Question about Gateway /ton 160W Power Supply (6500582) Power Supply
My gateway FPD 1510 is just white thats all that shows up when its connected to a computer or not. i have a gateway 2000 old monitor and id like to upgrade.
  • 1,602 Answers
WHAT YOU WOULD SPEND TO FIX IT YOU CAN BUY LCD MONITOR 19-24 INCHS RESONIBLE CHEEP, GOODWILL OR SECOND HAND STORES 1-2 PER INCH ON SCREENS,
CANDYMANGANDY
Posted on Jan 29, 2009
I bought a Gateway FPD1830 monator from a friend. What does it need other than a power cord to hook to a dell computer?
VGA or DVI cable, this cable has approx 1" x 1/2 inch blue or white ends and should connect both to the monitor and to the computer to transmit the video signal between the two.
Aug 29, 2010 | Gateway FPD 1830 18.1" Flat Panel LCD...
How do I get the monitor off power save?
it will allow you to enter the selection screen to pick safe mode, you just need to keep hitting the F8 key repetedly as soon as you hit the power button to turn the pc on.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 13, 2010 | Gateway FPD 1510 15.1" Flat Panel LCD...
Gateway fpd 2485 W looked like 60 cycle lines across
Power supply will be the first thing to check, see example of failed Gateway due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 18, 2010 | Gateway FPD1975W 19" LCD Monitor
What cable for Gateway FPD monitor to Dell Dimension 2400 compute
You can either use a dvi or vga cable, for more info go to http://service.gateway.com/s/Manuals/Monitors/8511253.pdf
Mar 03, 2010 | Computers & Internet
Gateway FPD 1730 Monitor
What has happened is part of your back lighting circuitry has gone out. Yes it is repairable but can cost most of what a replacement monitor will cost these days. Check that out before spending the money. If the problem is only in the back lighting circuit then expect to spend about $100 for a replacement board.
LCD monitors lifespan depends on the quality. Normal use and you should get 2-3 years of reliable service minimum. The display itself is good for about 4000 or so hours of use or more. The problems that show up are always (well 99.99% of the time) are back lighting problems like you have experienced. You should turn it off by the switch when not using it as every hour it runs the screen save is an hour of usable life. Heat is not good for it so if your computer gets the dust cleaned out to keep it cool do the monitor at the same time. Once a year at least more if you smoke use gas heat and have pets.
Tube monitors have a much longer life but you have the size weight and poorer display to go with them. If you have to go back to a tube monitor don't go back to your 14 ask around and you should be able to get a 17 or 19 crt for free. Or expect to pay no more than $10-20 for one.
Jul 10, 2009 | Gateway FPD1775W Monitor
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Dark screen of Gateway FPD 1520
If you can see the screen display an image upon close scrutiny, it could be that the florescent back light is burned out.
Aug 03, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
My monitor will not stay on. Gateway FPD 1530 15 in.
problem of smps some time it happen the power supply con't give the complet supply.
if still problem then replace RAM
or replace the display card.
Nov 17, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Computers & Internet Logo
462 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
