Question about ASUS F8Sn-A1 PC Notebook
Delete partition in vista
RE:
The problem is caused by Formatting the HDD in Vista before moving back to the system.
Simplest fix, hook it back to the Vista system and delete the partition from the drive in disk management. Once that is done, then put the drive with no partition in the XP system and boot to the XP CD, create a new partition and install XP
I don't know how to delete the partition. I'm in disk management, and I can delete volume. Is that the same? Thanks for helping so quickly!
  • mrbrightjuic Jan 30, 2009
    Thanks man! I appreciate your help. I just started my IT degree and I'm learning a lot about the different terminologies for the same thing and my head spins!
  • 3,940 Answers
Volume = Partiton yes
Don't you wish they'ed just keep the same terminology?
Posted on Jan 29, 2009
Hi, when I tried to upgrade/clone existing 60GB HD in Dell Inspiron 630m to HM160HC Samsung HDD, the HM160HC was partitioned to 60GB. I tried to fix the LBA to get back 160G but no success. I think only...
Hello Private672, Hi, If you have no important documents on the HDD or has been back up already, the full hdd size can be edited when you install another windows on it. there is a portion in the installation where you can delete and edit the partition. There are other free software utility on the internet for downloads to edit and low level your hard drive to get back the full size. among these are Partition Magic, Disk Manager. do a google search
Mar 02, 2011 | Samsung SA07HM160HC Samsung HM160HC 2.5...
Unable to access safe mode using f8 or msconfig because a virus has exe,
try to scan ur system using your anti-virus or if still not work you need to reset it to its factory default or reformatting your HDD...
How to Format a Computer with Windows Vista
Warning - Formatting hard drive information does not permanently erase the data. Even after a computer has been formatted, deleted files can be easily recovered. If you want to permanently wipe your hard drive by completely overwritting hard drive data, check out WipeDrive.
To format your hard disk during Windows Vista installation, you'll need to start, or boot, your computer using the Windows Vista installation disc or USB flash drive.
  1. Turn on your computer so that Windows starts normally, insert the Windows Vista installation disc, and then shut down your computer.
  2. Restart your computer.
  3. Press any key when prompted, and then follow the instructions that appear.
  4. On the Install Windows page, follow any instructions that are displayed, and then click Install now.
    • If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start Windows from a CD or DVD.
  5. On the Get important updates for installation page, we recommend getting the latest updates to help ensure a successful installation and to help protect your computer against security threats. You will need an Internet connection to get installation updates.
  6. On the Type your product key for activation page, do one of the following:
    • If you are reinstalling Windows Vista, you should enter your product key now.
    • If you are not reinstalling Windows Vista, you can skip this step.
  7. On the Please read the license terms page, if you accept the license terms, click I accept the license terms.
  8. On the Which type of installation do you want? page, click Custom.
  9. On the Where do you want to install Windows? page, click Drive options (advanced).
  10. Click the partition that you want to format and click Format
    • If you have more than one partition on this hard drive and want to get rid them to make one big drive again, then select a partition and click on the Delete option for each partition. Once you have deleted all of the partitions, select the Unallocated Space partition and click Format
  11. When you've finished formatting, click Next.
  12. Follow the instructions to finish installing Windows Vista, which include naming your computer and setting up an initial user account.
    • If you do not want to reinstall Windows Vista, you can cancel the installation at this point and keep your newly formatted drives.
Oct 03, 2010 | Computers & Internet
R600 - hard drive light flashes at a constant rate
The simplest solution to your problem would be to reinstall Windows Vista after deleting the old version.
Be sure to boot your computer with the DVD in the drive and when it asks if you want to remove the partition, answer YES. Then put in a new partition, format the drive and reload Vista by rebooting your system with Vista in your DVD drive.
You may lose your sound drivers but they can be downloaded from the Toshiba web site.
Just as an afterthought, you should have at least 1 Gig of RAM installed.
Good luck,
BW
Nov 12, 2009 | Computers & Internet
Can't restore, want to erase HDD and install over from scratch
You'll have to departition the hard drive. Also, copying Windows from another computer probably won't work.
Try running a registry cleaner. It can fix a lot of problems after having a virus or malware.
Aug 06, 2009 | Computers & Internet
Copying Files to PS3
Check what the "File System" type is by going to Start, Control Panel, Administrative Tools, Computer Management, Disk Manager. Select the external drive and read the "File System" type. The file system type must be "FAT32" in order for the Playstation to recognize it.
  • If the file system type is "NTFS", right click and select "Delete Partition" or "Delete Volume" for Vista.
  • then recreate the partition but do NOT format it. Make sure you assign a drive letter (for this Tutorial, we'll use h:)
  • If you are running Windows, format the drive by going to the command prompt (Vista, right click on command prompt in start menu and click "run as administrator")and type in "format h: /FS:FAT32" (without the quotes). You may need to substitute your drive letter. (note this will not work on XP for a large hard drive - you will have to use a third party formatting utility)
  • If you are using Mac OS X, open /Applications/Utilities/Disk Utility.app, pick the drive, and click on the 'Erase' tab. Pick 'MS-DOS (FAT)' for the file system type, and click on the 'Erase' button. This will reformat the drive in FAT-32.
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
Deleted Vista Recovery Partition. Now XP installer can't read HDD
if you have created recovery disk before the deleting of the recovery partition u can format the drive from your bios and create a new recovery partition using the recovery disk if not if your pc has crashed and your recovery partition is gone u will have to get a new operating system software but if your pc is still stable just run the recovery manager and restore to factory settings and it will put recover partition back on your hard disk
Feb 04, 2009 | Computers & Internet
BOOTMGR is missing Press Ctrl+Alt+Del to restart. Im trying to format an older computer with XP Pro. I physically took out the only hard drive in the computer and hooked it up externally to my laptop to...
Jan 29, 2009 | Computers & Internet
Erasing operating system
Hi, the best option might be to download Norton's Partition Magic (www.symantec.com) ($69.95) however, you can likely find previous versions for down load cheaper or free online. This will allow you to delete the partition that you have XP running on. One thing I will mention to you though, is that it is unlikely XP is causing your computer to slow down. In fact, quite the opposite. Your Vista load draws significantly more resources and memory so you might be better served to remove the Vista load. At any rate, whatever you decide. Make sure to back-up your important files prior to any deleting/re-formatting.
There are other ways to do this, but I have found NPM to be very clean and helpful in the past.
Let me know if this helps you out.
~ Genie-Us IT
Jun 25, 2008 | Gateway MT3705 Notebook
Vista
i'm taking it you have a partition on your HDD right? well if the case is this than simply "delete" the contents on the partition (this is called cleaning up) so it was how you bought it, clear. next just oh i don't know how you would say it. you have to compbine the partitions. i guess you can just delete the partition so your left with drive C:
May 24, 2008 | Computers & Internet
ASUS F8Sn-A1 PC Notebook Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
