pc2700 ram is ddr333, and a higher speed ddr ram like pc3200 will work just as well if not better than pc2700, it will simply go down to the speed that the processor requests the ram run at. It's all backwards compatible, faster ram can run slower if the computer needs it to run at the slower speed. Depending on the price you can find as long as you get 184 pin ddr ram either pc2700 or pc3200 with work fine with your motherboard. Peter
Oct 02, 2007 | Intel Motherboard
Intel D845GVSR Motherboard Logo
70 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
