Question about Pioneer SD-643HD5 64" Rear Projection Television
Double image. The colors are not blending next to each other
I have a pioneer 64" rear projection hdtv model #SD-643HD5. I have had this tv for 6 years. How can this be fixed.
  • kdg05a36 Jan 29, 2009
    I'M UNABLE TO BLEND THEM TOGETHER. I HAVE MADE SEVERAL ATTEMPTS. WHO AND WHAT PART OR ASSISTANCE IS NEEDED TO FIX THIS ISSUE?
  • 744 Answers
Hi the reason for double image is that due to poor quality of ur picture tube...its better to replace a new picture tube or if any of the Ics have got damaged u have to replace that ICs.. this double imaging may lead to bigger problems like image fading later and then u will not be able to view any picture in ur tv..So its better to go for a picture tube replacement or capacitor replacement...
thank u
Posted on Feb 01, 2009
  • Pioneer Master
  • 19,396 Answers
That is a defective convergence circuit.
The repair job is not simple and must be done by a technician.
Here is the how to : Fixing Convergence problems in RPTV's
  • 4,234 Answers
As indicated by others, this is a convergence problem. If you can solder and you feel comfortable working inside the set, you can fix this yourself. Please note that there are potentially dangerous high voltages present even when the set is unplugged.
First locate the convergence ICs. These are large black ICs attached to a heatsink and will be marked STK392-110. Resolder the pins on these ICs first. If that fails to resolve the problem, replace the ICs. Please note that there may be additional parts that require replacement. Once the above steps are completed, update this with the results. We will then address the additional parts if required.
Thanks,
Dan
Posted on Jan 29, 2009
    Sergeant:
  • 378 Answers
On the main board of the tv there are two convergence ic .they have to be replaced .the number of ic is 392-----100 .both has to be replace to clear the problem.a repair person is required at your place.to do this job.
    President:
  • 1,990 Answers
Welcome to Fixya! It turns out that this is a known problem for these sets. The recommended "fix" is to replace the convergence board at a cost of $375. I wouldn't recommend that kind of investment at this point. It is possible that the convergence ICs are starting to fail and that can show up in this manner as well. If you are to invest in this at all, I would try resoldering the entire convergence board first. If that does not resolve the problem, replace the convergence ICs (STK392-110 I think) and report the results here. Other than that, you are best to invest the $375 into a newer set. Please Rate my Solution, I need all the Help that I can Get! Thanks!
  • 679 Answers
There is a reset option on the remote,
the reset button is used to reset the default setting.
    Genius:
  • 2,920 Answers
It needs to be converged.call a tv repairman and tell them you need them to converge the tv and they will come out and do it. it shouldnt cost alot
    Sergeant:
  • 250 Answers
Its the problem of internal ic that r at their last stage.and needs to be replaced on the main board.to fix this problem.
  • 10,594 Answers
Its problem of convergence out ICs failure and require replacement of these 2 ICs.
  • Shahid Electronics
    Shahid Electronics Jan 29, 2009
    Its simple convergence board swap. Board is available in Part Store and a little tech minded can swap it easily or ask help from any friend.
I have a 64 inch hdtv pioneer projection monitor sd-643hd5 and it won't fit into my basement. What can I do? Thank You In Advance, Bruce Morash
Ha Ha, I had the exact problem. I think mine is the same model of TV as well, I have a 64" Pioneer made in 2003. So my TV would hit the slanted ceiling above my stairs as I tried to move it down. I first took off the wheels of the TV and this helped but it was not quite enough. So since the bottom of the TV is flat with exception of the side boards and the front trim. I removed the front trim temporarily and cut off the side boards with a circular saw till even with the flat bottom. This gave me 2.5" more clearance which was enough to fit the TV downstairs. Hint if you scribe the cut line with a utility knife it will reduce chipping.
TimBilt
Mar 28, 2011 | Pioneer SD-643HD5 64" Rear Projection...
I have a Pioneer SD-643HD5 that was working and then just turned off? Now the tv won't turn on
CK for Blowed Fuse will be in middle of chassis 6amp fuse if it is blowed set will not come on.
Dec 30, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Just fixed the convergence chip problem.$534.00. Now 720p and 1080 1 signals are showing double images and colors. Also the componentinput #2 is showing double images on any format
many of these sets need the convergence adjusted in the 480 and the 1080 separate-- the set most likely if looks good in 480 needs to be adjusted with the original remote in the 1080 mode.
Whoever charged you 534 got you---if you did it yourself you paid way too much--with 1080 signal--enter convergence mode and try to adjust in customer menu--if 480 is ok---it needs to be adjusted in the hd mode.
SD TECH
Oct 31, 2009 | Pioneer SD-643HD5 64" Rear Projection...
My t v is begining to show with colors overlapping
Replace Both convergence ICs STK392-110s upgrade to the 180s MATS Electronics 1-800-628-1118.
Aug 08, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Picture is green and stays green
check the convergence area for bad solder connection
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Aug 19, 2007 | Pioneer SD-643HD5 64" Rear Projection...
HELP TO FIND IC's CONVERGENCE GENERIC NUMBERS
STK392-180 http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Aug 01, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-643HD5 64 in. Rear Projection
You need to replace convergence chips - they are behind the large black heatsink
May 22, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-643HD5 64" Rear Projection Television Logo
18 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
