Question about E-Machines eMachines Desktop PC
Ok i have a emachine c2280 we put a new power supply changed the ram and i have no video, there is also a red light next to the ram what isit..
  • 8 more comments
  • loan_officer Jan 29, 2009
    no it doesn't beep
    i didn't rebuild it..i just had to change the power supply..so i was checking the the ram to see if that could be it..but i dont get no video..
  • loan_officer Jan 30, 2009
    i have both and integrated and a card
    Ok thats what i thought i just wanted to make sure..Thanks for the help..
  • Dan rogers
    Dan rogers May 11, 2010
    If you don't get any video off the mother board or out of the expansion card i'm sorry to say but it is time for a new motherboard
  • Dan rogers
    Well this is what i found. I looked at a forum (link below) and it seems the power supply unit in these computers are troublesome and may have caused you some problems. I would follow the directions given in the forum. I do think that when your last power supply failed it took the motherboard with it. Again try what is listed and let me know if anything works for you
    http://www.geekstogo.com/forum/E-machine...
  • Michael Lucas
    Michael Lucas May 11, 2010
    On the eMachine C2280, that light is merely an "on" light... showing that your power supply is plugged in
    Is your video integrated or do you have a video card.
  • Dan rogers
    is the video card integrated in the motherboard?
  • Dan rogers
    I'm not sure what the red light is, May i ask why you rebuilt the computer in the first place?
  • Dan rogers
    Does your computer beep when it tries to boot?
    Master:
  • 413 Answers
Anytime. Just in case you there is any way you can get video to display. There is a setting in bios to change what controls the display adaptor. You might want to try to reset your bios and see if you can change this setting. Figure there is nothing you can hurt at this point.
Just remove the "watch battery" that is on the motherboard for a couple minutes and try to start the computer. Also you might want to look for some pins on the board that say something about bios reset jumpers. Normally you short the two pins then remove and boot. Sometimes you short-boot-shutdown-unshort-boot again.
I'm thinking though if you can get in there you can set your display to pci or agp or whatever kind of video card you have.
Posted on Jan 30, 2009
Pc desk the problem is the exit to the pc to
Would you like to re-phrase the question so that we may better understand ?
Aug 21, 2009 | E-Machines Emachine C2280 Power Supply...
PC STARTS BUT NO VIDEO SIGNAL IS PRESENT AT THE MONITOR
No don't flash the bios, this job is not for the faint hearted !!
Contact me for support at http://www.motherboardsrus.co.uk
where you will find an email address.
You may also like to look at the pages entitled "emachine and Advent support pages" these pages relate the shop built pc's such as yours and emachine,advent,medion,gateway,packard bell etc.
Contact me on my direct email address
Chris
May 31, 2009 | Gateway 310 S PC Desktop
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
I have a emachine PC. PowerSupply blew up. changed it still down
Dear,
ELECTRIC SHOK OR IMPROPER EARTHING IS DAMAGE POWER SUPPLY,MOTHERBOARD,PROCESSOR,RAM
HOW TO CHECK IT.
(WHEN CHECKING KEEP CAUTION :- REMOVE HARD DISK DRIVE POWER SUPPLY SOCKET)
1. check power supply watt 400/450 and same another power supply install and check it. if power supply change and system is working ok so problem in your power supply.
2. check CMOS cell on motherboard,(3 volt)
3. Bfore power supply changing check on mother board any capasitor is like as damaged or not.
OR check main chipset ic is marked as intel.whenpower on it is very hitting or
normal)if very hitting require to repair your motherboard.(intel chipset ic near cmos cell or pci slot,)
4. checking of ram on other pc (working or not)(one beeps coming or not,if one beep coming ram is working ok)
Feb 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Cant get any picture through the moniter tryed agp vidieo card and pci vidieo card still nothing the motherboard is out of emachines c2280 L7VMM2
Sounds like you have a bad power supply or motherboard. The power supplies in eMachines are not known for reliability, so try testing the system with another one. If you still have no video, you should replace the motherboard.
Dec 13, 2008 | EliteGroup L7VMM2 Motherboard
Can not power up
To my personal experience eMachine MB's dies a slow aggravating death. I have had 2 that went janky and would take about 15 power up tries to boot. Probably the situation you are in now.
Did the power supply you had go bad? I seem to recall a bit of an issue with some older machines in the 2k series that when the Power supply died it took out the MB with it.
Sep 28, 2008 | E-Machines eMachines Desktop PC
Emachine T2984 won't power up
First, Check your ram. If not seated, it will not power up. Also, do you hear a series of beeps or not? Need a better & more exact description of problem and what occurs
Apr 14, 2008 | E-Machines eMachines Refurbished EMA...
Power Supply for L7VMM2
well,if you are sure that the new power supply is new and ok,than more than sure,if you dont have any response from the mainboard,that it is damaged by the high tension who allready burned your initial power supply.
I suggest you to visit a specialised service because for now its nothing you can do more.but first be sure you have a quite functional new power supply.
bye
Feb 05, 2008 | EliteGroup L7VMM2 Motherboard
E machine no power
Make sure the RAM is seated, the CPU, any video card and the Power supply is properly connected.
If you power it on, still get no POST (beep at startup from the PC speakers) its time to replace the motherboard.
Feb 01, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
56 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
